I have upgraded my Truenas from 23.10.2 to 25.0.4. Now LDAP doesn’t work.
First, It complained that SSSD failed parsing the configuration. After removing map passwd loginShell loginShell from the auxiliary parameters, it went past that, but now the error message is:
File "/usr/lib/python3/dist-packages/middlewared/plugins/directoryservices_/kerberos_health_mixin.py", line 39, in _health_check_krb5
st = os.stat('/etc/krb5.conf')
FileNotFoundError: [Errno 2] No such file or directory: '/etc/krb5.conf'
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 560, in __run_body
rv = await self.method(*args)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 48, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 174, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 682, in do_update
await self.__start(job, ds_type)
File "/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py", line 981, in __start
await self.middleware.call('directoryservices.health.check')
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 977, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 703, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 596, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/directoryservices_/health.py", line 118, in check
self._health_check_ldap()
File "/usr/lib/python3/dist-packages/middlewared/plugins/directoryservices_/ldap_health_mixin.py", line 39, in _health_check_ldap
self._health_check_krb5()
File "/usr/lib/python3/dist-packages/middlewared/plugins/directoryservices_/kerberos_health_mixin.py", line 47, in _health_check_krb5
raise KRB5HealthError(
middlewared.utils.directoryservices.health.KRB5HealthError: Kerberos configuration file is missing. This may indicate the file was accidentally deleted by a user with admin shell access to the TrueNAS server.
I have no idea why this error happens, as I do have kerberos configured with my realm and all, and it was working before the upgrade.
Is there any solution for this?
