Intel e1000e module load failure on 25.04-BETA.1
I have:
lspci -v | grep -A9 Ether
00:19.0 Ethernet controller: Intel Corporation 82579V Gigabit Network Connection (rev 04)
        DeviceName: Intel(R) 82579V Gigabit Ethernet Device
        Subsystem: Intel Corporation 82579V Gigabit Network Connection
        Flags: fast devsel, IRQ 20
        Memory at f0600000 (32-bit, non-prefetchable) [size=128K]
        Memory at f0625000 (32-bit, non-prefetchable) [size=4K]
        I/O ports at 6040 [size=32]
        Capabilities: [c8] Power Management version 2
        Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [e0] PCI Advanced Features
        Kernel modules: e1000e
It works fine on every other system I have ever installed on this hardware. Now I get:
[  845.193595] e1000e: Intel(R) PRO/1000 Network Driver
[  845.193600] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[  845.193792] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[  845.245434] e1000e 0000:00:19.0: probe with driver e1000e failed with error -3
This is an issue reported regularly elsewhere, mainly on Debian-based systems the last three or so years. As I have installed a 2.5GB/s Realtek PCIe card on the server, which works OK, I am fine connecting to the system.
Basically, I am just flagging the error. The solutions one can find involve rebuilding the kernel module, which is not to be expected from a general TrueNAS-Scale user.
Have you filed a bug report?
Bugs should be reported in Jira. TrueNAS - Issues - iXsystems TrueNAS Jira
Info about feedback in Truenas Docs: Providing Feedback in TrueNAS | TrueNAS Documentation Hub
