MakeMKV in TrueNas scale permission denied when changing output location
I am a total noob to TrueNas…
I have encountered many bumps along the way but I have resolved them all except this one. I have a truenas build ElectricEel-24.10.2.1 , I also installed Jellyfin and it works on my TV and phone. I installed MakeMKV and was able to rip a bluray. Here are my issues, 1. I cant see where MakeMKV ripped movie ended up at. 2. I am trying to change the output folder to the movies folder for Jellyfin. Here is where I encountered this issue I just cant figure out.
here is the config for MakeMKV in Truenas
services:
makemkv:
devices:
- /dev/sr0:/dev/sr0
- /dev/sg1:/dev/sg1
- /dev/sg2:/dev/sg2
- /dev/sg3:/dev/sg3
- /dev/sg4:/dev/sg4
- /dev/sg5:/dev/sg5
- /dev/sg6:/dev/sg6
- /dev/sg7:/dev/sg7
- /dev/sg8:/dev/sg8
environment:
- MAKEMKV_KEY=BETA
- DARK_MODE=1
- USER_ID=1000
- GROUP_ID=1000
image: jlesage/makemkv
ports:
- ‘5800:5800’
volumes:
- /mnt/pool/makemkv:/config:rw
- /mnt/pool/makemkv:/storage:rw
- /mnt/pool/Jellyfinsmbshare/Movies:/Movies:rw
version: ‘3’
and here is the error code
Error ‘Posix error - Permission denied’ Occurred when creating '/Movies/B1_t00.mkv
Does your target have the permissions/ACLs set to allow user 1000 to write there?
If not either add those permissions or change UID/GID to a user that has permissions on those folders. If jellyfin is working fine the apps user 568 probably has the right permissions.
