I have an AsRock Rack X570D4U-2L2T and AMD Ryzen 7 5700X.
In BIOS I had to enable Above 4G Decoding which then exposed a new setting which allowed me to set ReBAR to Auto. I also disabled SR-IOV.
In the Jellyfin pod settings, I selected Allocate 5 gpu.intel. com/i915 GPU and launched it. Went into the Jellyfin transcoding settings and set hardware acceleration to QSV and checked all the decoding and encoding capabilities - except the two Intel Low-Power encoders.
Can I enable those? I haven’t tried yet.
I don’t know how to verify that transcoding is working. I really wish intel-gpu-tools were installed so I could run intel_gpu_top to look at stats. It would be great to also be able to add that to Netdata as explained here.
I was watching a movie and the CPU was around 0% so I assume the dGPU was doing the transcoding.
How can I tell if the A40 is doing the transcoding??
I’ve got a feature request in to add the intel-gpu-tools -
But in the short term you can look in the Jellyfin dashboard under Logs to find your ffmpeg log for the playback, and see if it’s using the QSV transcoder.
Greetings, I am on EE 24.10.1 and having difficulty getting my AS Rock X570D4U to recognize my new Arc A380. My settings for 4G and BAR are On and Auto with SR-IOV disabled. The card works on my windows 11 rig. I am using an AMD Ryzen 7 5700X CPU. I cannot get the Linux shell to recognize my card with lspci -k | grep -EA3 'VGA|3D|Display' which is supposed to list all PCI devices related to graphics cards. I only see the onboard ASPEED VGA controller listed. I have a feeling I’m setting something incorrectly in the BIOS since others on other forums have reported success with this card. Appreciate any help.
I’m replying to myself to add that I contacted ASRock and they had me flash the newer beta L1.57 BIOS. I reset all to default, changed the following settings only: 4G on, BAR to auto, per recommendation from ASRock tech set the video OpROM policy to UEFI. lspci still only shows the ASPEED onboard graphic controller. Does anyone have any suggestions for a noob?
