Intel(R) Core™2 Quad CPU Q9400 @ 2.66GHz with 8GB Ram
4 Hard drives:
6Tb, 6TB, 4TB, 4TB
The two 6TB are mirrored
The two 4TB are mirrored
I know I’m a little low on Ram, but It has been running fine for months.
The problem is with the 4TB pool
Again it has been running ok, I started getting messages that I was at 74% and should stay below 80% for optimal performance. I said I had under 900GB of space left. I went in and deleted a good amount of files, more than 1TB. To my surprise, after I deleted those files I did not gain my space back. Instead, my pool is now 2.27TB. It used to be a little over 3TB. So essentially, my pool was shrunk by the amount of Data that I deleted. I tried doing searches and did not find anyone with this exact problem. Is this just a sign that my drives are dyng or is there something I can do or I’m missing. I thought of dumping and redoing the pool to see if I get my space back, but I’m not sure if that will work and wonder if there i an easier solution. I’m still fairly new to truenas, any help will be appreciated.
UPDATE:
After further review:
Windows says 844GB free of 2.27TB
Linux (Ubuntu) says I have 906GB free of 2.5TB
Truenas Pool says 844 available out of 3.5TB
To add more weirdness to the mix:
I’m running Plex from this system. There where movies there I deleted. The movies still show. They won’t play and ask me to make sure the file is still there. When I scan the drive. The movies do not disappear. I don’t know if this is related to the main problem or a separate issue but I thought it could potentionally be a symptom.
