Low-cost & low-power DIY NAS build: What would you spec for an efficient 6-drive pool?
And the common reason… if you decide to run a VM, you probably want to give it two cores for the same reason, ie two cores means a VM can actually do two things at once.
You have 4 threads.
If you run another VM, then another minimum of two cores…
So, that’s why you may want more than 2 cores. it comes down to if you want to run VMs (or even have the ability to run VMs)
OR if you are planning some heavy apps.
These AsRock Rack/Datto boards, and often complete, have been available on eBay for a long time. They are very suitable as NAS, with only one drawback: Java-only IMPI.
Totally agree re cores for VMs - that’s what I wanted to to do re: blue iris in windows. IIRC, I gave it four cores or whatever the maximum is and my ’CPU meter’ in BlueIris remained pegged 100% of the time. Maybe blue iris is not particularly multi threaded and hence core count makes less of a difference than core speed?
Who knows.
I may have a go with plex on my core machine and that will hopefully run better.
I ended up getting the X10SDV-7TP4F board (non -2C-). I’m waiting on some RAM and SAS breakout cables but am excited to move over to this “new” platform.
Thanks everyone for sharing your advice!
Don’t forget to add a fan to the cpu and hba heat sinks if not using server style airflow.
Thanks for the reminder! The seller hooked me up with some noctua fans and zipties to keep things under control :+1:
Really informative thread with great board searching. Would love to see more hardware discussions like this at various idle power consumption levels.
I’d love that dual 25gbe board for a OPNSense router lol but seems pretty dang expensive.
See my signature, I use the X10SDV-7TP4F in a Lian Li A76 case. Zero issues with heat but I upgraded most fans to Noctua PWM industrial fans. For a bit of a visual journey through all the modifications, see here.
I also added a fan to the CPU, along with a copper heat sink (CoolJag BUF-A series, IIRC). Removing the stock heat sink was a bit of a journey. Then I added a very small dedicated fan to the HBA heat sink. A few more fans to push air in and out of the case.
Lastly, I added @Stux’ excellent fan script that takes advantage of the dual zone fan functionality of the motherboard to limit hard drive temperatures to 30* C. The fans loaf 99% of the time at a much lower RPM, which lowers noise and power consumption.
