More monitoring options
Problem/Justification
In the Apps pane it should be possible to have more sorting options like on processorusage, networktraffic … Then one would be able to see in an instance why or by which app the processor is heating up.
A seperate monitoring screen for hardware like processor- and fanspeeds, a graphical representation of networktraffic from and to the server by app.
A central log that also tells you which user is connected to which app from which ip address
Impact
It would be an extra asset for troubleshooting. It would however puts an extra load on system resources though.
User Story
Well, recently I installed Bazarr and since then coretemperatures are increased by 15°C. It’s obvious where it coms from: exising movies are all at once provided with subtitles, but I wanted to dig a lttle deeper finding the cause.
