I have two stack that I can not get operational on EE
Was previously running on DFish in jailmaker
Stacks are a monitoring stack
Prometheus
node-exporter
cadvisor
Grafana
graphite
and a full nextcloud AIO stack…
Based on the fact that these work in the other docker install
I am wondering if I have a kernel setting issue
fs.inotify.max_user_watches 4962130
or maybe
fs.inotify.max_user_instances 8000
Is there a possible setting in here that is causing the stacks to starve?
Both stacks load without anything in the log showing an issue and imply they are functional the web UI may work for a moment or so then just STOP working
I can also get the stack operational on another machine which is why I am assuming Truenas has a Kernalsetting that is starving them.
