Hi there !
I am starting to get not so new with truenas, but until now, I used it only for storage, and have a dedicated proxmox machine nearby.
However, I am trying to remove it, and migrate some services to truenas.
One of them is nginx, which I want to have with a dedicated ip address, and have port 80 and 443 directly available.
I managed to configure this, and it works quite well. I have my certificates working, and nginx ui is also working for easier management.
However, the site files are on a dedicated dataset, and of course, the container is run as root (unprivileged), while nginx is run as www-data.
On the dataset, I have a dedicated user (called webhost), with a specific uid, same for the group.
I am having issues making these files being delivered by nginx though, and I don’t know why.
This seems to be a right error, and based on the new documentation given by Truenas, there is a mapping option for the users uid and gid.
So, I used it, and assigned the user webhost to the www-data uid and gid with this panel, but this is not working at all.
I also tried to change the uid and gid of www-data to match the ones from webhost, but still no results.
Is it a bug on truenas side as it is still experimental, or am I doing something wrong here ?
Thanks for any help/reply ![]()
