I am trying to run this as a custom container via the example yaml they provide:
The app is running, and the rear jack microphone device is detecting and selectable but no sound is coming through.
I’ve tried setting it as privileged and it didnt help.
Setting up a basic instance linux VM, passing the sound device to the VM and running the container inside that works fine and the audio comes through as expected.
Has anyone got any mic devices passing into a container successfully?
Thanks, I hadn’t seen that yet, unfortunately I gave it a try and no luck.
For now I’ve settled with running a little VM/Instance that has the mic attached and runs a little rtsp stream of the mic audio to the container, since at least that way I can still run it under apps and can back everything up easily compared to all running inside the instance.
