Issues installing Pihole and Unbound in Docker container on ElectricEel-24.10.1
Good afternoon everyone,
I recently upgraded to SCALE Electric Eel so I could try to install a few Docker containers, specifically for Pi-Hole and Unbound. I based my YAML file on the PiHole and Unbound config yaml by James Turland [JamesTurland/JimsGarage/Unbound on github] (made a few changes for truenas. See below). Whenever I try to install this, it spits out an error about an overlapping pool. I have no clue why this is happening. It is worth noting that I am using a dataset called “Docker” with the respective folders included in the YAML file already created. This dataset is owned by the admin user and group for the necessary permissions.
Here is the exact error from /var/log/app_lifecycle.log:
[2024/12/29 15:16:32] (ERROR) app_lifecycle.compose_action():56 - Failed 'up' action for 'pihole-unbound' app:  Network ix-pihole-unbound_dns_net  Creating
 Network ix-pihole-unbound_dns_net  Error
failed to create network ix-pihole-unbound_dns_net: Error response from daemon: invalid pool request: Pool overlaps with other one on this address space
Here is my edited YAML file:
networks:
  dns_net:
    driver: bridge
    ipam:
        - subnet: 172.16.0.0/24
  proxy:
    external: false
services:
  pihole:
    container_name: pihole
    hostname: pihole
    image: pihole/pihole:latest # remember to change this if you're using rpi
    networks:
      dns_net:
        ipv4_address: 172.16.0.5
      proxy:
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "8000:80/tcp"
    environment:
      TZ: 'America/New_York'
      WEBPASSWORD: 'password'
      PIHOLE_DNS_: '172.16.0.6#5053'
    volumes:
      - '/mnt/activeDirectory/Docker/pihole/etc-pihole/:/etc/pihole/'
      - '/mnt/activeDirectory/Docker/pihole/etc-dnsmasq.d/:/etc/dnsmasq.d/'
    restart: unless-stopped
  unbound:
    container_name: unbound
    image: mvance/unbound:latest # remember to change this if you're using rpi
    networks:
      dns_net:
        ipv4_address: 172.16.0.6
    volumes:
      - /mnt/activeDirectory/Docker/unbound:/opt/unbound/etc/unbound
    ports:
      - "5053:53/tcp"
      - "5053:53/udp"
    healthcheck:
      test: ["NONE"]
For the network config, I ran ip -a address in the TrueNAS shell to see that the docker network uses the 172.16.0.0/24 subnet. I am not using a proxy on my network (although I have plans to install NGINX sometime in the future).
I am still relatively new at this, so any help is appreciated. Thanks in advance.
I think since port 53 is in use by the systemd-resolver it gets blocked.
You can try to free up port 53 with these commands:
sudo systemctl disable systemd-resolved.service
sudo systemctl stop systemd-resolved
I ran those commands and got this output:
admin@truenas[~]$ sudo systemctl status systemd-resolved.service
[sudo] password for admin:
Unit systemd-resolved.service could not be found.
admin@truenas[~]$ sudo systemctl disable systemd-resolved.service
Failed to disable unit: Unit file systemd-resolved.service does not exist.
admin@truenas[~]$ sudo systemctl stop systemd-resolved
Failed to stop systemd-resolved.service: Unit systemd-resolved.service not loaded.
admin@truenas[~]$ systemctl --type=service --state=running
  UNIT                     LOAD   ACTIVE SUB     DESCRIPTION
  avahi-daemon.service     loaded active running Avahi mDNS/DNS-SD Stack
  certmonger.service       loaded active running Certificate monitoring and PKI enrollment
  chrony.service           loaded active running chrony, an NTP client/server
  containerd.service       loaded active running containerd container runtime
  cron.service             loaded active running Regular background program processing daemon
  dbus.service             loaded active running D-Bus System Message Bus
  docker.service           loaded active running Docker Application Container Engine
  getty@tty1.service       loaded active running Getty on tty1
  gssproxy.service         loaded active running GSSAPI Proxy Daemon
  libvirtd.service         loaded active running Virtualization daemon
  middlewared.service      loaded active running TrueNAS Middleware
  netdata.service          loaded active running netdata - Real-time performance monitoring
  nfs-blkmap.service       loaded active running pNFS block layout mapping daemon
  nginx.service            loaded active running A high performance web server and a reverse proxy server
  nmbd.service             loaded active running Samba NMB Daemon
  nscd.service             loaded active running Name Service Cache Daemon
  rpcbind.service          loaded active running RPC bind portmap service
  smartmontools.service    loaded active running Self Monitoring and Reporting Technology (SMART) Daemon
  smbd.service             loaded active running Samba SMB Daemon
  syslog-ng.service        loaded active running System Logger Daemon
  systemd-journald.service loaded active running Journal Service
  systemd-logind.service   loaded active running User Login Management
  systemd-machined.service loaded active running Virtual Machine and Container Registration Service
  systemd-udevd.service    loaded active running Rule-based Manager for Device Events and Files
  user@950.service         loaded active running User Manager for UID 950
  virtlogd.service         loaded active running Virtual machine log manager
  winbind.service          loaded active running Samba Winbind Daemon
  wsdd.service             loaded active running Web Services Dynamic Discovery host daemon
  zfs-zed.service          loaded active running ZFS Event Daemon (zed)
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
29 loaded units listed.
admin@truenas[~]$
I also ran systemctl --type=service --state=running after so you can see what all services are running.
Have some doubts about whether unbound will work within Truenas 24.10 because I think it doesn’t work in 24.04.2 and I could not make it work within the earlier Cobia version. Suggest you install PiHole first and be certain it’s functioning properly then attempt to add unbound on later, after all, the PiHole instructions for installing unbound assume there is already a working install of PiHole.
I removed all the parts from the YAML file referencing unbound, and I get the same error. The strange part is that when I remove the top network: section from the file, the container installs and deploys without errors, however I get a “403 Forbidden” error in my browser. I think this has something to do with the docker network driver, but when I change the default bridge driver to host, I get this error:
 Network ix-pihole_dns_net  Error
failed to create network ix-pihole_dns_net: Error response from daemon: only one instance of "host" network is allowed```
Any ideas? I'd really like to stick to docker for this instead if relying on the IX Applications catalog or another VM if possible.
Are you using /admin for reach PiHole GUI right?
I did forget about that part, and I tried it when I got the 403 forbidden message. That did get me to the admin interface for pihole. However, remember that I had to completely delete the network section of the yaml as seen below in order to get to the 403 forbidden message as seen in the exact yaml I used below:
services:
  pihole:
    hostname: pihole
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "8000:80/tcp"
    environment:
      PIHOLE_DNS_: '10.10.1.1'
    volumes:
This gives me the impression that something in the networking part of the yaml is what is causing the issue. Here are the networking parts of the yaml I deleted in the above script that worked:
networks:
  dns_net:
    driver: bridge
    ipam:
  #under services>pihole
    networks:
      dns_net:
        ipv4_address: 10.10.1.20
I don’t get any of the pool errors after I delete this.
My paths are in the yaml files above, and I’m pretty sure the ACLs are properly configured since it works sometimes.
Upon doing more research, I think the subnet of the docker container may have something to do with this. When I run ip -a address I get inet 172.16.0.1/24 brd 172.16.0.255 scope global docker0 for the internal docker network, hence the reason I used 172.16.0.0/24 in the yaml. I checked /etc/docker/daemon.jason out of curiosity, and the entry for address pools is as follows:
"default-address-pools": [{"base": "172.17.0.0/12", "size": 24}]}
Could this be causing my issues? If so, how can I fix it? I don’t want to mess anything up here, so any second opinions are greatly appreciated. And thanks for the help thus far.
If you can’t find a suitable network solution and the PiHole GUI is functional without including the network part of the script, then you might try leaving out that part and instead insert in the environment part:
INTERFACE: ‘the name of your truenas network interface’
For this to work “Permit All Origins” must be selected on the PiHole GUI’s DNS settings page.
Tried experimenting based on the evidence I had, and turns out I was on the right track. In the yaml file, I had to change the network subnet to subnet: 172.17.0.0/16 to match the line in /etc/docker/daemon.json. After changing this, the containers installed fine (both pihole on its own and the yaml config with both pihole and unbound), without any of the errors I previously encountered. Should have tried this sooner, but oh well. Thanks for the help, as ya’ll made the troubleshooting process a lot easier for me.
For future readers, set the subnet in your yaml file to be the same as the subnet listed in /etc/docker/daemon.json in the truenas CLI.That should fix this issue like it did for me.
Noob here, sorry if I’m misunderstanding something basic.
I’m building a TrueNAS 25.10.1 server from scratch, and I like the idea of building apps via Portainer stack method using Docker compose YAML files. I’m guessing matching Unbound with PiHole is exacly why this is useful, avoiding the more limited and less managed/updated TrueNAS native app selections. So, I installed Portainer via TrueNAS app, and I’m struggling to get any useful containers/stacks up and running.
I’ve tried copying the work done here, only changing the following from OP’s initial YAML file:
  • different TZ and WEBPASSWORD
  • environment>PIHOLE_DNS_: 10.20.0.77#5053 (saw that my router doesn’t like using some IPv4 addresses for DNS setting, this one works and looks familiar from other guides I’ve looked at)
  • unbound>networks>dns_net>ipv4_address: 10.20.0.77
  • volumes matched to datasets (all made with “app” preset) for
My YAML below:
networks:
  dns_net:
    driver: bridge
    ipam:
        - subnet: 172.17.0.0/12
  proxy:
    external: false
services:
  pihole:
    container_name: pi-hole
    hostname: pihole
    networks:
      dns_net:
        ipv4_address: 172.17.0.5
      proxy:
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "20080:80/tcp"
    environment:
      TZ: 'America/Chicago'
      PIHOLE_DNS_: '10.20.0.77#5053'
    volumes:
      - '/mnt/Shallow/AppData/Pi-Hole/:/etc/pihole/'
      - '/mnt/Shallow/AppData/Pi-Hole/dnsmasq/:/etc/dnsmasq.d/'
  unbound:
    networks:
      dns_net:
    volumes:
      - /mnt/Shallow/AppData/Unbound:/opt/unbound/etc/unbound
    ports:
      - "5053:53/tcp"
      - "5053:53/udp"
    healthcheck:
      test: ["NONE"]
I experienced the same “overlapping pool” error mentioned at the top of the post, where my daemon.json file lists 127.17.0.0/12 not 127.16.0.0/24. I tried matching this in my YAML, but instead of success reported by OP I got a new error:
Failed to deploy a stack: compose up operation failed: failed to create network pihole-unbound_dns_net: Error response from daemon: invalid network config: invalid subnet 172.17.0.0/12: it should be 172.16.0.0/12
For the heck of it I tried editing my .json file to 172.16.0.0/12 and matching in YAML, no dice as expected, same overlapping pool error.
What else can I try? Is there something outside of this YAML file I’m missing that needs to be done, like creating that network within Portainer GUI or something?
Hmmm, I’m still catching up on how subnets work, missed the fact that OP solved not by matching the /12 in daemon.json verbatim, but by using /16 instead. I discovered this by changing mine to /24 and using addresses inside that subnet for unbound and got it to build, no more errors!
However, for some reason now my password in the YAML file does not work in the admin web interface, very puzzling… Tried again with /16 subnet and same result, “wrong password” using the password I set with WEBPASSWORD variable. Seems like an odd new error, really got me scratching my head.
I’ll make a new post referencing this one if that’s better, was hoping this would be simpler but looks to be evolving into a different issue.
