LSI 9400-16i Help
Hello Guys,
Just setup my TrueNAS machine to do some disks test. I had a 9400-1i laying (purchased earlier) and i updated the firmware back then. Here’s what i can see at the moment. I’m not sure which profile was flashed as it comes in SAS_SATA and NVMe Mixed version. Secondly, i’m not sure if it is running in IT mode.
[~]# storcli show
CLI Version = 007.1207.0000.0000 Sep 25, 2019
Operating system = FreeBSD 13.1-RELEASE-p9
Status Code = 0
Status = Success
Description = None
Number of Controllers = 1
Host Name = CoreStorage.local
Operating System  = FreeBSD 13.1-RELEASE-p9
StoreLib IT Version = 07.1300.0200.0000
IT System Overview :
Ctl Model        AdapterType   VendId DevId SubVendId SubDevId PCI Address
  0 HBA 9400-16i   SAS3416(B0) 0x1000  0xAC    0x1000   0x3000 00:01:00:00
[~]# storcli /c0 show
Controller = 0
Status = Success
Description = None
Product Name = HBA 9400-16i
Serial Number = SP7XXXXXX
SAS Address =  500ZZZZZZZZZZ
PCI Address = 00:01:00:00
System Time = 04/26/2026 08:55:09
FW Package Build = 24.00.00.00
FW Version = 24.00.00.00
BIOS Version = 09.47.00.00_24.00.00.00
NVDATA Version = 24.00.00.22
PSOC Version = 05689001
Driver Name = mpr
Driver Version = 23.00.00.00
Bus Number = 1
Device Number = 0
Function Number = 0
Vendor Id = 0x1000
Device Id = 0xAC
SubVendor Id = 0x1000
SubDevice Id = 0x3000
Board Name = HBA 9400-16i
Board Assembly = 03-50008-15003
Board Tracer Number = SP7XXXXXX
Physical Drives = 4
PD LIST :
EID:Slt DID State DG      Size Intf Med SED PI SeSz Model                Sp
0:0       1 JBOD  -  14.551 TB SATA HDD N   N  512B ST16000NM000J-2TW103 U
0:1       2 JBOD  -  14.551 TB SATA HDD N   N  512B ST16000NM000J-2TW103 U
0:2       3 JBOD  -  14.551 TB SATA HDD N   N  512B ST16000NM000J-2TW103 U
0:3       4 JBOD  -  14.551 TB SATA HDD N   N  512B ST16000NM000J-2TW103 U
EID-Enclosure Device ID|Slt-Slot No.|DID-Device ID|DG-DriveGroup
UGood-Unconfigured Good|UBad-Unconfigured Bad|Intf-Interface
Med-Media Type|SED-Self Encryptive Drive|PI-Protection Info
SeSz-Sector Size|Sp-Spun|U-Up|D-Down|T-Transition
Requested Boot Drive = Not Set
# storcli /c0 show all
Controller = 0
Status = Success
Description = None
Basics :
Controller = 0
Adapter Type =   SAS3416(B0)
Model = HBA 9400-16i
Serial Number = SPXXXXXX
Current System Date/time = 04/26/2026 09:26:01
Concurrent commands supported = 6656
SAS Address =  500605b00d4b1930
Mfg Date = 00/00/00
Rework Date = 00/00/00
Revision No = N/A
Version :
Firmware Package Build = 24.00.00.00
Firmware Version = 24.00.00.00
Bios Version = 09.47.00.00_24.00.00.00
Driver Name = mpr
PCI Version :
Vendor Id = 0x1000
Device Id = 0xAC
Host Interface = PCIE
Device Interface = SAS-12G
Bus Number = 1
Device Number = 0
Function Number = 0
Pending Images in Flash :
Image name = No pending images
Status :
Controller Status = OK
Memory Correctable Errors = 0
Memory Uncorrectable Errors = 0
Bios was not detected during boot = No
Controller has booted into safe mode = No
Supported Adapter Operations :
Alarm Control = No
Cluster Support = No
Self Diagnostic = No
Deny SCSI Passthrough = No
Deny SMP Passthrough = No
Deny STP Passthrough = No
Support more than 8 Phys = Yes
FW and Event Time in GMT = No
Support Enclosure Enumeration = Yes
Support Allowed Operations = Yes
Support Multipath = Yes
Support Security = No
Support Config Page Model = No
Support the OCE without adding drives = No
support EKM = No
Snapshot Enabled = No
Support PFK = No
Support PI = No
Support Shield State = No
Support Set Link Speed = No
Support JBOD = No
Disable Online PFK Change = No
Real Time Scheduler = No
Support Reset Now = No
Support Emulated Drives = No
HwCfg :
ChipRevision =  B0
BatteryFRU = N/A
Front End Port Count = 1
Backend Port Count = 21
Serial Debugger = Absent
NVRAM Size = 0KB
Flash Size = 16MB
On Board Memory Size = 0MB
On Board Expander = Absent
Temperature Sensor for ROC = Present
Temperature Sensor for Controller = Absent
Current Size of CacheCade (GB) = 0
Current Size of FW Cache (MB) = 0
ROC temperature(Degree Celcius) = 49
Policies :
Policies Table :
Policy                          Current Default
Predictive Fail Poll Interval   0 sec
Interrupt Throttle Active Count 0
Interrupt Throttle Completion   0 us
Rebuild Rate                    0 %     30%
PR Rate                         0 %     30%
BGI Rate                        0 %     30%
Check Consistency Rate          0 %     30%
Reconstruction Rate             0 %     30%
Cache Flush Interval            0s
Flush Time(Default) = 4s
Drive Coercion Mode = none
Auto Rebuild = Off
Battery Warning = Off
ECC Bucket Size = 0
ECC Bucket Leak Rate (hrs) = 0
Restore HotSpare on Insertion = Off
Expose Enclosure Devices = Off
Maintain PD Fail History = Off
Reorder Host Requests = On
Auto detect BackPlane = SGPIO/i2c SEP
Load Balance Mode = None
Security Key Assigned = Off
Disable Online Controller Reset = Off
Use drive activity for locate = Off
Boot :
Max Drives to Spinup at One Time = 0
Maximum number of direct attached drives to spin up in 1 min = 0
Delay Among Spinup Groups (sec) = 0
Allow Boot with Preserved Cache = On
Defaults :
Phy Polarity = 0
Phy PolaritySplit = 0
Cached IO = Off
Default spin down time (mins) = 0
Coercion Mode = None
ZCR Config = Unknown
Max Chained Enclosures = 0
Direct PD Mapping = No
Restore Hot Spare on Insertion = No
Expose Enclosure Devices = No
Maintain PD Fail History = No
Zero Based Enclosure Enumeration = No
Disable Puncturing = No
Un-Certified Hard Disk Drives = Block
SMART Mode = Mode 6
Enable LED Header = No
LED Show Drive Activity = No
Dirty LED Shows Drive Activity = No
EnableCrashDump = No
Disable Online Controller Reset = No
Treat Single span R1E as R10 = No
Power Saving option = Enable
TTY Log In Flash = No
Auto Enhanced Import = No
Enable Shield State = No
Time taken to detect CME = 60 sec
Capabilities :
Supported Drives = SAS, SATA
Enable JBOD = Yes
Max Parallel Commands = 6656
Max SGE Count = 128
Max Data Transfer Size = 32 sectors
Max Strips PerIO = 0
Max Configurable CacheCade Size = 0
Min Strip Size = 512Bytes
Max Strip Size = 512Bytes
Scheduled Tasks = NA
Enclosure Information :
EID State Slots PD PS Fans TSs Alms SIM ProdID     VendorSpecific
  0 OK       16  4  0    0   0    0   0 VirtualSES
Physical Device Information :
Drive /c0/e0/s0 :
Drive /c0/e0/s0 - Detailed Information :
Drive /c0/e0/s0 State :
Shield Counter = 0
Media Error Count = 0
Other Error Count = 0
Predictive Failure Count = 0
S.M.A.R.T alert flagged by drive = No
Drive /c0/e0/s0 Device attributes :
Manufacturer Id = ATA
Model Number = ST16000NM000J-2TW103
NAND Vendor = NA
SN =
WWN =
Firmware Revision = SN04
Raw size = 14.551 TB [0x746bfffff Sectors]
Coerced size = 14.551 TB [0x746bfffff Sectors]
Non Coerced size = 14.551 TB [0x746bfffff Sectors]
Device Speed = Unknown
Link Speed = 6.0Gb/s
NCQ setting = N/A
Sector Size = 512B
Config ID = NA
Number of Blocks = 31251759103
Drive /c0/e0/s0 Policies/Settings :
Enclosure position = 0
Connected Port Number = 0(path0)
Sequence Number = 0
Commissioned Spare = No
Emergency Spare = No
Last Predictive Failure Event Sequence Number = 0
Successful diagnostics completion on = N/A
SED Capable = No
SED Enabled = No
Secured = No
Needs EKM Attention = No
PI Eligible = No
Certified = Yes
Wide Port Capable = No
Port Information :
Port Status Linkspeed SAS address
   0 Active 6.0Gb/s   0xZZZZZZZZ
Inquiry Data =
5a 0c
Drive /c0/e0/s1 :
Drive /c0/e0/s1 - Detailed Information :
Drive /c0/e0/s1 State :
Shield Counter = 0
Drive /c0/e0/s1 Device attributes :
NAND Vendor = NA
SN =
WWN =
NCQ setting = N/A
Sector Size = 512B
Config ID = NA
Drive /c0/e0/s1 Policies/Settings :
Sequence Number = 0
SED Capable = No
SED Enabled = No
Secured = No
PI Eligible = No
Certified = Yes
Port Information :
Inquiry Data =
5a 0c
Drive /c0/e0/s2 :
Drive /c0/e0/s2 - Detailed Information :
Drive /c0/e0/s2 State :
Shield Counter = 0
Drive /c0/e0/s2 Device attributes :
NAND Vendor = NA
SN =
WWN =
NCQ setting = N/A
Sector Size = 512B
Config ID = NA
Drive /c0/e0/s2 Policies/Settings :
Sequence Number = 0
SED Capable = No
SED Enabled = No
Secured = No
PI Eligible = No
Certified = Yes
Port Information :
Inquiry Data =
5a 0c
Drive /c0/e0/s3 :
Drive /c0/e0/s3 - Detailed Information :
Drive /c0/e0/s3 State :
Shield Counter = 0
Drive /c0/e0/s3 Device attributes :
NAND Vendor = NA
SN =
WWN =
NCQ setting = N/A
Sector Size = 512B
Config ID = NA
Drive /c0/e0/s3 Policies/Settings :
Sequence Number = 0
SED Capable = No
SED Enabled = No
Secured = No
PI Eligible = No
Certified = Yes
Port Information :
Inquiry Data =
5a 0c
[~]# storcli /c0 show personality
Controller = 0
Status = Failure
Description = Un-supported Command
Not sure if the JBOD is normal in this case. Also, is 49c a normal temperature or my HBA is overheating? I had a fan laying around so i put on it. Not sure if it helps any. Any help would be appreciated. Thank you
Given that the usual test is a finger test (when I press my finger against the LSI chipset, do I go Ow) I would suggest that 49 is OK
Feels normal. Neither too hot neither too cold to touch. Of course, the fins, did not touched the PCB.
If not mistaken it is in IR mode
If it is a LSI 9400-16i, would it even have an IR mode? That model number should be a ‘plain’ HBA but I am not familiar with the newer StorCLI software nor the results it returns compared to sas2flash and sas3flash.
The reality is you have to go over the documentation for that card and the software, StorCLI. It’s a bit confusing since they use the same for “MegaRAID” or refer to the newer series as such.
Was going off of the past:
As per my check, the LSI 9400-16i has only IT firmware available from Broadcom.
