Intel SSD reported temp and what SMART data displays
I am having trouble understanding why TrueNAS is reporting the drive temp so high when it is not. I have 2 of the same drive, Intel 545s Series SSDs, they both report there temp in Reporting as way to hot 76c and 79c but when I run “sudo smartctl -x /dev/xxx” in the shell I get the output shown below. I am running TrueNAS Scale EE RC2. I have these 2 drives set up as the boot pool so they are mirrored.
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Intel 545s Series SSDs
Device Model:     INTEL SSDSC2KW256G8
Serial Number:    BTLA734007P6256CGN
LU WWN Device Id: 5 5cd2e4 14deddd73
Firmware Version: LHF002C
User Capacity:    256,060,514,304 bytes [256 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-3 (minor revision not indicated)
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Oct 23 12:11:26 2024 MDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Write SCT (Get) Feature Control Command failed: scsi error badly formed scsi parameters
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (    0) seconds.
capabilities:                    (0x53) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (  15) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  5 Reallocated_Sector_Ct   -O--CK   100   100   000    -    0
  9 Power_On_Hours          -O--CK   100   100   000    -    4483
 12 Power_Cycle_Count       -O--CK   100   100   000    -    1165
170 Unknown_Attribute       PO--CK   100   100   010    -    0
171 Program_Fail_Count      -O--CK   100   100   000    -    0
172 Erase_Fail_Count        -O--CK   100   100   000    -    0
173 Unknown_Attribute       PO--CK   100   100   005    -    55836737540
174 Unexpect_Power_Loss_Ct  -O--CK   100   100   000    -    103
183 SATA_Downshift_Count    -O--CK   100   100   000    -    0
184 End-to-End_Error        PO--CK   100   100   090    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
190 Temperature_Case        -O--CK   024   046   000    -    24 (Min/Max 9/46)
192 Unsafe_Shutdown_Count   -O--CK   100   100   000    -    103
199 CRC_Error_Count         -O--CK   100   100   000    -    0
225 Host_Writes_32MiB       -O--CK   100   100   000    -    122267
226 Workld_Media_Wear_Indic -O--CK   100   100   000    -    0
227 Workld_Host_Reads_Perc  -O--CK   100   100   000    -    0
228 Workload_Minutes        -O--CK   100   100   000    -    0
232 Available_Reservd_Space PO--CK   100   100   010    -    0
233 Media_Wearout_Indicator -O--CK   099   099   000    -    0
236 Unknown_Attribute       -O--CK   099   099   000    -    0
241 Host_Writes_32MiB       -O--CK   100   100   000    -    122267
242 Host_Reads_32MiB        -O--CK   100   100   000    -    173204
249 NAND_Writes_1GiB        -O--CK   100   100   000    -    3967
252 Unknown_Attribute       -O--CK   100   100   000    -    13
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01       GPL,SL  R/O      1  Summary SMART error log
0x02       GPL,SL  R/O      1  Comprehensive SMART error log
0x03       GPL,SL  R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06       GPL,SL  R/O      1  SMART self-test log
0x07       GPL,SL  R/O      1  Extended self-test log
0x09       GPL,SL  R/W      1  Selective self-test log
0x10       GPL,SL  R/O      1  NCQ Command Error log
0x11       GPL,SL  R/O      1  SATA Phy Event Counters log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xdf       GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%         0         -
SCT Status Version:                  3
SCT Version (vendor specific):       0 (0x0000)
Device State:                        Active (0)
Current Temperature:                    31 Celsius
Power Cycle Min/Max Temperature:     26/32 Celsius
Lifetime    Min/Max Temperature:     14/55 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/100 Celsius
Min/Max Temperature Limit:            0/100 Celsius
Temperature History Size (Index):    128 (59)
Index    Estimated Time   Temperature Celsius
  60    2024-10-23 10:04    32  *************
 ...    ..( 10 skipped).    ..  *************
  71    2024-10-23 10:15    32  *************
  72    2024-10-23 10:16    24  *****
  73    2024-10-23 10:17    31  ************
 ...    ..(  4 skipped).    ..  ************
  78    2024-10-23 10:22    31  ************
  79    2024-10-23 10:23    30  ***********
 ...    ..(  6 skipped).    ..  ***********
  86    2024-10-23 10:30    30  ***********
  87    2024-10-23 10:31    33  **************
  88    2024-10-23 10:32    31  ************
 ...    ..(  3 skipped).    ..  ************
  92    2024-10-23 10:36    31  ************
  93    2024-10-23 10:37    32  *************
  94    2024-10-23 10:38    33  **************
  95    2024-10-23 10:39    31  ************
  96    2024-10-23 10:40    30  ***********
  97    2024-10-23 10:41    31  ************
 ...    ..(  5 skipped).    ..  ************
 103    2024-10-23 10:47    31  ************
 104    2024-10-23 10:48    32  *************
 105    2024-10-23 10:49    31  ************
 106    2024-10-23 10:50    32  *************
 107    2024-10-23 10:51    31  ************
 ...    ..(  2 skipped).    ..  ************
 110    2024-10-23 10:54    31  ************
 111    2024-10-23 10:55    30  ***********
 112    2024-10-23 10:56    30  ***********
 113    2024-10-23 10:57    26  *******
 114    2024-10-23 10:58    32  *************
 115    2024-10-23 10:59    31  ************
 120    2024-10-23 11:04    31  ************
 121    2024-10-23 11:05    30  ***********
 122    2024-10-23 11:06    29  **********
 125    2024-10-23 11:09    29  **********
 126    2024-10-23 11:10    28  *********
 127    2024-10-23 11:11    28  *********
   0    2024-10-23 11:12    30  ***********
   1    2024-10-23 11:13    29  **********
   2    2024-10-23 11:14    29  **********
   3    2024-10-23 11:15    29  **********
   4    2024-10-23 11:16    30  ***********
 ...    ..(  9 skipped).    ..  ***********
  14    2024-10-23 11:26    30  ***********
  15    2024-10-23 11:27    31  ************
  16    2024-10-23 11:28    30  ***********
  17    2024-10-23 11:29    31  ************
  18    2024-10-23 11:30    30  ***********
  19    2024-10-23 11:31    31  ************
  20    2024-10-23 11:32    30  ***********
  21    2024-10-23 11:33    30  ***********
  22    2024-10-23 11:34    30  ***********
  23    2024-10-23 11:35    31  ************
 ...    ..( 13 skipped).    ..  ************
  37    2024-10-23 11:49    31  ************
  38    2024-10-23 11:50    29  **********
  39    2024-10-23 11:51    30  ***********
  40    2024-10-23 11:52    31  ************
  41    2024-10-23 11:53    31  ************
  42    2024-10-23 11:54    29  **********
  46    2024-10-23 11:58    29  **********
  47    2024-10-23 11:59    30  ***********
  48    2024-10-23 12:00    30  ***********
  49    2024-10-23 12:01    31  ************
  50    2024-10-23 12:02    29  **********
  51    2024-10-23 12:03    30  ***********
  52    2024-10-23 12:04    30  ***********
  53    2024-10-23 12:05    30  ***********
  54    2024-10-23 12:06    31  ************
  58    2024-10-23 12:10    31  ************
  59    2024-10-23 12:11    33  **************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4            1165  ---  Lifetime Power-On Resets
0x01  0x010  4            4483  ---  Power-on Hours
0x01  0x018  6      8012914085  ---  Logical Sectors Written
0x01  0x020  6        37211835  ---  Number of Write Commands
0x01  0x028  6     11351150690  ---  Logical Sectors Read
0x01  0x030  6        74494575  ---  Number of Read Commands
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4             103  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              32  ---  Current Temperature
0x05  0x010  1              31  ---  Average Short Term Temperature
0x05  0x018  1               -  ---  Average Long Term Temperature
0x05  0x020  1              57  ---  Highest Temperature
0x05  0x028  1              29  ---  Lowest Temperature
0x05  0x030  1              35  ---  Highest Average Short Term Temperature
0x05  0x038  1              30  ---  Lowest Average Short Term Temperature
0x05  0x040  1               -  ---  Highest Average Long Term Temperature
0x05  0x048  1               -  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              85  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4            9480  ---  Number of Hardware Resets
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1               1  ---  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0005  2            0  R_ERR response for non-data FIS
0x000a  2            5  Device-to-host register FISes sent due to a COMRESET
and
Serial Number:    PHLA8076006Y256CGN
LU WWN Device Id: 5 5cd2e4 14f1a0c43
Local Time is:    Wed Oct 23 12:18:46 2024 MDT
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  9 Power_On_Hours          -O--CK   100   100   000    -    28431
 12 Power_Cycle_Count       -O--CK   100   100   000    -    1266
173 Unknown_Attribute       PO--CK   096   096   005    -    317834657817
174 Unexpect_Power_Loss_Ct  -O--CK   100   100   000    -    133
183 SATA_Downshift_Count    -O--CK   100   100   000    -    3
190 Temperature_Case        -O--CK   024   044   000    -    24 (Min/Max 0/44 #143)
192 Unsafe_Shutdown_Count   -O--CK   100   100   000    -    133
199 CRC_Error_Count         -O--CK   100   100   000    -    5
225 Host_Writes_32MiB       -O--CK   100   100   000    -    264830
233 Media_Wearout_Indicator -O--CK   096   096   000    -    0
236 Unknown_Attribute       -O--CK   096   096   000    -    0
241 Host_Writes_32MiB       -O--CK   100   100   000    -    264830
242 Host_Reads_32MiB        -O--CK   100   100   000    -    141521
249 NAND_Writes_1GiB        -O--CK   100   100   000    -    19215
252 Unknown_Attribute       -O--CK   100   100   000    -    74
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Short offline       Completed without error       00%     25213         -
Current Temperature:                    30 Celsius
Power Cycle Min/Max Temperature:     24/32 Celsius
Lifetime    Min/Max Temperature:      3/53 Celsius
Temperature History Size (Index):    128 (52)
  53    2024-10-23 10:11    30  ***********
  56    2024-10-23 10:14    30  ***********
  57    2024-10-23 10:15    31  ************
 ...    ..(  7 skipped).    ..  ************
  65    2024-10-23 10:23    31  ************
  66    2024-10-23 10:24    23  ****
  67    2024-10-23 10:25    30  ***********
  73    2024-10-23 10:31    30  ***********
  74    2024-10-23 10:32    29  **********
  75    2024-10-23 10:33    28  *********
  76    2024-10-23 10:34    29  **********
  79    2024-10-23 10:37    29  **********
  80    2024-10-23 10:38    30  ***********
  81    2024-10-23 10:39    33  **************
 ...    ..(  4 skipped).    ..  **************
  86    2024-10-23 10:44    33  **************
  87    2024-10-23 10:45    32  *************
  88    2024-10-23 10:46    31  ************
  89    2024-10-23 10:47    30  ***********
  97    2024-10-23 10:55    30  ***********
  98    2024-10-23 10:56    31  ************
  99    2024-10-23 10:57    30  ***********
 104    2024-10-23 11:02    30  ***********
 105    2024-10-23 11:03    29  **********
 106    2024-10-23 11:04    29  **********
 107    2024-10-23 11:05    24  *****
 108    2024-10-23 11:06    30  ***********
 114    2024-10-23 11:12    30  ***********
 115    2024-10-23 11:13    29  **********
 116    2024-10-23 11:14    28  *********
 117    2024-10-23 11:15    28  *********
 118    2024-10-23 11:16    28  *********
 119    2024-10-23 11:17    27  ********
 120    2024-10-23 11:18    27  ********
 121    2024-10-23 11:19    27  ********
 122    2024-10-23 11:20    30  ***********
 123    2024-10-23 11:21    32  *************
 124    2024-10-23 11:22    30  ***********
 125    2024-10-23 11:23    30  ***********
 126    2024-10-23 11:24    29  **********
 127    2024-10-23 11:25    30  ***********
 ...    ..( 31 skipped).    ..  ***********
  31    2024-10-23 11:57    30  ***********
  32    2024-10-23 11:58    27  ********
  33    2024-10-23 11:59    29  **********
  34    2024-10-23 12:00    30  ***********
  35    2024-10-23 12:01    30  ***********
  36    2024-10-23 12:02    27  ********
  37    2024-10-23 12:03    28  *********
  38    2024-10-23 12:04    27  ********
  39    2024-10-23 12:05    28  *********
  40    2024-10-23 12:06    27  ********
  41    2024-10-23 12:07    28  *********
  42    2024-10-23 12:08    29  **********
  43    2024-10-23 12:09    30  ***********
  44    2024-10-23 12:10    28  *********
  45    2024-10-23 12:11    27  ********
  46    2024-10-23 12:12    30  ***********
  52    2024-10-23 12:18    30  ***********
           Read: Disabled
          Write: Disabled
0x01  0x008  4            1266  ---  Lifetime Power-On Resets
0x01  0x010  4           28431  ---  Power-on Hours
0x01  0x018  6     17355908891  ---  Logical Sectors Written
0x01  0x020  6       545380834  ---  Number of Write Commands
0x01  0x028  6      9274782090  ---  Logical Sectors Read
0x01  0x030  6        61211373  ---  Number of Read Commands
0x04  0x010  4             133  ---  Resets Between Cmd Acceptance and Completion
0x05  0x008  1              30  ---  Current Temperature
0x05  0x010  1              29  ---  Average Short Term Temperature
0x05  0x018  1              35  ---  Average Long Term Temperature
0x05  0x020  1              54  ---  Highest Temperature
0x05  0x028  1              24  ---  Lowest Temperature
0x05  0x030  1              42  ---  Highest Average Short Term Temperature
0x05  0x038  1              29  ---  Lowest Average Short Term Temperature
0x05  0x040  1              38  ---  Highest Average Long Term Temperature
0x06  0x008  4            9598  ---  Number of Hardware Resets
0x06  0x018  4               5  ---  Number of Interface CRC Errors
0x07  0x008  1               7  ---  Percentage Used Endurance Indicator
                                ||__ D supports DSN
@Curtis8523 it looks like they’re reporting the SMART temperature value in a nonstandard way. Normally vendors populate SMART 194 with the temperature sensor but it looks like that’s a null field here.
Can you report a bug for this with a debug log attached?
Ticket created.
Thanks for the quick response.
Was there ever a solution on this? I have having similar issues. I can create a thread and post details, but if you had a solution I figured I would try this first.
Try checking SMART 194 as was said as normal for your device in the Smart data? Is it using that field? Report a Bug in GUI might be an idea if it isn’t, along with a debug dump. Upper right of GUI is a smile icon for Feedback / Report A Bug
I can’t find the ticket that was created by the OP - but can you dump the SMART attributes (sudo smartctl -a /dev/sdX) of a disk and we’ll see where/which attribute is reporting the correct temperature.
Ticket is here,
https://ixsystems.atlassian.net/browse/NAS-131958
not fixed yet. still broken.
Edit to add: appears to be 190 for the temperature. When using GUI, it reports as min 78 and max 79.
Model Family:     Intel 53x and Pro 1500/2500 Series SSDs
Device Model:     INTEL SSDSC2BW120A4
Serial Number:    PHDA411600T21207GN
LU WWN Device Id: 5 5cd2e4 00039908a
Firmware Version: DC32
User Capacity:    120,034,123,776 bytes [120 GB]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Aug  1 23:06:54 2025 CDT
Offline data collection status:  (0x02) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                ( 2930) seconds.
capabilities:                    (0x7f) SMART execute Offline immediate.
                                        Abort Offline collection upon new
                                        command.
                                        power-saving mode.
recommended polling time:        (   1) minutes.
recommended polling time:        (  48) minutes.
Conveyance self-test routine
SCT capabilities:              (0x0025) SCT Status supported.
  5 Reallocated_Sector_Ct   0x0032   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours_and_Msec 0x0032   100   100   000    Old_age   Always       -       351h+10m+47.540s
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       25
170 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       7
183 SATA_Downshift_Count    0x0032   100   100   000    Old_age   Always       -       1
184 End-to-End_Error        0x0033   100   100   090    Pre-fail  Always       -       0
187 Uncorrectable_Error_Cnt 0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0032   023   040   000    Old_age   Always       -       23 (Min/Max 18/40)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       7
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       1
225 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       2590
226 Workld_Media_Wear_Indic 0x0032   100   100   000    Old_age   Always       -       65535
227 Workld_Host_Reads_Perc  0x0032   100   100   000    Old_age   Always       -       52
228 Workload_Minutes        0x0032   100   100   000    Old_age   Always       -       65535
232 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
233 Media_Wearout_Indicator 0x0032   100   100   000    Old_age   Always       -       0
241 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       2590
242 Host_Reads_32MiB        0x0032   100   100   000    Old_age   Always       -       584
249 NAND_Writes_1GiB        0x0032   100   100   000    Old_age   Always       -       180
SMART Error Log not supported
# 1  Short offline       Completed without error       00%       332         -
# 2  Short offline       Completed without error       00%       243         -
# 3  Extended offline    Completed without error       00%       239         -
# 4  Offline             Interrupted (host reset)      10%       217         -
# 5  Short offline       Completed without error       00%       175         -
# 6  Offline             Interrupted (host reset)      10%       149         -
# 7  Offline             Interrupted (host reset)      10%       131         -
# 8  Short offline       Completed without error       00%        90         -
# 9  Extended offline    Completed without error       00%        86         -
#10  Offline             Interrupted (host reset)      10%        58         -
#11  Short offline       Completed without error       00%        24         -
#12  Extended offline    Completed without error       00%        22         -
#13  Offline             Interrupted (host reset)      10%        20         -
#14  Offline             Interrupted (host reset)      10%        20         -
#15  Offline             Interrupted (host reset)      10%        20         -
#16  Offline             Interrupted (host reset)      10%        20         -
#17  Offline             Interrupted (host reset)      10%        20         -
#18  Offline             Interrupted (host reset)      10%        19         -
#19  Offline             Interrupted (host reset)      10%        17         -
#20  Offline             Interrupted (host reset)      10%        17         -
#21  Offline             Interrupted (host reset)      10%        17         -
190 is the smart attribute the value is 23 from your output. Something is happening to me.
Yeah it was late and I didn’t phrase that well. 190 was the attribute where it was reading the temperature. GUI temp is 78-79, which is way too high as well. Actual temps are fine. I am mostly worried about it affecting fans, I am working on quieting my new to me 2U server.
Would be nice for it to be accurate as well for alarming me if temps are off.
