More efficient one way up sync from TrueNAS to Proton Drive
I’m new to TrueNAS and got great help from this forum with various issues and figured I’d share my solution for anyone interested.
Mostly for backup and secure remote availability of my files (without exposing my NAS to the outside world) I wanted to have my document files synced to Proton Drive, but one way only: from my NAS to Proton. Running rclone on my entire dataset where I keep my personal files, which is quite a lot (2TB), is very time consuming (HOURS), so, I came up with this approach:
  1. keep a local DB of all my files
  2. on schedule, I do it every morning at 6 am, do a snapshot of local files
  3. compare the snapshot files to database records by name and modified time
  4. compile new/modified and deleted file lists
  5. upload to Proton Drive only the new/modified files and remove deleted files
  6. record snapshot as the current state of files in the database
  7. keep log of the process
This entire process completes in seconds or in minutes (if modified/new list is large) instead of hours running rclone comparing local files to remote.
So, I have the script below saved as .sh file in my home folder with required execute permission and schedule it via system->advanced->cron jobs
The pre-requisite is that you must run rcolone and setup new remote to your Proton Drive - it walks you through it step by step.
I hope it helps someone. The script is below
#!/bin/bash
USER_HOME="/mnt/home/YOUR_USERNAME"
SOURCE_DIR="/mnt/YOUR_DATAPOOL/MyFiles" #NAS location of your files
DB_DIR="/mnt/YOUR_DATAPOOL/home/YOUR_USERNAME/proton_file_tracker"
DB_FILE="$DB_DIR/file_tracker.db"
LOG_FILE="/mnt/YOUR_DATAPOOL/rclone_pd.log" #LOCATION OF THE LOG FILE
# Ensure the directory exists for storing DB and temp files
mkdir -p "$DB_DIR"
# Create the database if it doesn't exist
if [ ! -f "$DB_FILE" ]; then
    sqlite3 "$DB_FILE" <<SQL
CREATE TABLE files (path TEXT PRIMARY KEY, mtime INTEGER, size INTEGER);
CREATE TABLE metadata (key TEXT PRIMARY KEY, value INTEGER);
INSERT INTO metadata (key, value) VALUES ('last_run_time', 0);
SQL
fi
# Update the current file info in bulk
find "$SOURCE_DIR" -type f -printf "%p|%T@|%s\n" > "$DB_DIR/current_files.txt"
# Track current timestamp
CURRENT_TIMESTAMP=$(date +%s)
# Before the SQLite command, prepare a variable for the SQL query
# to reduce path of the files from absolute to relative
RELATIVE_SQL_CHANGED="SELECT substr(f.path, length('$SOURCE_DIR') + 1) AS path FROM files f LEFT JOIN files_last_run flr ON f.path = flr.path WHERE flr.path IS NULL OR f.mtime > COALESCE(flr.mtime, 0);"
RELATIVE_SQL_DELETED="SELECT substr(flr.path, length('$SOURCE_DIR') + 1) AS path FROM files_last_run flr WHERE flr.path NOT IN (SELECT path FROM files);"
# Performance tuning and database operations
sqlite3 "$DB_FILE" <<SQL > /dev/null 2>&1
PRAGMA synchronous=OFF;
PRAGMA journal_mode=WAL;
BEGIN TRANSACTION;
-- Backup the current files table as files_last_run
DROP TABLE IF EXISTS files_last_run;
ALTER TABLE files RENAME TO files_last_run;
-- Recreate files table and create indexes
CREATE INDEX IF NOT EXISTS idx_files_path ON files(path);
CREATE INDEX IF NOT EXISTS idx_files_last_run_path ON files_last_run(path);
-- Import new file data
.import $DB_DIR/current_files.txt files
-- Identify changes
.output $DB_DIR/changed_files.txt
$RELATIVE_SQL_CHANGED
-- Identify deletions
.output $DB_DIR/deleted_files.txt
$RELATIVE_SQL_DELETED
-- Update last run time after all changes have been identified
INSERT OR REPLACE INTO metadata (key, value) VALUES ('last_run_time', $CURRENT_TIMESTAMP);
COMMIT;
SQL
# Error handling for rclone operations
# Sync changed files
if [ -s "$DB_DIR/changed_files.txt" ]; then
    if ! rclone sync "$SOURCE_DIR" "proton_drive:Home-NAS/Docs" --files-from "$DB_DIR/changed_files.txt" --update --local-no-check-updated --protondrive-replace-existing-draft=true --log-file="$LOG_FILE" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO; then
        echo "Error syncing files. Details in $LOG_FILE" >> "$LOG_FILE"
        exit 1
    fi
fi
# Handle deletions
if [ -s "$DB_DIR/deleted_files.txt" ]; then
    if ! rclone delete "proton_drive:Home-NAS/Docs" --include-from "$DB_DIR/deleted_files.txt" --protondrive-replace-existing-draft=true --log-file="$LOG_FILE" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO; then
        echo "Error deleting files. Details in $LOG_FILE" >> "$LOG_FILE"
        exit 1
    fi
fi
# Clean up temporary files
rm -f "$DB_DIR/changed_files.txt" "$DB_DIR/deleted_files.txt" "$DB_DIR/current_files.txt"
echo "############################################################" >> "$LOG_FILE"
echo "Sync completed successfully." >> "$LOG_FILE"
@weekends-rule
Thanks a lot for sharing! That helped me!
How did you solve the problem of having to enter the 2FA code?
Or did you simply not secure your proton account with 2FA?
I do have 2fa but when you first create the destination with rcron, it asks you for 2fa, once you enter it - rclone works by renewing the token automatically
Oh man, saving this thread. Thank you, kind friend.
oh, yep, i realized it myself after having it run for three nights in a row now.
Thanks!
Please note that directory tracking was not important to me because I designed this project as somewhat another backup option and to make my data securely available for infrequent online access. I did not implement any monitoring for directories.
What I mean is this: you create directory “My Files” on TrueNAS and this script will sync it to Proton. Then, you delete “My Files” on your NAS - this script will remove all files from “My Files” folder on Proton, but will not delete the folder itself. Also, if you rename “My Files” on your NAS to “My Files New” - this script will create new folder on Proton “My Files New”, sync files to it, remove all files from Proton “My Files” but will not delete the folder itself.
I dont have any plans yet to add directory monitoring but if it becomes nuisance, I will.
Aight! While I still don’t need the folder tracking, I couldn’t stand the fact that this was not “complete”, so I finished it. This version, while having file sync logic/mechanics unchanged, now has folder tracking.
The folder tracking is not done by tracking folders via the file system but examining what was uploaded to Proton Drive. This script now properly cleans up folders that were renamed or deleted. No more orphaned (empty) folders. As a safeguard to prevent mass deletion, if the current state of folders is missing (for instance when you run it the first time), the script will simply document the online folders list and only proceeds with removing online copies when they were confirmed removed by comparison to an existing previous state.
No folder deletions or any other file/folder system operations is ever done to the file system.
#!/bin/bash
# v2 - adding folder tracking
USER_HOME="/mnt/home/USERNAME"
SOURCE_DIR="/mnt/Datapool/Docs"
DB_DIR="/mnt/Datapool/home/USERNAME/proton_file_tracker"
LOG_FILE="/mnt/Datapool/home/USERNAME/LOGNAME.log"
mkdir -p "$(dirname "$LOG_FILE")"
log_debug() {
    echo "$(date '+%Y-%m-%d %H:%M:%S') - $1" >> "$LOG_FILE"
echo "" >> "$LOG_FILE"
printf "#%.0s" {1..80} >> "$LOG_FILE"; echo >> "$LOG_FILE"
log_debug "Sync operation started"
log_footer() {
    log_debug "Sync completed successfully"
    log_debug "New/changed files: $NEW_CHANGED_COUNT"
    log_debug "Deleted files:     $DELETED_COUNT"
    log_debug "Deleted folders:   $DELETED_FOLDER_COUNT"
mkdir -p "$DB_DIR"
SQL
fi
BEGIN TRANSACTION;
COMMIT;
SQL
        exit 1
    fi
fi
        exit 1
    fi
fi
FOLDER_DB_FILE="$DB_DIR/folder_tracker.db"
DELETED_FOLDERS_FILE="$DB_DIR/deleted_folders.txt"
CURRENT_FOLDERS_FILE="$DB_DIR/current_folders.txt"
FIRST_RUN=0
if [ ! -f "$FOLDER_DB_FILE" ]; then
    sqlite3 "$FOLDER_DB_FILE" <<SQL
CREATE TABLE folders (path TEXT PRIMARY KEY);
SQL
    FIRST_RUN=1
    log_debug "Folder tracking initializing: creating baseline state, no deletions will occur"
fi
awk -F'|' '{sub(/[^/]*$/, "", $1); print $1}' "$DB_DIR/current_files.txt" | sort -u > "$CURRENT_FOLDERS_FILE"
RELATIVE_SQL_DELETED_FOLDERS="SELECT substr(flr.path, length('$SOURCE_DIR') + 1) AS path FROM folders_last_run flr WHERE flr.path NOT IN (SELECT path FROM folders);"
sqlite3 "$FOLDER_DB_FILE" <<SQL > /dev/null 2>&1
BEGIN TRANSACTION;
$( [ "$FIRST_RUN" -eq 0 ] && echo "DROP TABLE IF EXISTS folders_last_run; ALTER TABLE folders RENAME TO folders_last_run;" )
.import --csv $CURRENT_FOLDERS_FILE folders
$( [ "$FIRST_RUN" -eq 0 ] && echo ".output $DELETED_FOLDERS_FILE" )
$( [ "$FIRST_RUN" -eq 0 ] && echo "$RELATIVE_SQL_DELETED_FOLDERS" )
COMMIT;
SQL
if [ "$FIRST_RUN" -eq 0 ] && [ -s "$DELETED_FOLDERS_FILE" ]; then
    while IFS= read -r folder; do
        if ! rclone rmdir "proton_drive:Home-NAS/Docs/$folder" --log-file="$LOG_FILE" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO; then
            log_debug "Error deleting folder '$folder'. Details in $LOG_FILE"
        fi
    done < "$DELETED_FOLDERS_FILE"
fi
NEW_CHANGED_COUNT=$(wc -l < "$DB_DIR/changed_files.txt")
DELETED_COUNT=$(wc -l < "$DB_DIR/deleted_files.txt")
DELETED_FOLDER_COUNT=0
if [ "$FIRST_RUN" -eq 0 ]; then
    DELETED_FOLDER_COUNT=$(wc -l < "$DELETED_FOLDERS_FILE" 2>/dev/null || echo 0)
fi
rm -f "$DB_DIR/changed_files.txt" "$DB_DIR/deleted_files.txt" "$DB_DIR/current_files.txt" "$DELETED_FOLDERS_FILE" "$CURRENT_FOLDERS_FILE"
log_footer
I did some log clean up to filter out some noisy log messages from rclone since the operation is intentional:
A file or folder with that name already exists (Code=2500, Status=422)
so, now, rclone logs to a temp log file which then passed to the log writer that filters the noise and makes operation’s log very neat. Added some comments for readability
#!/bin/bash
# /mnt/Datapool/home/st0retron/proton_file_tracker/pd_file_sync_script.sh
DB_DIR="/mnt/Datapool/home/USERNAME/proton_file_tracker"  # Shared directory for file and folder tracking DBs and temp files
LOG_FILE="/mnt/PATH TO LOG FOLDER/LOGNAME.log"
write_log() {
    if [ -f "$1" ]; then
        # Process rclone temp log file, filtering out 422 errors
        while IFS= read -r line; do
            if ! echo "$line" | grep -q "A file or folder with that name already exists (Code=2500, Status=422)"; then
                echo "$(date '+%Y-%m-%d %H:%M:%S') - $line" >> "$LOG_FILE"
            fi
        done < "$1"
    else
        # Regular log message
    fi
write_log "Sync operation started"
log_footer() {
    write_log "Sync completed successfully"
    write_log "New/changed files: $NEW_CHANGED_COUNT"
    write_log "Deleted files:     $DELETED_COUNT"
    write_log "Deleted folders:   $DELETED_FOLDER_COUNT"
mkdir -p "$DB_DIR"
SQL
fi
BEGIN TRANSACTION;
COMMIT;
SQL
    TEMP_LOG="$LOG_FILE.tmp"
    if ! rclone sync "$SOURCE_DIR" "proton_drive:Home-NAS/Docs" --files-from "$DB_DIR/changed_files.txt" --update --local-no-check-updated --protondrive-replace-existing-draft=true --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
        echo "Error syncing files. Details in $TEMP_LOG" >> "$LOG_FILE"
        exit 1
    fi
    write_log "$TEMP_LOG"
    rm -f "$TEMP_LOG"
fi
    if ! rclone delete "proton_drive:Home-NAS/Docs" --include-from "$DB_DIR/deleted_files.txt" --protondrive-replace-existing-draft=true --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
        echo "Error deleting files. Details in $TEMP_LOG" >> "$LOG_FILE"
        exit 1
    fi
    rm -f "$TEMP_LOG"
fi
# Folder tracking section using the same DB_DIR
FIRST_RUN=0
SQL
    FIRST_RUN=1
    write_log "Folder tracking initializing: creating baseline state, no deletions will occur"
fi
RELATIVE_SQL_DELETED_FOLDERS="SELECT substr(flr.path, length('$SOURCE_DIR') + 1) AS path FROM folders_last_run flr WHERE flr.path NOT IN (SELECT path FROM folders) ORDER BY path DESC;"
BEGIN TRANSACTION;
COMMIT;
SQL
        if ! rclone rmdir "proton_drive:Home-NAS/Docs/$folder" --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
            write_log "Error deleting folder '$folder'. Details in $TEMP_LOG"
        fi
        rm -f "$TEMP_LOG"
fi
fi
log_footer
One more addition: running with --resetstate parameter will clear out both (file and folder tracking) databases and set the current state of files. This could be useful when manually adding files or folders to Proton Drive and avoiding repeating uploading by the script. So, basically, --resetstate will catalog all files in the SOURCE and consider them being online and only sync future changes.
#!/bin/bash
# /mnt/Datapool/home/USERNAME/proton_file_tracker/pd_file_sync_script.sh
# v2 - added folder tracking
# v3 - added reset state mechanism - to take a snapshot of the SOURCE_DIR state and consider them already online. Useful when manually uploading files or renaming folders that would otherwise trigger large deletes and re-uploads
# v.3.3
# there is a log upload command at the very end of this script but only needed to update the log file if it is stored within the SOURCE DIR
# if the log file stored somewhere else and is not uploaded to the Proton Drive, the very last rclone sync command is not needed
# comment it out
SOURCE_DIR="/mnt/Datapool/SOURCE_DIR"	#source dir to sync up, dont include the last forward slash: something/something/source
REMOTE_DIR="proton_drive:PROTON_DESTINATION_DIR" #destination on Proton Drive for synced files, dont include the last forward slash
LOG_FILE="/mnt/Datapool/Docs/PATH_TO_LOG/LOGFILENAME.log" #full path to log file
DB_DIR="/mnt/Datapool/home/USERNAME/proton_file_tracker" #dir where databases and temp files are stored
DB_FILES="$DB_DIR/file_tracker.db" #db holding files state for tracking new/changed/deleted files
CURRENT_FILES="$DB_DIR/current_files.txt" #temp files
CHANGED_FILES="$DB_DIR/changed_files.txt"
DELETED_FILES="$DB_DIR/deleted_files.txt"
DB_FOLDERS="$DB_DIR/folder_tracker.db" #db holding folders state to track deleted folders
CURRENT_FOLDERS="$DB_DIR/current_folders.txt" #temp files
DELETED_FOLDERS="$DB_DIR/deleted_folders.txt"
#variables to keep track for state reset or when
RESET_STATE=0
FIRST_RUN=0
# Define write_log function early
write_log() {
                if ! echo "$line" | grep -qE "Transferred:|Errors:|Checks:|Deleted:|Elapsed time:"; then
                fi
            fi
        done < "$1"
    else
    fi
# Initial log header
# Check for --resetstate parameter (case-insensitive)
for arg in "$@"; do
    if [[ "${arg,,}" == "--resetstate" ]]; then
        RESET_STATE=1
        write_log "Resetting state with --resetstate parameter"
        rm -f "$DB_FILES" "$DB_FOLDERS"
        break
    fi
done
mkdir -p "$DB_DIR"
log_footer() {
if [ ! -f "$DB_FILES" ]; then
    sqlite3 "$DB_FILES" <<SQL
SQL
fi
find "$SOURCE_DIR" -type f -printf "%p|%T@|%s\n" > "$CURRENT_FILES"
sqlite3 "$DB_FILES" <<SQL > /dev/null 2>&1
BEGIN TRANSACTION;
.import $CURRENT_FILES files
.output $CHANGED_FILES
.output $DELETED_FILES
COMMIT;
SQL
if [ -s "$CHANGED_FILES" ] && [ "$RESET_STATE" -eq 0 ]; then
    if ! rclone sync "$SOURCE_DIR" "$REMOTE_DIR" --files-from "$CHANGED_FILES" --update --local-no-check-updated --protondrive-replace-existing-draft=true --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
        exit 1
    fi
    rm -f "$TEMP_LOG"
fi
if [ -s "$DELETED_FILES" ] && [ "$RESET_STATE" -eq 0 ]; then
    if ! rclone delete "$REMOTE_DIR" --include-from "$DELETED_FILES" --protondrive-replace-existing-draft=true --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
        exit 1
    fi
    rm -f "$TEMP_LOG"
fi
if [ ! -f "$DB_FOLDERS" ]; then
    sqlite3 "$DB_FOLDERS" <<SQL
SQL
    FIRST_RUN=1
    write_log "Creating folder tracking initial state"
fi
awk -F'|' '{sub(/[^/]*$/, "", $1); print $1}' "$CURRENT_FILES" | sort -u > "$CURRENT_FOLDERS"
sqlite3 "$DB_FOLDERS" <<SQL > /dev/null 2>&1
BEGIN TRANSACTION;
.import --csv $CURRENT_FOLDERS folders
$( [ "$FIRST_RUN" -eq 0 ] && echo ".output $DELETED_FOLDERS" )
COMMIT;
SQL
if [ "$FIRST_RUN" -eq 0 ] && [ -s "$DELETED_FOLDERS" ]; then
        if ! rclone rmdir "$REMOTE_DIR${folder}" --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
        fi
        rm -f "$TEMP_LOG"
    done < "$DELETED_FOLDERS"
fi
NEW_CHANGED_COUNT=$(wc -l < "$CHANGED_FILES")
DELETED_COUNT=$(wc -l < "$DELETED_FILES")
    DELETED_FOLDER_COUNT=$(wc -l < "$DELETED_FOLDERS" 2>/dev/null || echo 0)
fi
rm -f "$CHANGED_FILES" "$DELETED_FILES" "$CURRENT_FILES" "$DELETED_FOLDERS" "$CURRENT_FOLDERS"
log_footer
# final log file push to update the log file that was already partially uploaded during the chagned files sync, but
# it has more entries by now, so need to sync up to get the full log, otherwise the online log file will only have
# the full log info up to the last sync operation
log_footer
LOG_DIR=$(dirname "$LOG_FILE")
rclone sync "$LOG_FILE" "$REMOTE_DIR/${LOG_DIR#$SOURCE_DIR/}" --update --local-no-check-updated --protondrive-replace-existing-draft=true --stats 0 > /dev/null 2>&1
this looks really awesome! thank you for sharing your work!
How will this react if the upload gets interrupted (either lost of connection or issue with the server)? On the next run will it know that some new/changed files were not uploaded?
Thanks for this guide and script. I will give it a shot on my server.
The script updates file system state only after successful upload and if any individual file fails to upload, the file system state will not update meaning that all of the files reported as new, changed, or deleted will again be reported the same during the next sync. Obviously if the upload failure happened after some remote files were deleted - they will produce an error during the next sync (cant delete the same files twice) but all the new and changed files will be re-uploaded again.
Rclone is pretty good at connections and recovery - it does try more than a few times and, at least in my case, always recovers.
If the datasets are used as Windows shares, what could I add in the script so it ignores the system folder(s) $RECYCLE.BIN and its content? The same for the system file desktop.ini?
I guess my rclone session timed out today unable to re-establish connection. I ended up editing rclone config via SSH:
rclone config
e - to edit existing
# - number for your proton client config
then accepting defaults until 2fa, enter the current 2fa
n - to skip editing advanced configs
q - to quit
then quickly typing:
rclone lsd name_of_your_proton_config:
so rclone can login in time while the 2fa is still current.
But then I realized, instead of all above, I should’ve just ran this command in the SSH terminal (lsd to list directories):
rclone lsd name_of_your_proton_config: --protondrive-2fa=######
where ###### is, obviously, the current 2fa code, which would’ve accomplished the same thing
I would probably keep the exclusions in a separate file for manageability (exclude.config), then have the script look for that file: if found - then exclude files or folders listed in it, if not - dont exclude anything.
# exclude.config
# Lines starting with # are comments
# Exclude specific files
- desktop.ini
# Exclude specific folders (use trailing slash for directories)
- $RECYCLE.BIN/
- Thumbs.db
# Exclude any folder named "Backup" anywhere in the path
- **/Backup/
# Exclude all .tmp files
- *.tmp
This format will be the same as rclone: - for exclusion, ** for recursive matching, / for directories. This aligns with rclone’s --exclude or --filter-from options
Then add the logic to the top of existing script:
# Path to exclusion file
EXCLUDE_CONFIG="$DB_DIR/exclude.config"
EXCLUDE_FILTER="$DB_DIR/exclude_filter.txt"
# Initialize exclude filter file
: > "$EXCLUDE_FILTER"
# Check if exclude.config exists and convert to find-compatible patterns
if [ -f "$EXCLUDE_CONFIG" ]; then
    write_log "Applying exclusions from $EXCLUDE_CONFIG"
    # Convert rclone filter patterns to find-compatible patterns
        # Skip comments and empty lines
        [[ "$line" =~ ^#.*$ || -z "$line" ]] && continue
        # Remove leading '-' and trim whitespace
        pattern=$(echo "$line" | sed 's/^- *//')
        # Handle rclone patterns (simplified for find)
        if [[ "$pattern" == */ ]]; then
            # Directory (ends with /)
            pattern=$(echo "$pattern" | sed 's/\/$//')
            echo "-path '*/$pattern' -prune" >> "$EXCLUDE_FILTER"
        else
            # File or pattern
            if [[ "$pattern" == **/* ]]; then
                pattern=$(echo "$pattern" | sed 's/\*\*\/*//')
                echo "-name '$pattern' -prune" >> "$EXCLUDE_FILTER"
            else
            fi
        fi
        # Add to rclone filter file
        echo "- $pattern" >> "$EXCLUDE_FILTER.rclone"
    done < "$EXCLUDE_CONFIG"
fi
will also need to modify the find command:
# Build find exclude arguments
FIND_EXCLUDE_ARGS=""
if [ -s "$EXCLUDE_FILTER" ]; then
    FIND_EXCLUDE_ARGS=$(cat "$EXCLUDE_FILTER" | tr '\n' ' ')
fi
# Update current file info with exclusions
find "$SOURCE_DIR" \( $FIND_EXCLUDE_ARGS \) -o -type f -printf "%p|%T@|%s\n" > "$CURRENT_FILES"
sync and folder tracking will also need to be updated with filters. The filtering script should look something like this (I DID NOT TEST THIS):
#!/bin/bash
# v3 - adding reset state mechanism
# v4 - adding exclusion filtering
EXCLUDE_FILTER_RCLONE="$DB_DIR/exclude_filter_rclone.txt"
RESET_STATE=0
FIRST_RUN=0
write_log() {
                fi
            fi
        done < "$1"
    else
    fi
for arg in "$@"; do
        RESET_STATE=1
        write_log "Creating file and folder tracking initial state"
        break
    fi
done
mkdir -p "$DB_DIR"
# Initialize exclude filter files
: > "$EXCLUDE_FILTER_RCLONE"
# Process exclude.config if it exists
        echo "- $pattern" >> "$EXCLUDE_FILTER_RCLONE"
        # Convert to find-compatible pattern
        else
            # File or pattern
            else
            fi
        fi
fi
fi
# Define log_footer function
log_footer() {
# Initialize file database
SQL
fi
BEGIN TRANSACTION;
COMMIT;
SQL
    RCLONE_FILTER=""
    if [ -f "$EXCLUDE_FILTER_RCLONE" ] && [ -s "$EXCLUDE_FILTER_RCLONE" ]; then
        RCLONE_FILTER="--filter-from $EXCLUDE_FILTER_RCLONE"
    fi
    if ! rclone sync "$SOURCE_DIR" "$REMOTE_DIR" --files-from "$CHANGED_FILES" --update --local-no-check-updated --protondrive-replace-existing-draft=true $RCLONE_FILTER --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
        exit 1
    fi
    rm -f "$TEMP_LOG"
fi
# Delete files
    RCLONE_FILTER=""
    fi
    if ! rclone delete "$REMOTE_DIR" --include-from "$DELETED_FILES" --protondrive-replace-existing-draft=true $RCLONE_FILTER --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
        exit 1
    fi
    rm -f "$TEMP_LOG"
fi
# Initialize folder database
SQL
    FIRST_RUN=1
fi
# Generate current folders with exclusions
# Filter out excluded folders
    TEMP_FOLDERS="$DB_DIR/temp_folders.txt"
    : > "$TEMP_FOLDERS"
        skip=0
                if [[ "$folder" == *"$pattern"* ]]; then
                    skip=1
                    break
                fi
            fi
        if [ "$skip" -eq 0 ]; then
            echo "$folder" >> "$TEMP_FOLDERS"
        fi
    done < "$CURRENT_FOLDERS"
    mv "$TEMP_FOLDERS" "$CURRENT_FOLDERS"
fi
BEGIN TRANSACTION;
COMMIT;
SQL
# Delete folders
    RCLONE_FILTER=""
    fi
        if ! rclone rmdir "$REMOTE_DIR${folder}" $RCLONE_FILTER --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0; then
        fi
        rm -f "$TEMP_LOG"
fi
# Count operations
fi
rm -f "$CHANGED_FILES" "$DELETED_FILES" "$CURRENT_FILES" "$DELETED_FOLDERS" "$CURRENT_FOLDERS" "$EXCLUDE_FILTER" "$EXCLUDE_FILTER_RCLONE" "$TEMP_FOLDERS"
# Write log footer
log_footer
# Final log file push
Thanks for this. Adapted a few things here and there to fit my use-case. Thanks to your framework that was a breeze! Works like a charm so far :slight_smile:
ok, finally decided to implement folder exclusions, improve proton connectivity, error handling, and temp files cleanup.
The file where exclusions are listed must be in UNIX format (end lines with LF, not CRLF), comments are allowed and ignored, wildcards accepted, this is folder exclusion only - individual file names not allowed. Here is the content of my “excluded.txt” file located in /mnt/Datapool/Docs dataset (dataset named “Docs” and root folder in that dataset “Websites” must be Docs/Websites/** ):
# Skip these folders (this is folders ONLY exclusion list, individual files cannot be excluded)
# One folder per line, no surrounding quotes, trailing slash is required to avoid confusion folders with files.
# Use relative paths from /mnt/Datapool/Docs or **/folder for folders anywhere.
# Append /** for recursive exclusion of folder contents.
# Examples:
# Docs/Quicken Files/** - will skip recursively everything in Docs/Quicken Files
# **/Temp/** - will recursively skip Temp folder found anywhere
# Temp/** - skips the Temp folder at /mnt/Datapool/Docs/Temp recursively
# Temp - skips folder named Temp only at the root of file system Docs/Temp
# Functionally Docs/Websites/ and Docs/Websites/** produce the same filter: everything recursively in Websites is ignored, but /** required for script to properly create exclusion filters
# MUST BE IN UNIX FORMAT FOR PROPER LINE ENDING
Docs/Websites/**
Docs/VB Projects/**
Here is the tested script that now honors exclusion list:
#!/bin/bash
# v4 - stability improvements, cleanup, add delay for API stability, and fix error handling logic.
# v5 - add excluded folders
# v5.1 - fix exclusion parsing to prevent find warnings
DB_DIR="/mnt/Datapool/home/USERNAME/proton_file_tracker" #location for database files
LOG_DIR="/mnt/Datapool/home/USERNAME/logs" #location for log files
LOG_FILE="${LOG_DIR}/2025 Home-NAS to Proton.log" #name of the log file
EXCLUDE_FILE="/mnt/Datapool/home/USERNAME/logs/excluded.txt" #list of folders to exclude from tracking (see exclusions notes)
# please note that below proton connection will be tested to ensure connectivity before proceeding with
# hard coded name proton_drive: - if you named your rconfig remote differently, use that name in connectivity check
# --- Temporary file definitions AND state tracking databases ---
# --- Script state variables ---
RESET_STATE=0
FIRST_RUN=0
# --- Build exclusion arguments for find and rclone ---
FIND_EXCLUDE_ARGS=()
RCLONE_EXCLUDE_ARGS=()
if [ -f "$EXCLUDE_FILE" ]; then
    while IFS= read -r rule; do
        # Skip empty lines and comments
        if [[ -z "$rule" || "$rule" =~ ^[[:space:]]*# ]]; then
            continue
        fi
        # Trim whitespace and carriage returns
        rule=$(echo "$rule" | tr -d '\r' | xargs)
        # Skip if rule is empty after trimming
        [ -z "$rule" ] && continue
        # Add to find exclusion args
        find_path=$(echo "$rule" | sed 's#/\*\*##; s#/$##')
        # Only add valid paths to avoid /mnt/Datapool/Docs/
        if [ -n "$find_path" ]; then
            FIND_EXCLUDE_ARGS+=(-path "$SOURCE_DIR/$find_path" -prune -o)
        fi
        # Add to rclone exclusion args for rmdir
        RCLONE_EXCLUDE_ARGS+=("--exclude" "$rule")
    done < "$EXCLUDE_FILE"
fi
# Graceful exit function to clean up temp files
cleanup_and_exit() {
    echo "$(date '+%Y-%m-%d %H:%M:%S') - An error occurred. Cleaning up temporary files." >> "$LOG_FILE"
    rm -f "$CHANGED_FILES" "$DELETED_FILES" "$CURRENT_FILES" "$DELETED_FOLDERS" "$CURRENT_FOLDERS" "$TEMP_LOG"
    exit 1
# Trap for global cleanup on errors/interrupts
trap 'cleanup_and_exit' ERR INT TERM
write_log() {
            # Filter out noisy rclone log entries
            if ! echo "$line" | grep -qE "Transferred:|Errors:|Checks:|Deleted:|Elapsed time:|A file or folder with that name already exists"; then
            fi
        done < "$1"
    else
    fi
# --- Script Start ---
# Ensure operational directories exist
mkdir -p "$DB_DIR" "$LOG_DIR"
# Log excluded folders (minimal)
if [ ${#RCLONE_EXCLUDE_ARGS[@]} -gt 0 ]; then
    write_log "Applying exclusion rules from: $EXCLUDE_FILE"
fi
for arg in "$@"; do
        RESET_STATE=1
        write_log "Creating file tracking initial state"
        break
    fi
done
log_footer() {
# Check Proton Drive authentication before proceeding
# CONNECTIVITY CHECK - USING NAME proton_drive: or update to your rclone remote name
if [ "$RESET_STATE" -eq 0 ]; then
    if ! rclone lsd proton_drive: >/dev/null 2>&1; then
        write_log "Error: Proton Drive authentication failed. Check rclone configuration."
        cleanup_and_exit
    fi
fi
# --- File Tracking Logic ---
    if ! sqlite3 "$DB_FILES" <<SQL
SQL
    then
        write_log "Error creating file_tracker.db."
        cleanup_and_exit
    fi
fi
# Generate current_files.txt, excluding specified folders
if [ ${#FIND_EXCLUDE_ARGS[@]} -gt 0 ]; then
    if ! find "$SOURCE_DIR" "${FIND_EXCLUDE_ARGS[@]}" -type f -printf '%p|%T@|%s\n' > "$CURRENT_FILES" 2> "$DB_DIR/find_error.log"; then
        write_log "Error running find for files: $(cat "$DB_DIR/find_error.log")"
        rm -f "$DB_DIR/find_error.log"
        cleanup_and_exit
    fi
else
    if ! find "$SOURCE_DIR" -type f -printf '%p|%T@|%s\n' > "$CURRENT_FILES" 2> "$DB_DIR/find_error.log"; then
        cleanup_and_exit
    fi
fi
if ! sqlite3 "$DB_FILES" <<SQL > /dev/null 2> "$DB_DIR/sqlite_error.log"
BEGIN TRANSACTION;
COMMIT;
SQL
then
    write_log "Error running SQLite for files: $(cat "$DB_DIR/sqlite_error.log")"
    rm -f "$DB_DIR/sqlite_error.log"
    cleanup_and_exit
fi
# --- Folder Tracking Logic ---
    if ! sqlite3 "$DB_FOLDERS" <<SQL
SQL
    then
        write_log "Error creating folder_tracker.db."
        cleanup_and_exit
    fi
    FIRST_RUN=1
fi
# Generate current_folders.txt, excluding specified folders and removing carriage returns
    if ! find "$SOURCE_DIR" "${FIND_EXCLUDE_ARGS[@]}" -type d -printf '%p\n' | tr -d '\r' | sort -u > "$CURRENT_FOLDERS" 2> "$DB_DIR/find_error.log"; then
        write_log "Error running find for folders: $(cat "$DB_DIR/find_error.log")"
        cleanup_and_exit
    fi
else
    if ! find "$SOURCE_DIR" -type d -printf '%p\n' | tr -d '\r' | sort -u > "$CURRENT_FOLDERS" 2> "$DB_DIR/find_error.log"; then
        cleanup_and_exit
    fi
fi
if ! sqlite3 "$DB_FOLDERS" <<SQL > /dev/null 2> "$DB_DIR/sqlite_error.log"
BEGIN TRANSACTION;
$( [ "$FIRST_RUN" -eq 0 ] && echo "DROP TABLE IF EXISTS folders_last_run; ALTER TABLE folders RENAME TO folders_last_run; CREATE TABLE folders (path TEXT PRIMARY KEY);" )
COMMIT;
SQL
then
    write_log "Error running SQLite for folders: $(cat "$DB_DIR/sqlite_error.log")"
    cleanup_and_exit
fi
# --- Rclone Sync/Delete Operations ---
    if [ -s "$CHANGED_FILES" ]; then
        TEMP_LOG="$DB_DIR/rclone_sync.tmp.log"
        if ! rclone sync "$SOURCE_DIR" "$REMOTE_DIR" --files-from "$CHANGED_FILES" --update --local-no-check-updated --protondrive-replace-existing-draft=true --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0 --retries 5 --low-level-retries 20 --retries-sleep 10s; then
            echo "$(date '+%Y-%m-%d %H:%M:%S') - Error syncing files. Details written to main log." >> "$LOG_FILE"
            rm -f "$TEMP_LOG"
            cleanup_and_exit
        fi
        rm -f "$TEMP_LOG"
    fi
    # --- STABILITY FIX: Add a short delay between sync and delete ---
    if [ -s "$CHANGED_FILES" ] && [ -s "$DELETED_FILES" ]; then
        write_log "Pausing for 15 seconds before processing deletions..."
        sleep 15
    fi
    if [ -s "$DELETED_FILES" ]; then
        TEMP_LOG="$DB_DIR/rclone_delete.tmp.log"
        if ! rclone delete "$REMOTE_DIR" --include-from "$DELETED_FILES" --protondrive-replace-existing-draft=true --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0 --retries 5 --low-level-retries 20 --retries-sleep 10s; then
            echo "$(date '+%Y-%m-%d %H:%M:%S') - Error deleting files. Details written to main log." >> "$LOG_FILE"
            rm -f "$TEMP_LOG"
            cleanup_and_exit
        fi
        rm -f "$TEMP_LOG"
    fi
fi
# --- Folder Deletion ---
    TEMP_LOG="$DB_DIR/rclone_rmdir.tmp.log"
    xargs -a "$DELETED_FOLDERS" -I {} rclone rmdir "$REMOTE_DIR{}" "${RCLONE_EXCLUDE_ARGS[@]}" --log-file="$TEMP_LOG" --log-format "date:'2006-01-02 15:04:05',level,msg" --log-level INFO --stats 0 --retries 5 --low-level-retries 20 --retries-sleep 10s --timeout 5m --contimeout 1m
    if grep -q "ERROR" "$TEMP_LOG"; then
        write_log "Error deleting one or more folders. Details in temp log."
        rm -f "$TEMP_LOG"
        cleanup_and_exit
    else
        write_log "Empty folder removal process completed."
        rm -f "$TEMP_LOG"
    fi
fi
# --- Final Cleanup and Logging ---
NEW_CHANGED_COUNT=$(wc -l < "$CHANGED_FILES" 2>/dev/null || echo 0)
DELETED_COUNT=$(wc -l < "$DELETED_FILES" 2>/dev/null || echo 0)
fi
log_footer
# Final log file push (silent, no logging, no error checking)
rclone copy "$LOG_FILE" "$REMOTE_DIR/${LOG_DIR#$SOURCE_DIR/}" --update --local-no-check-updated --protondrive-replace-existing-draft=true --stats 0 --quiet --retries 5 --retries-sleep 10s > /dev/null 2>&1
Hi, I’m a bit new to cron scripts in truenas and I keep hitting a call error on Goldeye and was having a syntax error at line 35 when trying to run it on fangtooth. if you have anything I might be missing or tips I should be using, let me know! if not thank you for the script either way! thanks! edit: I seem to have gotten it working! sorry for the junk reply!
Last year Proton killed rclone implementation completely.
I’ll look into if this script can be converted to use their official CLI that they just released
The official Proton CLI version is much much better, and faster. I’ll post the new script and how to set it up in a new thread
