Dear TrueNAS Dev Team,
Problem:
I understand that there are good reasons to provide TrueNAS Scale as an appliance (instead of a distro). That, however, leads to a lot of restrictions at the cost of the usability of TrueNAS Scale. I find myself time and again looking for workarounds for these restrictions.
To give an example: It’s kind of useless to have NixOS as a container. Most (all?) configuration changes are made with the command nixos-rebuild switch. That, however leads to an error message, due to security settings. It would require to change the setting of the incus container to security.nesting=true. That’s possible from the shell. But this breaks TrueNAS’ settings in the GUI. Bummer.
Solution:
- Expose a lot more parameters / options of the underlying commands via GUI (e.g. through check boxes etc.) OR
- Provide a textbox for the user to add parameters / options (like the
Commandsfield on the screen for creating custom apps).
Best regards
Ture
