You can get various metrics from this power pack and I am sure other brands which would be useful to users and their self builds.
On Windows you use the CORSAIR iCUE Software, which you can monitor your power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop.
Impact
A user can see how much power their TrueNAS build is using, and can see if there are any issues with the power unit.
User Story
This would be a nice feature to be added to reporting and NetData and would fit nicely with UPS reporting.
Additional
This is also expanding to other devices such as power supplies.
Assuming your kernel is up-to-date, there is hwmon/kernel support in the corsair-psu module: https://docs.kernel.org/hwmon/corsair-psu.html
In addition, liquidctl has support on top of the kernel module for monitoring: https://github.com/liquidctl/liquidctl/blob/main/docs/corsair-hxi-rmi-psu-guide.md
True, but many of us run it on PC motherboards and having access to the temp in the case ( for example ), is nice to have since is already there in the power supply. All it needs is the software side.
I hope that is taken into consideration for integration when the PSU is available.
