I moved my server from a double NAT setup (TP-link Decos connected to the Telus router) to directly into my Telus router and now it is refusing to get internet. It won’t do things like a general update or load apps. I’ve been playing with the network settings with no joy.
I’m able to connect to it locally through the router but this is what the apps section looks like:
Here are some of the alerts it gives:
And trying to update gives this error:
Summary
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1317, in _create_direct_connection
hosts = await self._resolve_host(host, port, traces=traces)
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 971, in _resolve_host
return await asyncio.shield(resolved_host_task)
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1002, in _resolve_host_with_throttle
addrs = await self._resolver.resolve(host, port, family=self._family)
File “/usr/lib/python3/dist-packages/aiohttp/resolver.py”, line 38, in resolve
infos = await self._loop.getaddrinfo(
File “/usr/lib/python3.11/asyncio/base_events.py”, line 868, in getaddrinfo
return await self.run_in_executor(
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3.11/socket.py”, line 962, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
The above exception was the direct cause of the following exception:
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py”, line 323, in process_method_call
result = await method.call(app, params)
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py”, line 40, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 883, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 703, in _call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 596, in run_in_executor
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 178, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/update.py”, line 105, in get_trains
trains_data = self.middleware.call_sync(‘update.get_trains_data’)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1002, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1042, in run_coroutine
return fut.result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 449, in result
return self.__get_result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 401, in _get_result
raise self.exception
File "/usr/lib/python3/dist-packages/middlewared/plugins/update/trains.py", line 63, in get_trains_data
**(await self.fetch(f"{self.update_srv}/trains.json"))
File "/usr/lib/python3/dist-packages/middlewared/plugins/update/trains.py", line 25, in fetch
async with client.get(url) as resp:
File “/usr/lib/python3/dist-packages/aiohttp/client.py”, line 1359, in aenter
self._resp: _RetType = await self._coro
File “/usr/lib/python3/dist-packages/aiohttp/client.py”, line 663, in _request
conn = await self._connector.connect(
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 563, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1032, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/lib/python3/dist-packages/aiohttp/connector.py”, line 1323, in _create_direct_connection
raise ClientConnectorDNSError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorDNSError: Cannot connect to host update.ixsystems.com:443 ssl:default [Temporary failure in name resolution]
I looked around at others that had similar issues and they mentioned that their system clock had gone out of sync. I checked mine and it’s accurate.
I’m stumped. Any help would be appreciated.
Thank you.
