Hi, I’m tried to look about it without particular success. I moved from Core to Scale. I rebuilt my applications in dockers, so my question is if is correct to delete the iocage dataset or if this can create problems. At present I don’t have any issue, it is just to have a clean system. Thanks
The iocage dataset is part of the jails system on CORE, and isn’t used on SCALE.
Thanks, so I will remove it
