Since moving from Dragonfish beta to full release, ive been getting a critical error stating cannot hadupdate?? It seems to clear itself several hours later, but given its flagged as critical id like to know what it is, and whether i should be finding a solution. Anyone else getting this since the april update?
Edit, nvm, solved second error, still not sure what a hadupdate is though
I believe HadUpdate is TrueNAS attempting to phone-home that its been updated.
If internet access is not functional at startup it can fail. but it retries every hour and should stop once it succeeds.
Oh geez, barely critical is it!! Havent IX heard of the boy that cried wolf haha anyways cheers for the help @Stux , its probably my dodge connection, getting fibre in few days so no worries
In my case it fails because I use a virtualized router, and the router hasn’t started up yet when the HadUpdate check is run the first time
Same for me (although in my case it’s a DoH Relay + PiHole so it can’t resolve the domain)… definitely doesn’t seem critical, maybe a delay should be put in on first-boot update checking to allow for this sort of use-case without freaking new users out .
Edit: OR! Perhaps lowering the severity of the non-critical critical alert
