Here is the result from sudo dmesg :
[ 70.645946] critical target error, dev sde, sector 42190448 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 70.645978] zio pool=MAIN vdev=/dev/disk/by-partuuid/c5adb8fc-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=19453960192 size=4096 flags=1572992
[ 84.767639] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 85.299466] ioatdma: Intel(R) QuickData Technology Driver 5.00
[ 85.301940] NTB Resource Split driver, version 1
[ 85.303501] Software Queue-Pair Transport over NTB, version 4
[ 85.316424] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 86.843446] pps pps2: new PPS source ptp2
[ 86.843506] ixgbe 0000:24:00.1: registered PHC device on enp36s0f1
[ 92.033826] ixgbe 0000:24:00.1 enp36s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[ 101.060545] audit: type=1400 audit(1730324357.343:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=4571 comm=“apparmor_parser”
[ 101.060549] audit: type=1400 audit(1730324357.343:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=4571 comm=“apparmor_parser”
[ 101.060668] audit: type=1400 audit(1730324357.343:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lsb_release” pid=4570 comm=“apparmor_parser”
[ 101.060761] audit: type=1400 audit(1730324357.343:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“virt-aa-helper” pid=4575 comm=“apparmor_parser”
[ 101.061336] audit: type=1400 audit(1730324357.343:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/bin/man” pid=4573 comm=“apparmor_parser”
[ 101.061339] audit: type=1400 audit(1730324357.343:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“man_filter” pid=4573 comm=“apparmor_parser”
[ 101.061342] audit: type=1400 audit(1730324357.343:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“man_groff” pid=4573 comm=“apparmor_parser”
[ 101.061399] audit: type=1400 audit(1730324357.343:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“libvirtd” pid=4577 comm=“apparmor_parser”
[ 101.061402] audit: type=1400 audit(1730324357.343:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“libvirtd//qemu_bridge_helper” pid=4577 comm=“apparmor_parser”
[ 101.062264] audit: type=1400 audit(1730324357.343:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/sbin/chronyd” pid=4576 comm=“apparmor_parser”
[ 101.788126] systemd-journald[1019]: Data hash table of /var/log/journal/d5e92ecedd4e49478aae4286ed723502/system.journal has a fill level at 75.1 (8540 of 11377 items, 6553600 file size, 767 bytes per hash table item), suggesting rotation.
[ 101.788131] systemd-journald[1019]: /var/log/journal/d5e92ecedd4e49478aae4286ed723502/system.journal: Journal header limits reached or header out-of-date, rotating.
[ 102.756796] NFSD: Using UMH upcall client tracking operations.
[ 102.756802] NFSD: starting 90-second grace period (net f0000000)
[ 241.686339] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 241.686382] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 241.686411] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 241.686437] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 241.686471] sd 0:0:0:0: [sdd] tag#2327 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=7s
[ 241.686483] sd 0:0:0:0: [sdd] tag#2327 Sense Key : Illegal Request [current]
[ 241.686487] sd 0:0:0:0: [sdd] tag#2327 Add. Sense: Logical block address out of range
[ 241.686490] sd 0:0:0:0: [sdd] tag#2327 CDB: Write(16) 8a 00 00 00 00 00 02 8c fa d0 00 00 00 08 00 00
[ 241.686492] critical target error, dev sdd, sector 42793680 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 241.686519] zio pool=MAIN vdev=/dev/disk/by-partuuid/c57ae2de-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=19762814976 size=4096 flags=1572992
[ 316.690841] mce: [Hardware Error]: Machine check events logged
[ 316.690848] mce: [Hardware Error]: Machine check events logged
[ 439.604108] sdh: sdh1
[ 471.275837] sdh: sdh1
[ 515.356903] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 515.357632] sd 0:0:0:0: [sdd] tag#2167 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=6s
[ 515.357644] sd 0:0:0:0: [sdd] tag#2167 Sense Key : Illegal Request [current]
[ 515.357650] sd 0:0:0:0: [sdd] tag#2167 Add. Sense: Logical block address out of range
[ 515.357656] sd 0:0:0:0: [sdd] tag#2167 CDB: Write(16) 8a 00 00 00 00 00 04 4b 4a b8 00 00 00 08 00 00
[ 515.357660] critical target error, dev sdd, sector 72043192 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 515.358757] zio pool=MAIN vdev=/dev/disk/by-partuuid/c57ae2de-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=34738565120 size=4096 flags=1572992
[ 523.149286] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 523.150021] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 523.150686] sd 0:0:2:0: [sdb] tag#2153 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=6s
[ 523.150698] sd 0:0:2:0: [sdb] tag#2153 Sense Key : Illegal Request [current]
[ 523.150705] sd 0:0:2:0: [sdb] tag#2153 Add. Sense: Logical block address out of range
[ 523.150711] sd 0:0:2:0: [sdb] tag#2153 CDB: Write(16) 8a 00 00 00 00 00 04 4b e7 08 00 00 00 08 00 00
[ 523.150715] critical target error, dev sdb, sector 72083208 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 523.151611] zio pool=MAIN vdev=/dev/disk/by-partuuid/c4910958-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=34759053312 size=4096 flags=1572992
[ 541.941551] sdh: sdh1
[ 557.080076] sdi: sdi1
[ 627.980118] mce: [Hardware Error]: Machine check events logged
[ 627.980125] mce: [Hardware Error]: Machine check events logged
[ 687.007351] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 687.008015] sd 0:0:0:0: [sdd] tag#2112 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=6s
[ 687.008028] sd 0:0:0:0: [sdd] tag#2112 Sense Key : Illegal Request [current]
[ 687.008034] sd 0:0:0:0: [sdd] tag#2112 Add. Sense: Logical block address out of range
[ 687.008040] sd 0:0:0:0: [sdd] tag#2112 CDB: Write(16) 8a 00 00 00 00 00 04 5d 33 78 00 00 00 08 00 00
[ 687.008044] critical target error, dev sdd, sector 73216888 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 687.008743] zio pool=MAIN vdev=/dev/disk/by-partuuid/c57ae2de-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=35339497472 size=4096 flags=1572992
[ 690.201829] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.202322] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.202709] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.203072] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.203390] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.203688] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.203986] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.204283] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.204578] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.204872] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.205168] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 690.205471] sd 0:0:2:0: [sdb] tag#2177 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=6s
[ 690.205480] sd 0:0:2:0: [sdb] tag#2177 Sense Key : Illegal Request [current]
[ 690.205484] sd 0:0:2:0: [sdb] tag#2177 Add. Sense: Logical block address out of range
[ 690.205489] sd 0:0:2:0: [sdb] tag#2177 CDB: Write(16) 8a 00 00 00 00 00 04 5e 0e f8 00 00 00 08 00 00
[ 690.205491] critical target error, dev sdb, sector 73273080 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 690.206471] zio pool=MAIN vdev=/dev/disk/by-partuuid/c4910958-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=35368267776 size=4096 flags=1572992
[ 799.699633] sdh: sdh1
[ 824.421679] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.422433] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.423096] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.423739] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.424372] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.425001] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.425629] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.426253] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.426875] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.427501] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.428122] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 824.428753] sd 0:0:2:0: [sdb] tag#2187 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=6s
[ 824.428768] sd 0:0:2:0: [sdb] tag#2187 Sense Key : Illegal Request [current]
[ 824.428775] sd 0:0:2:0: [sdb] tag#2187 Add. Sense: Logical block address out of range
[ 824.428781] sd 0:0:2:0: [sdb] tag#2187 CDB: Write(16) 8a 00 00 00 00 00 04 5f 2d 60 00 00 00 18 00 00
[ 824.428786] critical target error, dev sdb, sector 73346400 op 0x1:(WRITE) flags 0x0 phys_seg 3 prio class 2
[ 824.430367] zio pool=MAIN vdev=/dev/disk/by-partuuid/c4910958-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=35405807616 size=12288 flags=1074267264
[ 939.261698] mce: [Hardware Error]: Machine check events logged
[ 939.261705] mce: [Hardware Error]: Machine check events logged
[ 1203.302110] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1203.302897] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1203.303570] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1203.304229] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1203.304885] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1203.305532] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1203.306173] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1203.306811] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1203.307457] sd 0:0:2:0: [sdb] tag#2168 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=6s
[ 1203.307469] sd 0:0:2:0: [sdb] tag#2168 Sense Key : Illegal Request [current]
[ 1203.307475] sd 0:0:2:0: [sdb] tag#2168 Add. Sense: Logical block address out of range
[ 1203.307480] sd 0:0:2:0: [sdb] tag#2168 CDB: Write(16) 8a 00 00 00 00 00 04 60 02 40 00 00 00 08 00 00
[ 1203.307485] critical target error, dev sdb, sector 73400896 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 1203.308628] zio pool=MAIN vdev=/dev/disk/by-partuuid/c4910958-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=35433709568 size=4096 flags=1572992
[ 1204.408176] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.408995] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.409691] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.410371] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.411047] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.411722] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.412398] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.413070] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.413740] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.414405] mpt2sas_cm0: log_info(0x31080000): originator(PL), code(0x08), sub_code(0x0000)
[ 1204.415076] sd 0:0:1:0: [sde] tag#2133 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=8s
[ 1204.415087] sd 0:0:1:0: [sde] tag#2133 Sense Key : Illegal Request [current]
[ 1204.415093] sd 0:0:1:0: [sde] tag#2133 Add. Sense: Logical block address out of range
[ 1204.415099] sd 0:0:1:0: [sde] tag#2133 CDB: Write(16) 8a 00 00 00 00 00 04 5f eb 40 00 00 00 08 00 00
[ 1204.415103] critical target error, dev sde, sector 73395008 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ 1204.416337] zio pool=MAIN vdev=/dev/disk/by-partuuid/c5adb8fc-4c75-11ec-b658-d05099df7916 error=121 type=2 offset=35430694912 size=4096 flags=1572992
[ 1250.547396] mce: [Hardware Error]: Machine check events logged
[ 1561.833900] mce: [Hardware Error]: Machine check events logged
[ 1561.833911] mce: [Hardware Error]: Machine check events logged
[ 1873.119008] mce: [Hardware Error]: Machine check events logged
[ 1873.119014] mce: [Hardware Error]: Machine check events logged
[ 2184.404708] mce: [Hardware Error]: Machine check events logged
[ 2184.404715] mce: [Hardware Error]: Machine check events logged
[ 2495.690205] mce: [Hardware Error]: Machine check events logged
[ 2495.690213] mce: [Hardware Error]: Machine check events logged
[ 2806.975827] mce: [Hardware Error]: Machine check events logged
