I’ve recently had issues with my pools being offline after in-place upgrade from Core to Scale. I’ve restored data from those disks using data recovery software and I’m now trying to build a new pool using those drives on a fresh Scale installation, but I’m encountering some issues.
When I create the pool from the GUI I get the following:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 560, in __run_body
rv = await self.method(*args)
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 287, in nf
rv = await func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 48, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 174, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/pool.py", line 582, in do_create
await self.middleware.call('pool.format_disks', job, disks, 0, 30)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 977, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 692, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 34, in format_disks
devname = await self.middleware.call('disk.gptid_from_part_type', disk, zfs_part_type)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 703, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 596, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/disk_info.py", line 173, in gptid_from_part_type
raise CallError(f'Partition type {part_type} not found on {disk}')
middlewared.service_exception.CallError: [EFAULT] Partition type 6a898cc3-1dd2-11b2-99a6-080020736631 not found on sda
I’ve already wiped the disks, zeroed them, etc.
This is what I’ve already done for both disks:
wipefs -a /dev/sda
sgdisk --zap-all /dev/sda
dd if=/dev/zero of=/dev/sda bs=1M count=100 status=progress
I can create the pool from the CLI, but then it’s not showing in the GUI.
It’s all very confusing to me.
I also have imported one of my non-mirrored pools, it’s also showing in the CLI, I can access the data via CLI, but still nothing in the GUI.
