I’m having some trouble getting a modded Minecraft server running on my TrueNAS setup, and I’m not sure if this is a Minecraft issue or something with TrueNAS itself.
I’m trying to launch a Minecraft 1.21.1 server with Fabric Loader 0.16.10 using the Crafty Controller app on TrueNAS, but no matter what I try, I keep getting the same error. Here’s what the log shows:
[23:29:30] [INFO] [FabricLoader/GameProvider]: Loading Minecraft 1.21.1 with Fabric Loader 0.16.10
[23:29:30] [INFO] [FabricLoader/GameRemap]: Fabric is preparing JARs on first launch, this may take a few seconds...
[23:29:34] [ERROR] [FabricLoader/]: Uncaught exception in thread "main"
java.lang.RuntimeException: An exception occurred when launching the server!
at net.fabricmc.loader.impl.launch.server.FabricServerLauncher.main(FabricServerLauncher.java:71)
at net.fabricmc.installer.ServerLauncher.main(ServerLauncher.java:69)
Caused by: java.lang.RuntimeException: error remapping game jars [/crafty/servers/6062f25c-f21b-40b1-ad9f-9a228482b95c/versions/1.21.1/server-1.21.1.jar]
at net.fabricmc.loader.impl.game.GameProviderHelper.deobfuscate(GameProviderHelper.java:248)
at net.fabricmc.loader.impl.game.minecraft.MinecraftGameProvider.initialize(MinecraftGameProvider.java:331)
at net.fabricmc.loader.impl.launch.knot.Knot.init(Knot.java:140)
at net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:68)
at net.fabricmc.loader.impl.launch.knot.KnotServer.main(KnotServer.java:23)
at net.fabricmc.loader.impl.launch.server.FabricServerLauncher.main(FabricServerLauncher.java:69)
... 1 more
Caused by: java.nio.file.FileSystemException: /crafty/servers/6062f25c-f21b-40b1-ad9f-9a228482b95c/./.fabric/remappedJars/minecraft-1.21.1-0.16.10/zipfstmp5830680519539875243.tmp: Operation not permitted
at java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:100)
at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:106)
at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111)
at java.base/sun.nio.fs.UnixFileAttributeViews$Posix.setMode(UnixFileAttributeViews.java:277)
at java.base/sun.nio.fs.UnixFileAttributeViews$Posix.setPermissions(UnixFileAttributeViews.java:299)
at java.base/java.nio.file.Files.setPosixFilePermissions(Files.java:2169)
at jdk.zipfs/jdk.nio.zipfs.ZipFileSystem.sync(ZipFileSystem.java:1869)
at jdk.zipfs/jdk.nio.zipfs.ZipFileSystem.lambda$close$9(ZipFileSystem.java:484)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:571)
at jdk.zipfs/jdk.nio.zipfs.ZipFileSystem.close(ZipFileSystem.java:483)
at net.fabricmc.loader.impl.lib.tinyremapper.FileSystemReference.close(FileSystemReference.java:131)
at net.fabricmc.loader.impl.lib.tinyremapper.OutputConsumerPath.close(OutputConsumerPath.java:213)
at net.fabricmc.loader.impl.game.GameProviderHelper.deobfuscate0(GameProviderHelper.java:318)
at net.fabricmc.loader.impl.game.GameProviderHelper.deobfuscate(GameProviderHelper.java:246)
... 6 more
This only happens when creating a new server. On a previous version of TrueNAS Scale, I was able to set up Fabric servers without any issues. Right now, the problem only happens when trying to create a new modded server, vanilla works fine.
However, if I import a modded server that was already running on the older TrueNAS version, it works perfectly fine — the imported server launches without any errors and runs without any issues.
What I’ve figured out so far:
- Fabric is trying to remap the game JARs on first launch.
- It’s trying to create or modify temporary files in the
.fabric/remappedJars/directory. - The operation fails due to a permissions issue:
Operation not permitted.
I’ve already given the Crafty Controller app role full control over the dataset where the server files are located, but the error still happens.
As a test, I also tried running the server through the “itzg/docker-minecraft-server” app from the TrueNAS catalog — but while I don’t get logs from that app, the server crashes in the same way, so I suspect it’s the same permissions issue.
What I need help with:
- What exactly is going wrong here?
- Is this a TrueNAS permissions issue, Fabric issue, or something else?
- How can I fix it so the server launches properly?
Any advice or ideas would be appreciated, thanks in advance!
ElectricEel-24.10.2
