Issues with importing TrueNAS pool after disk passthrough on Proxmox
Good evening, I’m trying to import the pools associated with my HDDs that were in my TrueNAS Core VM hosted on my Proxmox server. I did a disk passthrough of all my HDDs that I used to use in my old TrueNAS Scale, which was hosted on a desktop.
However, when I try to use Import Existing Pool, the pool dropdown is empty. When I go to the disks section, the attached disks are still listed.
I tried to repeat the disk passthrough steps again, but I got the same result. Then, I tried to do an HBA passthrough by adding the PCI Device, and I got the message “No IOMMU detected, please activate it. See Documentation for further information.” After further research, I found that my ASUS P8Z68-M PRO motherboard only supports VT-x and not VT-d. Getting a new motherboard is not an option.
Now, I’m facing two options here, and I’m looking for your help:
  1. Am I missing anything with the disk passthrough configuration?
  2. If I need to recreate the pools, is there an option where I can access the content of the disks to copy them out to avoid losing everything?
if you type zpool import in the shell, what do you see?
root@truenas[~]# zpool import
pool: ST6000DM003-2CY186
state: UNAVAIL
status: The pool was last accessed by another system.
action: The pool cannot be imported due to damaged devices or data.
see:
    ST6000DM003-2CY186  UNAVAIL  unsupported feature(s)
      vtbd1p2           ONLINE
pool: HUH728080ALE601
state: UNAVAIL
see:
    HUH728080ALE601  UNAVAIL  unsupported feature(s)
      vtbd4p2        ONLINE
pool: BINARIES
state: UNAVAIL
see:
    BINARIES    UNAVAIL  unsupported feature(s)
      vtbd3p2   ONLINE
pool: ST8000DM004-2U9188
state: UNAVAIL
see:
    ST8000DM004-2U9188  UNAVAIL  unsupported feature(s)
      vtbd5p2           ONLINE
pool: VIRTUALIZATION
state: UNAVAIL
see:
    VIRTUALIZATION  UNAVAIL  unsupported feature(s)
      vtbd2p2       ONLINE
pool: HUA723030ALA640
state: UNAVAIL
see:
    HUA723030ALA640  UNAVAIL  unsupported feature(s)
      vtbd6p2        ONLINE
I hope I am wrong, but I suspect that the way proxmox does a disc passthrough is not the same as a “real” hardware passthrough.
As you say your motherboard does not support vt-d.
I suspect its still a virtual disc. And ZFS really doesnt like virtual discs for data pools.
Can you recreate your exact old setup? With the drives exactly on the same sata ports ?
Again I hope i am wrong and there is some CLI-fu to import your pool.
So, you are trying to mount pools created with TrueNAS scale on a virtualized instance of TrueNAS core?
Also, it appears that you have a pool per disk. Is this correct?
Also, I believe you probably forgot to export the pools before decommissioning the other system, but this is not really a problem
Yes
Yes
Yes
Only if I delete proxmox and reinstall TrueNAS Scale on the same machine.
Which version of CORE are you trying to use?
It appears it doesn’t support the features that are in use/enabled on the pool.
Use Scale instead.
Having a single disk per pool… is well… strange. As you have no drive failure resiliency, and without setting copies=2, no bitrot protection either.
Normally, if you had a bunch of 8TB drives for example you’d combine them together using raidz1 or raidz2 in a pool.
TrueNAS-13.0-U6.1
I was just doing tests to learn about how to use TrueNAS
I think TrueNAS Core 13.3 Beta may support the pool features used by Scale.
Thank you @Stux, now I’m able to access my storage again!
