Need Help Understanding ZFS Expansion
In a few months, I am looking at making a DIY NAS. I don’t plan on buying all the HDDs up front (considering the prices lately…), and was planning on going with UNRAID. I have since learned that TrueNAS SCALE either has or is planning to release the ability to expand RAIDZ storage pools.
I am very interesting in utilizing TrueNAS, but want to make sure this is something I can do.
I did a quick test with VMware Player, and I saw that under Storage in 25.04, there’s an “expand” option, but I am unsure if it does exactly what I’m looking for - adding a drive to expand capacity as necessary. However, the “expand” options I’m seeing talk about “rewriting” the data to get the full capacity.
Is the option to expand a ZFS pool now a thing where I can add drives as needed? I was planning on buying four upfront, and then adding two more as time went on, that way I could set it up with RAIDZ2 up-front, and take time to get money for the other two drives.
If anything, I may just wait an extra month or so and just buy all six drives at once.
Thank you.
Yes, it’s been released since 24.10.
The only storage layouts that can be expanded are raidzx (x= 1,2 or 3) but not mirrors
But there is still a drawback to raidz expansion which is discussed at length here
TLDR (as i understood it) the data written after expansion gets written with a different parity ratio then the old data was written with, which leads to a falsly displayed available space.
