Greetings, I’m starting to try truenas for the first time and I would like help installing Kodbox, which is a Windows-type web viewer/manager.
I saw some steps on github. I have not had success adding repository.
help
help
Those instructions leave out a lot of information, like the fact that you’d need a webserver already running (as just one example). But regardless, you won’t be able to install this on SCALE directly–you’d need to create either a virtual machine or a sandbox, and then install the software in that environment. Creating the VM or sandbox is something we can help with, but you’re going to be on your own to install software inside it.
Kodbox docker and docker compose
https://hub.docker.com/r/kodcloud/kodbox
Demo/tutorial for setting up a sandbox for running docker compose stacks
Thanks, I haven’t had much time to investigate further but I understand that I can have KODBOX installed using docker compose.
any guide to configure docker compose in truenas scale?
Could you guide me on how to configure kodbox once I install docker compose?
thank you
The Sandboxes/Jailmaker video is that.
The internet/youtube is crawling with guides for using compose.
I managed to have a dock thanks to the video
but I’m stuck on a variable that doesn’t allow kodbox to run
. Could you help me
to identify what needs to be configured?
I attach an image of my problem
Thank you, I have managed to run Kodbox, through your tutorial and extra help from Reddit users, but my second objective is to ensure that Kodbox can manage some datasets as well as this video.
kodbox file nas manager
at minute 22:56 to minute 26:45 it is about kodbox running in unraid and managing some folders on the local host.
I would like to achieve the same but in TRUENAS SCALE
Could you help me?
