Since Truenas did NOT support matrix as a native app as of yet, I attempted to go with this solution.
I also wanted to make sure I could touch the files, so I mounted all the volumes on directories in my smb share: /mnt/poolname/smbsharename (ofc this isn’t how it’s really named. will not disclose for privacy reasons)
I also used my personal domain: domain.com (not how my domain is named either. will not disclose for privacy reasons)
Docker-compose script
version: '3'
services:
# Synapse host for your Matrix instance
synapse:
image: matrixdotorg/synapse:latest
restart: always
volumes:
- /mnt/poolname/smbsharename/Docker/synapse/files/data:/data
- /mnt/poolname/smbsharename/Docker/synapse/files/homeserver.yaml:/data/homeserver.yaml
- /mnt/poolname/smbsharename/Docker/synapse/files/secrets/:/synapse-secrets/
- /mnt/poolname/smbsharename/Docker/synapse/files/letsencrypt:/etc/letsencrypt
- /mnt/poolname/smbsharename/Docker/synapse/files/nginx-proxy-manager/.well-known/matrix:/var/www/matrix.white.fm/.well-known/matrix
environment:
- SYNAPSE_SERVER_NAME=domain.com
- SYNAPSE_REPORT_STATS=yes
- SYNAPSE_NO_TLS=true
- SYNAPSE_DB_HOST=postgres
- SYNAPSE_DB_NAME=synapse
- SYNAPSE_DB_USER=synapse_user
- SYNAPSE_DB_PASSWORD=16digitpasswords
- SYNAPSE_ADMIN_USER=admin
- SYNAPSE_ADMIN_PASS=$$(cat /synapse-secrets/matrix_admin_pass.txt)
ports:
- "8008:8008"
- "8448:8448"
labels:
- 'nginx.enable=true'
- 'nginx.http.routers.matrix.rule=Host(`domain.com`)'
- 'nginx.http.routers.matrix.tls=true'
- 'nginx.http.services.matrix.loadbalancer.server.port=8008'
# Postgres DB host for your Matrix instance
postgres:
image: postgres
restart: always
environment:
POSTGRES_PASSWORD: 16digitpasswords
POSTGRES_USER: synapse_user
POSTGRES_DB: synapse
POSTGRES_INITDB_ARGS: "--encoding=UTF8 --lc-collate=C --lc-ctype=C"
volumes:
- /mnt/poolname/smbsharename/Docker/synapse/files/secrets/postgresmatrix:/var/lib/postgresql/data
# Redis host for your Matrix instance
redis:
image: redis
container_name: redis
restart: always
# Nginx Proxy Manager
# app:
# image: 'jc21/nginx-proxy-manager:latest'
# restart: unless-stopped
# ports:
# - '80:80'
# - '81:81'
# - '443:443'
# environment:
# DB_MYSQL_HOST: "db"
# DB_MYSQL_PORT: 3306
# DB_MYSQL_USER: "npm"
# DB_MYSQL_PASSWORD: "npm"
# DB_MYSQL_NAME: "npm"
# volumes:
# - ./data:/data
# - ./letsencrypt:/etc/letsencrypt
# - ./nginx-proxy-manager/.well-known/matrix:/var/www/matrix.white.fm/.well-known/matrix
# the database for your NPM instance
# db:
# image: 'jc21/mariadb-aria:latest'
# environment:
# MYSQL_ROOT_PASSWORD: 'npm'
# MYSQL_DATABASE: 'npm'
# MYSQL_USER: 'npm'
# MYSQL_PASSWORD: 'npm'
# volumes:
# - ./data/mysql:/var/lib/mysql
# The chat interface for your Matrix instance
element:
image: vectorim/element-web:latest
volumes:
- /mnt/poolname/smbsharename/Docker/synapse/files/element-config.json:/app/config.json
ports:
- "8080:80"
# Maubot (https://github.com/maubot/maubot)
# maubot:
# image: 'dock.mau.dev/maubot/maubot:latest'
# ports:
# - '29316:29316'
# volumes:
# - './maubot:/data:z'
# This container is the database for Maubot
# postgres-maubot:
# image: 'postgres:latest'
# ports:
# - 5432:5432
# environment:
# POSTGRES_USER: postgres # The PostgreSQL user (useful to connect to the database)
# POSTGRES_PASSWORD: KMeEqPH4rLvHeel9 # The PostgreSQL password (useful to connect to the database)
# POSTGRES_DB: postgres # The PostgreSQL default database (automatically created at first launch)
# Use this container as an SMTP relay routing through Google yes
postfix:
# follow the instructions for using Google's SMTP relay here: https://apps.google.com/supportwidget/articlehome?hl=en&article_url=https%3A%2F%2Fsupport.google.com%2Fa%2Fanswer%2F2956491%3Fhl%3Den&assistant_id=generic-unu&product_context=2956491&product_name=UnuFlow&trigger_context=a
image: juanluisbaptiste/postfix:alpine
container_name: postfix
expose:
- 25
environment:
SMTP_SERVER: smtp-relay.gmail.com
SMTP_PORT: 587
SMTP_USERNAME: randomusername@domain.com
SMTP_PASSWORD: other16digitpasswords
SERVER_HOSTNAME: domain.com
#Use this container as a webhook relay to send encrypted webhook messages to your server
# webhooks:
# depends_on:
# - synapse
# environment:
# ALLOW_UNICODE: 'True'
# DISPLAY_APP_NAME: 'True'
# KNOWN_TOKENS: 'EXAMPLETOKEN,!roomID:YOURSERVERNAME.COM,NetworkNotifications'
# MATRIX_ADMIN_ROOM: '!adminRoomID:YOURSERVERNAME.COM'
# MATRIX_DEVICE: matrix-ubuntu-docker
# MATRIX_PASSWORD: 'YOURSUPERSECRETPASSWORD'
# MATRIX_SERVER: https://matrix.YOURDOMAIN.COM
# MATRIX_SSLVERIFY: 'True'
# MATRIX_USERID: '@webhooks:YOURDOMAIN.COM'
# MESSAGE_FORMAT: yaml
# USE_MARKDOWN: 'True'
# image: jceloria/matrix-encrypted-webhooks:latest
# ports:
# - 8000:8000
# volumes:
# - /opt/data/matrix/webhooks/config:/webhooks-config
The guide also mentioned that I should download and edit these other files in the github .
So I edited the homserver.yaml, element-config.json, and the files in the secrets folder, then put them in the directories listed above in the volumes for my synapse install.
edited parts of the homeserver.yaml script
# This homeserver.yaml works in my environment with Docker Compose, but you may need to make adjustments for your particular environmnet.
modules:
server_name: "domain.com"
web_client_location: https://element.domain.com/
public_baseurl: https://matrix.domain.com/
edited parts of the element-config.json script
"default_server_config": {
"m.homeserver": {
"base_url": "https://element.domain.com",
"server_name": "domain.com"
synapse_secrets.env
SYNAPSE_ADMIN_PASS=$$(cat /secrets/matrix_admin_pass.txt)
complicated16digitpassword
When I tried to run it, redis, element, and postfix ran with no problems. However, both the postgres and synapse would not start. Am I missing something here?
