Goodnight! I have on my server 1x 6Tb HD and 4 more disks that add up to exactly 6Tb (1x 1Tb, 2x 1.5Tb and 1x 2 Tb). I would like to know if I can create a Stripe with these 4 different disks and then create a mirror, mirroring the 6Tb HD in this pool. As if it were a mirror of 2x 6Tb HDs
Nope, that’s not supported. Far too hacky to be a good idea.
It could be done at the CLI: partition the 6 TB disk with 1x 1 TB, 2x 1.5 TB, and 1x 2 TB partitions, then create a pool consisting of four mirrors, each consisting of one partition and one matching disk. But definitely:
@Alec_Ovr, there are lots of things that can be done with ZFS that really aren’t a good idea, and this is one of them.
What is the most efficient way to organize HDs? I have 2 more 1TB HDs left. I would like to have as much space as possible without using Stripe.
Honestly, it would be to ditch the smaller drives, get a second 6 TB unit, and mirror those two. There really isn’t a good way to put those seven drives together into a redundant pool.
Thank you very much!
I managed to do this configuration once, but I’m going to look for new HDs!
Best to buy another 6TB drive.
If you want you can pair the 1 with the 2, and the 2 1.5s with each other and and have
6 + 1 + 1.5TB = 8.5TB
And then replace drives with bigger drives in the future as they fail or remove them eventually (since they’re mirrors)
But definitely start by getting another 6TB
