Migration CORE->SCALE: General Question
Hi folks
I’m running TrueNAS/FreeNAS for more than 10 years now and it seems that the FreeBSD based CORE seems to reach eol in the near future :smiling_face_with_tear:
My use case is mostly private for a single user, I’m running a 3 drives ZFS pool on a quite old machine und I’m using this for timemachine backups, archiving some music, photos, movies and other private stuff and a nextcloud instance running in a jail based on GitHub - samuel-emrys-blogs/freebsd-nextcloud-setup-hardened: How to install Nextcloud on FreeNAS in an iocage jail with hardened security
So my questions are
  • Can I just use the same ZFS pool on SCALE without copying the data and rebuilding the pool? I have a backup, but I don’t want to loose my ZFS snapshot history.
  • I assume that jails are not supported anymore, and the new way is to use a kind of containers. Is this docker or podman based?
  • Is there a guide or other documentation for migrating jails to the new world?
  • Is there an official way to use nextcloud on TrueNAS Scale?
  • My current server is about 15 years old, it has 12GB ram and cpu info from boot says
CPU: Intel(R) Core(TM) i5 CPU         750  @ 2.67GHz (2660.00-MHz K8-class CPU)
and
  Features2=0x98e3fd<SSE3,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,POPCNT>
  AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
Is this still sufficient? Can I use docker with this CPU or should I think about buying new hardware?
Hi, i was wondering about the same idea… But for the moment say that core is eol is a bit much. I think we can stay good for at least another year… Hope more!
1: assuming that have a backup is always better, you can import pool from core to scale
2: jail are not supported, but you can always install the same app in a docker restoring backup as supported by the specific app
3: is related to the specific app of the jail, i dont think exist something “generic”
4: dont know but for sure, maybe in nextcloud doc
5: i think u will need at least a RAM upgrade, 12 are a bit low for core too
This is my guide to the jails system on scale
Personally, I migrated my services into docker compose in a vm on core. Then that vm migrated easily to scale.
Then I migrated those docker compose stacks to a sandbox/jail
Scale can mount your pool. And the migration is pretty good.
In my experience scale has less ram needs than core.
Based on my experience changing from CORE to SCALE:
  1. Your pools should be fine, and show up in SCALE. No need to copy/rebuild.
  2. As I see it, there are two things in SCALE that replace jails/plugins.
    a) As others have noted, there is a Sandbox/Jailmaker solution. It’s very much a roll-your-own thing. You’ll find instructions for setting up a Jailmaker jail, but then you’re on your own, depending on what you want to put in it. Not being a video learner, I suggest you start here. That will get you started, then link you to the jailmaker github page for further info.
    b) Apps. This is where you can set up prepackaged Apps with their options, in some kind of container/pod. To me, the App system is kind of a minefield, lots of stuff out there but documentation is poor to nonexistent. I’ve gotten what I need to work eventually, after much wailing and gnashing of teeth.
  3. You can’t migrate jails to SCALE, just set up new stuff to replace them as noted above.
  4. There are at least two NextCloud Apps. One is in the TrueNAS catalog and one in the Truecharts catalog, premium train.
  5. I saw somewhere that SCALE is less demanding of hardware than CORE, but maybe others can comment on suitability of your hardware.
Thanks for the answers so far.
I can remember that I could not use bhyve on my current machine some years ago, due to missing cpu features but I cannot remember any details .
Migrated my test CORE system to Scale today.
Did it through the GUI and it took about 30 minutes with a few reboots on its own.
Everything that could migrate, did without any shell work.
Network, which I have a lagg setup migrated fine. Pools showed up and my rsync from another truenas Core instance is still connected and runs.
TrueCommand didnt even notice the change other than displaying the new OS.
Ill wait on apps as there seems to be some changes on the horizon but as a NAS the migration went perfect!
Migrated my second system from core to scale. Again used gui and update went well, except this time I had to do a manual restart of the server. All shares back online with no issues. I did have my rsync jobs fail. This was odd because my test system also had rsync tasks that worked. Both were rsync tasks to the same primary turenas Core system. The difference was the second system as set up from the primary core as a push. I switched it to pull on scale from core system and all works fine now.
So I think its time to try the migration, i will upgrade my hardware from 12GB RAM to 16GB, the truenas migration itself should be quite forward fter reading some documentation and tutorials.
Stil wondering about my NextCloud jail.
It is worth a try “migrating” to the docker based stuff, so reusing the mariadb base database, maybe by restoring from frn DB abckup or export etc.
Or should I start from scratch, creating a new nextcloud instance and just copy the data over. Its is more a less a single user system, with full text search bases on elasticsearch enabled.
I finally migrated from TrueNAS Core to the latest Scale. It went quite smoothly. I did a fresh install and then imported my old configuration.
I ran into some issues with my network configuration because the Ethernet device name changed, but it was an easy fix.
Of course, I lost my jails, but I already have some Docker apps running, including a custom caddy app acting as a reverse proxy.
I’m still using a USB stick as a boot device and have noticed that it is much slower than it was with TrueNAS Core. I’ll replace this with the smallest and cheapest SSD available. :wink:
Yep, replace it soon as possible because Scale will literally destroy this USB stick.
If you lack free SATA port, you can also consider to use small SSD with USB-SATA adapter, or USB-NVME adapter with a ultra cheap 16gb NVME Optane/pseudo Optane.
M10 drives are genuine Optane. At 16 GB it’s just the smallest possible package because it was intended to serve as fast cache for a HDD in tiered storage.
Fine boot device for CORE. For SCALE/CE there is (or was?) the consideration that a swap partition would be created on >64 GB boot devices, so maybe 100+ GB is desirable here.
When you buy stuff on Aliexpress, you can’t be sure of anything :smile: Mine is working well (just reached 10k hours of usage), so legit or not to me make no difference. Btw, theyr price is increased (from 3~4€ to 6~7€ each :triumph: ).
About swap.. they didn’t remove it at all from Scale?
Even at 7€ a pop, it would not be worth trying to make a convincing lookalike so you can be quite confident that it’s the real thing, massively off-loaded from wharehouses after discontinuation.
As for swap on Linux, I think I remember there was a U-turn on the U-turn and one optional swap partition on the boot device was put back to offset the removal of the 2 GB swap/buffer on pool drives but I’m unsure whether it’s still current or I skipped a U-turn on the U-turn on the U-turn… :face_with_spiral_eyes:
totally legit
ahahah
is quite a long time i don’t make a fresh install, if i well remember was at EEL release… i vaguely remember that maybe installer ask you something about that but i don’t remember the “minimum size” requirement, i always used very small SSD (the biggest was 64gb), atm no swap is present in my boot pool
nvme0n1     INTEL MEMPEK1J016GAL       gpt    disk           14403239936
├─nvme0n1p1                            gpt    part    4096       1048576 BIOS boot
├─nvme0n1p2                            gpt    part    6144     536870912 EFI System
└─nvme0n1p3                            gpt    part 1054720   13863206400 Solaris /usr & Apple ZFS
(instead i have a ~2gb FreeBSD swap partition in every other disks, god bless CORE :smile: )
With respect to pool disks, the current behavior is to create a data partition of $disksize - 2 GB. When replacing a drive, the data partition is the same size, and if that 2 GB of slop space is needed, it’s used. So it’s similar to the old behavior, but without the swap partitions–just a data partition that doesn’t quite fill the disk.
I do not question the 2 GB buffer space. But it no longer serves as possible swap. The question is whether CE still offers to create a swap partition on sufficiently large boot devices during installation—and thus whether a plain 100 GB oldie would be better than a 16 GB M10 for this purpose.
25.10.0 (the latest ISO I have in my Proxmox storage), on a 100 GB boot device, does not ask to create a swap partition.
I found a 128GB SSD for ~20 CHF/€/$ in a regular shop, quite a no brainer, but what a waste of space :grinning_face:
Any chance to utilize this for other purposes than piling up several years of TrueNAS updates?
Unlucky, no… Only viable with unsupported - and not raccomended- tricks
And another annoying problem.
After a reboot I cannot login by ssh, I have to open a shell in the UI and type
sudo usermod -s /usr/bin/zsh fillg1
[sss_cache] [confdb_init] (0x0010): Unable to open config database [/var/run/sssd-cache/db/config.ldb]
Could not open available domains
I'm able to connect after that, but after a reboot its gone,
Any ideas?
