Looking to upgrade hardware
I a, currently running truenas core on an ancient HP N54L and it has been working fine for many many years.
It’s about time to upgrade as I need to add more drives.
I was co soldering using one of my old hp z800 workstations, but that is just as old as n54l.
My main issue is what motherboard and processor? I will be looking to run Truenas scale and will be using it for file storage and as a plex server. Additionally I will be looking to run a single, lightweight VM that will be used to back up then as to the cloud (currently idrive).
I will not be looking to do any config migration, but will start from scratch and copy data over from old to new.
The bits of the spec I know:
  • node 804 case
  • Support for a minimum of 6 SATA HDDs. I currently have 4 (I think) 3tb Wd reds, but looking to add more of larger capacity.
  • remote management (ipmi?)
  • M2 nvme slot. I am looking to use this for boot drive, although I do have a SATA ssd I could use for this, but would rather use this as a single storage drive.
Copilot/chatgpt has given a few suggestions, but each time I get a different answer. Also do I go AMD or an intel? For the lan, I would prefer intel, especially for the 2.5gb interface, but I can use a separate card for that.
I have been considering the ASRock Rack E3C246D4U motherboard with Intel Xeon E-2134, but is this now a bit old?
Thanks.
Coffee Lake should still be adequate for a NAS.
Skip 2.5G and go to 10G: E3C246D4U2-2T is available on eBay.
I’ll be sticking with 2.5g as I have upgraded in the last year. 10g copper switches were out of budget, especially where all/majority of ports are 10gb.
Before I start buying, what is the consensus on the following hardware?
  • Node 804 case
  • ASRock Rack E3C246D4 U2-2T motherboard
  • CRUCIAL 32 GB 3200 MHz DDR4 Memory Kit - 16 GB x 2
  • Thermaltake Toughpower GF A3 650W | Full Modular | 80Plus Gold Certified
    -Intel Xeon E-2276G SRF7M Six Core 3.80GHz Socket LGA1151 Processor CPU 80W
    -ARCTIC Freezer 34 eSports DUO CPU Cooler
Anything I have missed? Obviously there are cables and drives.
I have one of those. Not a big fan of the layout in the HDD areas, I found it to be rather cramped.
That goes for both the 8 HDD holders in the back compartment due to the sheer amount of cables being routed there and also for the two bays at the bottom where I had issues with them touching or almost touching the motherboard. The bottom bays also leave no room for cabling and you basically need to get properly angled L-shaped cables to fit anything there.
You can make it work, but if I had to choose between the Node 804 and my Define R5, I would pick the latter every day of the week.
Solid basis for a 8 drive NAS.
The additional drive positions in the motherboard compartment are a bit of a pain to populate, but the drive compartment is manageable with cable ties.
Mind that the case is not silent: Drive noise goes straight out through the top mesh.
The r5 define will be too big. Looking at the specs, it will be bigger than the 450mm depth I have. It’s about the same size as the z800 case and that will not fit there.
Thanks for the heads up though.
translated with deepl:
You can hear the noise of the hard disks in almost all enclosures. I currently have a Proliant MicroServer Gen8 with 4 hard disks. You can also hear them clicking.
I myself see the fan noise as more of a problem. Especially as the hard disks in the Node 8 are mounted in rubber sleeves. This should dampen the noise of the hard disks somewhat.
The drive bays of most enclosures do not have a noise damper.
I also bought the Fractal Node 8 for my new NAS. However, I will probably replace the Fractal fans with quieter models from noctua. Unfortunately, the Fractal fans do not support PWM, but they are supposed to be controlled by the motherboard (Supermicro).
Buy a used BrocadeICX 6450 or 7250, if in the U.S they were pretty cheap on Ebay not long ago.
With the Node 804, drives themselves are the issue. I know it: I own the case.
Fractal fans are not bad; you can bring in Noctuas, and more fans for more airflow, but the drives are noisier than the fans.
That’s because the case has a fan controller board where one can plug non-PWM fans to be controlled globally by one PWM cable to the motherboard.
With a Supermicro board, you’ll need to use a control script going through the BMC anyway.
Noise is not too much of an issue for me. My Poe switch has a noisy fan and my 2 3d printers make a bit of noise when printing. I often print when I am working in the same room.
If anyone has got recommendations for a better case no bigger than the 804, I will consider it.
The best small case out there is now unobtanium, the Lian-Li q26a or b. Up to ten drives in a decent sled configuration (especially with the backplanes), easily removed panels, great air flow, mini ITX motherboard but standard ATX PSU. Just freaking awesome.
Sadly, have not been made in 10 years or more.
Make sure it is ECC UDIMM memory. :wink:
Made sure of that. Ecc Ddr4 udimm seems a bit more difficult to come by nowadays, but have found some.
I have to come back to the subject of hard disk noise.
I have been using the NODE 804 for about 3 - 4 weeks now. However, only with 4 hard disks in the suspension. I have no problems with the noise of the hard disks. They are very quiet. I have to get very close to the case to hear them at all.
If you install the hard disks as described in the manual on page 21, you shouldn’t be surprised at the noise. The developers at Fractal have either deliberately broken the principle of structure-borne noise damping or they have simply been asleep.
The bottom screw eliminates the noise damping. This screw presses on the hard disk and on the metal rail. In other words: metal on metal without a rubber buffer.
Try to mount the hard disks according to the instructions on page 20. This means only 4 screws per hard disk instead of 6.
As for the noise from the top of the enclosure, you can cover the top of the frame with some paper as long as you don’t install a fan there. This should reduce the noise from the top.
By the way: The company Bicker (bicker.de) sells ATX power supplies from 350 to around 1,300 watts. Many of these power supplies are designed for continuous operation (24/7) and often for an extended temperature range (-10 - +70°)
Translated with DeepL.com (free version)
This is actually quite intelligent, the use cases for 10g at home is very limited. The 10g hype from utube these days is quite entertaining.
I personally do not use 2.5gb, it would be ok for me but I could never find a switch that fits my needs. Gigabit is perfectly fine for me and I cannot see that changing anytime soon.
That is a fascinating collection of power supplies.
They even have ATX frame PSUs with DC power inputs. I’m not sure I would highlight the DC PSU efficiency at 80+%, however?
But they also offer the first medical grade ATX PSUs I’ve ever seen. Few OEMs are willing to go through that kind of trouble / liability.
Very cool link, thank you!
That is your use case and I am psyched for you that it meets your needs. Other people want something faster. For example, the folk who want to do photo / video editing with all storage on one machine.
The main appeal of all the 10GbE gear finally coming down in price is that 10GbE has come into reach of far more consumers. Switches, NICs, etc. now cost a lot less than in the past.
I’m still a fan of fiber based 10GbE though thanks to its lower transceiver cost, better EMI resistance, usually lower power requirements (though some modern copper transceivers are reportedly getting better).
The main downside of copper at 2.5+GbE is the alleged fragility to maintain signal integrity - ie allegedly CAT5e+ cables are needed, they cannot be longer than Y distance, etc. In practice, I am running 2.5GbE on CAT3 for over 200’.
But to each his or her own. Gigabit is plenty fast for most applications, inexpensive to install / set up, and easy to terminate.
deleted
