I am encountering persistent issues when trying to run TrueNAS Scale inside a virtual machine (VM). TrueNAS Core, running on the same hypervisor, works without major issues (aside from occasional python3.9 core dumps), but TrueNAS Scale fails to boot properly. Below are the setup details, logs, and questions for the community.
Steps to Reproduce
- Create a new VM for TrueNAS Scale.
- Use default configurations (detailed below).
- Boot the VM.
Expected Result
The TrueNAS Scale VM boots successfully without errors.
Actual Result
The TrueNAS Scale VM fails to boot, with multiple errors, including:
- Middleware (
middlewared.service) failing to initialize. - Disk cache table and ZFS pool import issues (
ix-syndisks.serviceandix-zfs.service).
Environment
Hypervisor: Proxmox
TrueNAS Core VM Configuration:
- Memory: 16 GB
- CPUs: 8 cores
- BIOS: SeaBIOS
- Storage: VirtIO SCSI Disk (32 GB)
- Network: VirtIO
(Works fine apart from occasional core dumps.)
TrueNAS Scale VM Configuration:
- Memory: 8 GB
- CPUs: 8 cores
- BIOS: SeaBIOS
- Network: VirtIO
(Fails to boot with middleware and ZFS errors.)
Logs and Errors
- Middleware Error Logs:
File "/usr/bin/middlewared", line 33, in <module>
sys.exit(load_entry_point('middlewared==0.0.0', 'console_scripts', 'middlewared')())
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 2220, in main
).run()
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 2034, in run
self.loop.run_until_complete(self.__initialize())
File "/usr/lib/python3.11/asyncio/base_events.py", line 654, in run_until_complete
return future.result()
File "/usr/lib/python3/dist-packages/middlewared/schema/patch.py", line 24, in resolve
cp.attrs[name] = attr.copy()
AttributeError: 'tuple' object has no attribute '__dict__'
Service Failures:
middlewared.servicefails to initialize TrueNAS middleware.ix-syndisks.servicefails to sync the disk cache table.ix-zfs.servicefails to import ZFS pools.
Console Logs:
Failed to start middlewared.service - TrueNAS Middleware. Failed to import ZFS pools. See "systemctl status ix-zfs.service" for details.
Screenshots
Additional screenshots of the errors during the boot process:
Middleware Errors:
ZFS and Disk Cache Errors:
Troubleshooting Steps Taken
- Verified the ISO file integrity using the SHA256 checksum.
- Tested default VM configurations for TrueNAS Scale.
- Compared VM settings with TrueNAS Core, which works fine.
- Reviewed logs and ensured no apparent misconfiguration.
Questions for the Community
- Are there any known compatibility issues with TrueNAS Scale on Proxmox using VirtIO devices?
- Could the issues with TrueNAS Scale be related to the hypervisor or specific VM configurations (e.g., BIOS settings, machine type)?
- Are there recommended configurations for running TrueNAS Scale VMs?
- Would testing TrueNAS Scale on bare metal help isolate the issue?
- Full logs and screenshots of the errors.
- VM configuration details for both Core and Scale.
