Hello community!
I am asking for your help for the first time. I had finally managed to configure Truenas.
I gave up on the idea of having a separate pool for applications.
No matter what I do, I can’t configure it.
I wanted to install Tailscal, Nextcloud and Jellyfin, on a 250GB nvme with the data on 3x12TB in raidz1, and the data shared in smb.
Finally, I managed to configure Tailscale and jellyfine on the pool where the data is located, that is to say the 3*12TB.
Today, I turned Truenas off and on again and all my applications disappeared with this error message.
I looked through the French and English forums. I can’t find the solution.
Apart from uninstalling and reinstalling everything…
If any of you have the solution, I’m interested.
sorry for my english, it’s google translation, I’m french.
Thanks in advance.
Thomas
[EFAULT] Failed to stop docker service: [EFAULT] Failed to umount dataset: Dataset Application/ix-apps not found
concurrent.futures.process.RemoteTraceback:
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs/dataset_actions.py", line 77, in umount
with libzfs.ZFS() as zfs:
File “libzfs.pyx”, line 534, in libzfs.ZFS.exit
File “/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/dataset_actions.py”, line 78, in umount
dataset = zfs.get_dataset(name)
File “libzfs.pyx”, line 1463, in libzfs.ZFS.get_dataset
libzfs.ZFSException: Dataset Application/ix-apps not found
File “/usr/lib/python3.11/concurrent/futures/process.py”, line 256, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File “/usr/lib/python3/dist-packages/middlewared/worker.py”, line 112, in main_worker
res = MIDDLEWARE._run(*call_args)
File “/usr/lib/python3/dist-packages/middlewared/worker.py”, line 46, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File “/usr/lib/python3/dist-packages/middlewared/worker.py”, line 34, in _call
with Client(f’ws+unix://{MIDDLEWARE_RUN_DIR}/middlewared-internal.sock’, py_exceptions=True) as c:
File “/usr/lib/python3/dist-packages/middlewared/worker.py”, line 40, in call
return methodobj(*params)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 183, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs/dataset_actions.py", line 82, in umount
raise CallError(f’Failed to umount dataset: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to umount dataset: Dataset Application/ix-apps not found
The above exception was the direct cause of the following exception:
File “/usr/lib/python3/dist-packages/middlewared/plugins/docker/update.py”, line 90, in do_update
await self.middleware.call(‘service.stop’, ‘docker’)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1626, in call
return await self.call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1457, in call
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 179, in nf
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 49, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/service.py”, line 267, in stop
await service_object.after_stop()
File "/usr/lib/python3/dist-packages/middlewared/plugins/service/services/docker.py", line 72, in after_stop
await self.mount_umount_ix_apps(False)
File "/usr/lib/python3/dist-packages/middlewared/plugins/service/services/docker.py", line 19, in mount_umount_ix_apps
await self.middleware.call(‘zfs.dataset.umount’, docker_ds, {‘force’: True})
return await self._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1465, in _call
return await self._call_worker(name, *prepared_call.args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1471, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1377, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1361, in run_in_executor
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 488, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 533, in __run_body
rv = await self.method(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/docker/update.py”, line 92, in do_update
raise CallError(f’Failed to stop docker service: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to stop docker service: [EFAULT] Failed to umount dataset: Dataset Application/ix-apps not found
