Hi, every time I get a power loss, my server doesn’t automatically boot back up after the power comes back, but when I power it on manually, I have no issues so it doesn’t seem to be corruption. Does anyone know why that might happen?
This is usually configured in your motherboard’s BIOS / EFI.
I would check there first, to see if your motherboard even has this feature.
Thanks, i’ll check that when i have access to the machine and get back if i have any issues
Consider investing in a UPS (battery backup), even a low-end one that can at least mitigate against brief powerloss events.
I do have one, but I haven’t set it up yet, I will tomorrow, I just need to make sure it properly shuts down both of my servers, so I don’t know if ill plug in the USB of the UPS to the NAS or to my Ubuntu server yet.
I couldn’t agree more. Although ZFS pools are pretty resilient against sudden failures, we have had several brief outages in the 6 months since I implemented our NAS. Additionally it smooths out any brownouts and spikes and protects the electronics of your disks - and you really don’t want one disk much less several disks having their electronics fried at the same time.
What would the setting in the bios be? Because the only thing close i can think of is WOL, which after some research seems to not be well supported by truenas
“Restore on AC Power Loss” or something like that.
The wording might be different.
Could be under “Advanced” or “ACPI” settings.
You want to look into NUT and using same to broadcast from your NUT server to other devices that it’s time to shut down gracefully as the battery goes low. This can be a very frustrating process to set up and test but eventually it will work as intended.
It’s definitely not WOL. @winnielinnie has got it 100% right, but it varies by OEM. Supermicro tech support replied to a similar question like this:
Enter the BIOS setup and select the Advanced > Boot Feature and set the Restore on AC Power Loss setting to “Last State”. You will know there was an AC power loss if the system starts automatically when you plug the AC power cord in. If you plug the power card in and the system does not start (and you have to manually press a button to start the system), that means the system was normally shut down from the operating system.
What i saw some people did is use the TrueNAS support for UPS to shut it down, and make other servers ping the TrueNAS server and if its shut down, shut down the server as well
Yes, that’s what I’m doing. It’s not that much of a hassle to setup honestly.
What UPS do you have? If it works with truenas it’s not that much of a setup.
If needed, I can copy the appropriate settings / configs from my Ubuntu VM and supply it to you.
That would be great, I use a APC Back-UPS NS 700
That’s the theory. In practice, some of the settings are not as simple to implement as one would think. Sort of like ACLs.
Often NUT feels like a lottery.
This is mostly from my bookstack instance (unfortunately you cannot simply copy and paste). It’s been a while since I configured it. If someone has remarks / catches an error or has an improvement, feel free to chime in.
TrueNAS SCALE Settings
Set a user and a password
Settings on Ubuntu Server
- Install NUT
sudo apt update
sudo apt install nut-client
- Create
/etc/nut/nut.confwith the contents of
MODE=netclient
- Create
/etc/nut/upsmon.conf
RUN_AS_USER root
MONITOR ups@<YOUR-TRUENAS-IP>:3493 1 <USERNAME> <PASSWORD> slave
MINSUPPLIES 1
SHUTDOWNCMD "/sbin/shutdown -h"
NOTIFYCMD /usr/sbin/upssched
POLLFREQ 2
POLLFREQALERT 1
HOSTSYNC 15
DEADTIME 15
POWERDOWNFLAG /etc/killpower
NOTIFYMSG ONLINE "UPS %s on line power"
NOTIFYMSG ONBATT "UPS %s on battery"
NOTIFYMSG LOWBATT "UPS %s battery is low"
NOTIFYMSG FSD "UPS %s: forced shutdown in progress"
NOTIFYMSG COMMOK "Communications with UPS %s established"
NOTIFYMSG COMMBAD "Communications with UPS %s lost"
NOTIFYMSG SHUTDOWN "Auto logout and shutdown proceeding"
NOTIFYMSG REPLBATT "UPS %s battery needs to be replaced"
NOTIFYMSG NOCOMM "UPS %s is unavailable"
NOTIFYMSG NOPARENT "upsmon parent process died - shutdown impossible"
NOTIFYFLAG ONLINE SYSLOG+WALL+EXEC
NOTIFYFLAG ONBATT SYSLOG+WALL+EXEC
NOTIFYFLAG LOWBATT SYSLOG+WALL
NOTIFYFLAG FSD SYSLOG+WALL+EXEC
NOTIFYFLAG COMMOK SYSLOG+WALL+EXEC
NOTIFYFLAG COMMBAD SYSLOG+WALL+EXEC
NOTIFYFLAG SHUTDOWN SYSLOG+WALL+EXEC
NOTIFYFLAG REPLBATT SYSLOG+WALL
NOTIFYFLAG NOCOMM SYSLOG+WALL+EXEC
NOTIFYFLAG NOPARENT SYSLOG+WALL
RBWARNTIME 43200
NOCOMMWARNTIME 600
FINALDELAY 5
Replace <YOUR-TRUENAS-IP>, <USERNAME>, <PASSWORD> accordingly. The latter two are the name and password you set in TrueNAS under the UPS service tab.
- Create the paths for
pipefnandlockfn, i.e.
mkdir /etc/nut/upssched/
- Create
/etc/nut/upssched.conf
CMDSCRIPT /etc/nut/upssched-cmd
PIPEFN /etc/nut/upssched/upssched.pipe
LOCKFN /etc/nut/upssched/upssched.lock
AT ONBATT * START-TIMER onbatt 60
AT ONLINE * CANCEL-TIMER onbatt online
AT ONBATT * START-TIMER earlyshutdown 60
AT ONLINE * CANCEL-TIMER earlyshutdown online
AT LOWBATT * EXECUTE onbatt
AT COMMBAD * START-TIMER commbad 120
AT COMMOK * CANCEL-TIMER commbad commok
AT NOCOMM * EXECUTE commbad
Change the timings to your liking here.
- Create /etc/nut/upssched-cmd and make it executeable (
chmod +x)
#!/bin/sh
case $1 in
onbatt)
logger -t upssched-cmd "UPS running on battery"
earlyshutdown)
logger -t upssched-cmd "UPS on battery too long, early shutdown"
/usr/sbin/upsmon -c fsd
shutdowncritical)
logger -t upssched-cmd "UPS on battery critical, forced shutdown"
upsgone)
logger -t upssched-cmd "UPS has been gone too long, can't reach"
logger -t upssched-cmd "Unrecognized command: $1"
esac
- Profit
sudo systemctl restart nut-client restart the client after making all the changes.
You can then use sudo systemctl status nut-client to check the status.
Some remarks
Shutdown timer in TrueNAS should be long enough for the other server to have all timers passed and shutdown gracefully.
Make sure your UPS has enough power to supply both machines with energy until they are shutdown.
Test this setup before relying on it.
Try rebooting the server. Maybe not all services needed were restarted.
You could also kill power shortly and wait a few seconds while SSHing into the server to see whether you get a notification and see if it would work nonetheless.
I googled for that error and didn’t find a definite answer. Sorry I’m not of more help here.
Looks like those errors aren’t causing any issues, as i’ve tested everything and everything works as expected, the only thing i’m missing is maybe make it so when the power comes back, it wakes up my servers, if it’s even possible
That’s not something NUT does, AFAIK. It is something you can enable via the BIOS, however. For supermicro here is a description. Other OEMs will have different ways of auto-powering back on. It’s been working pretty flawlessly here.
