Hello, This is my first post here so I’ll do my best to supply you with as much information as I can to make this easier.
Problem: The interface I use for iSCSI connections is set to DOWN and I can not bring it back up. I get 100% packet loss when pinging the address I assigned to the interface from all sources.
You should also note, this connection is a direct line from my TrueNAS box to my desktop via 10gb Twinax. My desktop interface is configured to 10.10.10.1 The TrueNAS interface is set to 10.10.10.2/2
Also to be clear, this has worked for quite some time, just yesterday when I booted the trueNAS box up everything looked normal it gave me the option to view the webui from https://10.10.10.2/ (it didn’t work but it was listed in the “The Web user interface is at:”)
I have checked and triple checked the settings are correct on both systems, also since both systems use Intel(R) Ethernet Server Adapter X520-2’s which are dual port, I tried using the other port disabling the one not in use.
Here is a ifconfig -a dump
root@truenas[~]# ifconfig -a
ix0: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: 10gbtwinax
options=4e53fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
ether 90:e2:ba:cb:6f:20
inet 10.10.10.2 netmask 0xc0000000 broadcast 63.255.255.255
media: Ethernet autoselect
status: no carrier
ix1: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 90:e2:ba:cb:6f:21
status: no carrier
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether fc:aa:14:9d:02:50
inet 192.168.0.24 netmask 0xffffff00 broadcast 192.168.0.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
ix0 is the interface in question.
Thank you for your time and please advise if you require any additional information.
