well i liked ur xeon suggestion. not looking down on it.
but i’m set on ryzen 65tdp cpu with igpu. am5 (am4 possible if its a price deal)
i think ill have to pass on ecc for now and just get non ecc. i cant find a good source for ddr5 ecc. later i can get ddr5 when it becomes more available. no rush. just don’t want to close the door shut, so next i can simply get ram and be done with it for a future easy upgrade.
I like this MATX, it does everything i needed, but it had only 4 sata. the case im looking at for hotswap has 5 sata, so looking for a 6 sata mobo which then makes the choice a X670 if not mistaken?
And because i now switch case to a 4U (this silverstone), it supports atx mobo, so now i’m looking at this
https://www.asrock.com/mb/compare.us.asp?Models=X670E%20PG%20Lightning,X670E%20Pro%20RS
either the X670E PG ligthning or X670E Pro RS
i know its not intended for server, but it just works
but unlike GregSalazar (who did the youtube for the silverstone casing im interested in), he opted for a gaming cpu. i dont plan to use my nas for that. its strictly just for truenas as a storage and docker containers, thats all. i might dabble in making a VM to test linux os once in a blue moon). thats my current usage for it. Im guessing for that either a 600 watt or 750 watt seasonic atx 3.0 psu would suffice?
the main diff between the 2 boards is the pcie slots. i’m leaning toward the X670E PG Lightning.
but etorix made a great point, B550, but don’t really want to deal with ebay x-x; do u have any other b550 with 5-6 sata? then i can check for availability.
https://www.reddit.com/r/homelab/comments/1b6rud1/gigabyte_mc12le0_b550/
i checked for the MC12-LE0 no local stock, that is another problem for me. good suggestions but…
if you are willing to import a MC12-LE0 from Germany, you can go for, say, a Ryzen 5600(X) CPU, use the BMC video output to set the BIOS (no iGPU),
bmc video output how does that work? yeah as long as i can get bios to show on monitor (for me to setup truenas) then that’s all i need. any other motherboards can do this? i have a spare 5600x lying around (i replaced my desktop to a 5700x3d from this cpu)
Or i’m willing to just get a new cpu with igpu if the other option is gonna be hard to get. AMD Ryzen 5 7600 how about this? igpu with ecc support.
Really confused which cpu and mobo combo to get
4u case is chunky but im ok with that. ive seen enough homelabbers using something similar, so it wouldnt be an unusual pick.
