@ericloewe
Half of the bandwidth, not half the drives? So it will still handle 16 drives, but slower… Hmmm… I can live with that. Thank you!
Next question… Since the card has 4 ports, can I mix the attached drives?
Meaning, with the right cables, can I connect both SAS and SATA drives? (I am thinking about a fast pool with SSDs and a larger pool with HDDs.)
The card has four connectors, I wouldn’t call them ports per se since they’re four individual lanes each, which can be used independently. And yes, you can mix SATA and SAS drives.
“Fast” is going to be relative when you only have four lanes of PCIe 3.0 for the whole controller, which is the same as a single typical NVMe SSD (and easily saturated by many these days).
