Im new to TrueNAS, I installed Plex and Ollama and they do not show up under apps.
However, if I try to go back to Discover apps and Install it again:
Im not sure how I can delete the app and or why its not showing up under apps.
Thank you
Thank you
Hi, i’m not sur to expose the right method but go to the scale shell and enter this line of command :
cd …/mnt/name_of_your_storage/ix-applications/releases
and just after
rm -r -f plex
it will remove the folder name plex and all the subfolder. like this you can install plex with the name “plex”.
Warmly
P.S: sorry if I make spelling mistake I speak French
Hi LDM,
Thank you, however, im seeing this:
admin@truenas[~]$ cd /mnt/Apollo-Plex/ix-applications/releases
cd: no such file or directory: /mnt/Apollo-Plex/ix-applications/releases
don’t forget the ‘…’ before all the directory (the firts ‘/’ ) just 2 points i didnt know why the website show 3 then I only write two
if you have write it are you sur you use the right disk in the directory ?
it’s noty finish to reboot or just to analyse the application like you can see on the right top corner.
Im seeing this: 2024-05-21 16:33:29 network is not ready: container runtime network not ready: NetworkReady=false reason:NetworkPluginNotReady message:Network plugin returns error: cni plugin not initialized
Where do you see this ? ( I didn’t say you any thing who can change network setting so I don’t kno where you can see it. )
now when you are in “application” you see the same thing ? when you go to “settings” your storage is select ?
Warmly
