New RAIDZ2 array failures move between disks. Please Help
Appreciate the recommendations.
Update:
badblocks has finished with 0/0/0 errors. I also ran a smart long on the rest of the drives and everything looks good. So maybe a cosmic ray hit my box at the time I created the Z2 pool but the plan now is to completely reload TrueNAS, create a new RAIDZ2 pool with all 8 drives, and the new pool for 24-48 hours. Still seems a bit odd to me but sometimes thats how things go. I figure after a create the new pool if I write 50TB of bunk data and then run a scrub that should hopefully put enough stress on the system the bring out any errors if they are going to happen again.
SMART info the the suspect drive after running badblocks:
truenas_admin@nas[~]$ sudo smartctl -a /dev/sdg
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Ultrastar DC HC530
Device Model:     WDC  WUH721414ALE6L4
Serial Number:    9MGBVN0T
LU WWN Device Id: 5 000cca 290c5641b
Firmware Version: LDGNW400
User Capacity:    14,000,519,643,136 bytes [14.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Nov 16 14:37:10 2024 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  101) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1400) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   001    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   137   137   054    Pre-fail  Offline      -       92
  3 Spin_Up_Time            0x0007   096   096   001    Pre-fail  Always       -       159
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       9
  5 Reallocated_Sector_Ct   0x0033   100   100   001    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   001    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   128   128   020    Pre-fail  Offline      -       18
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       63
 10 Spin_Retry_Count        0x0013   100   100   001    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       9
 22 Helium_Level            0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       49
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       49
194 Temperature_Celsius     0x0002   063   063   000    Old_age   Always       -       32 (Min/Max 20/58)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%         9         -
The above only provides legacy SMART information - try 'smartctl -x' for more
Update 3:
And the mystery continues. After running badblocks on one of the suspicious drives and coming up with zero errors I reloaded TrueNAS and wrote about 20TB of bogus data. This morning I kicked off a scrub which faulted two of my drives, one of which being the 9MGBVN0T drive, I checked SMART and it reports nothing bad. Does anyone have any thoughts on this? I am going to try and RMA the drives but I have a feeling they are going to tell me to pound sand because all the other tests I’ve run clearly show there aren’t any problems.
Since it’s been discussed before I am going to install a larger PSU tomorrow in case that is contributing but I would think the power/stress required to write 20TB would be about the same for a scrub. I also hooked up a kill-a-watt which shows it’s currently consuming ~150 watts so I really don’t think it’s the issue but at this point I am grasping at straws here and willing to try anything.
Output of zpool status
        NAME                                      STATE     READ WRITE CKSUM
        spinners                                  ONLINE       0     0     0
          raidz2-0                                ONLINE       0     0     0
            90559c5a-b761-4204-816b-0e8cc7cd9506  FAULTED    791   890     0  too many errors
            41ff962a-64e4-452a-92b0-d0285ea73282  ONLINE       0     0     0
            3fd69d0f-4e75-47c6-a5c1-b419418d2431  ONLINE       0     0     0
            6fcd9e15-28e2-4d9d-92b7-2959e87c3c16  ONLINE       0     0     0
            311f270b-7938-4796-b271-d294f6de14a2  ONLINE       0     0     0
            fc6432da-a266-4c15-b0e6-6b4b30dd7172  ONLINE       0     0     0
            892ad932-9cba-47d4-a19d-a883f8a31a19  FAULTED  1.55K 1.67K     0  too many errors
            e284540f-4563-44b2-baa6-fcdf66ecea9d  ONLINE       0     0     0
The faulted drive above with 1.55k read errors maps to the 9MGBVN0T drive. Here’s the SMART data for the 9MGBVN0T drive after starting the scrub and faulting the pool.
Local Time is:    Sun Nov 17 06:02:22 2024 PST
Offline data collection status:  (0x80) Offline data collection activity
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  3 Spin_Up_Time            0x0007   092   092   001    Pre-fail  Always       -       318
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       14
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       79
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       14
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       60
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       60
No Errors Logged
tl;dr drives run just fine until I do a scrub. Right after scrub starts drives go to faulted. Please help.
I only see a single short smart test in the log you posted, run a long one.
Nevermind, I see you have tried but it doesn’t get logged.
Surely you should be able to RMA the drive based on that alone.
Any chance it is the wires? Moving them around make any changes on which disks are considered degraded?
Good call! I’ll give that a try today.
Checksum errors on a drive withour SMART finding anything wrong could be issues with the controler and/or cables.
Someone recently reported he had eventually pinpoined drive errors to… a fan being powered from the same rail as the drives: Moving the fan to a different power cable put an end to drive errors. Do not neglect anything…
Thanks for the pointers.
Other than the drive backplane the only other thing plugged directly into the PSU is the motherboard. Previously I had the fans at the rear of the backplane plugged into the mobo but I’ve since moved them back to being powered from the backplane as when the were on the mobo one of them was only spinning at 400 rpm.
I’ve got new SAS cables and power supply (Corsair RM750e, the same that is used in the 45 Drives HL15) ordered as of today.
I am currently running SMART long on the 9MGBVN0T drive as the rest of them have completed and did actually log to SMART, though I don’t expect there to be an issue here as all of the SMART data looks fine to me.
While I wait for cables and PSU I am going to do as Fleshmauler recommended and swap the drives around after the SMART test concludes, then I will clear the ZFS errors, initiate another scrub (that seems to be what triggers the failures), and see if the errors follow the drive or the slot. I may also take the drives out of the backplane and directly connect them to SATA cables after this test as well just to rule out the backplane itself.
Based off all the smart data and running of badblocks on one the 9MGBVN0T drive I feel like the problem has to be an underlying hardware issue and nothing to do with the drive…but at I guess we’ll see where the troubleshooting goes. It really is slow going once you graduate to larger drives.
I had a high-quality PSU with 500 W for a while with 8 drives and it caused many problems. Since switching to 750 W everything is fine. Also PSUs age, so having some buffer is advisable.
For comparison: I have an old Dell PowerEdge R440 which has a dual 1200 W PSU. Yes it has 2 CPUs, but the 8 drive bays are 2.5".
Update 4:
Moved the drives around and run a scrub and the failures didn’t follow the backplane slots AND it is two totally different drives marked as faulted this time.
Luckily I’ve got a new PSU and SAS cables being delivered today. Going to swap those out and try one more time. If i still get failures I plan on trying the drives outside of the backplane.
Talk about a small project gone south; I am riding the struggle bus with this one.
Final update:
It appears to be stable now. I replaced both the PSU and the SFF-8482 to SATA cables at the same time so I’ll never really know which was the root cause but at this point I am over it.
I just wanted to thank everyone who commented again for their assistance.
I am coming back 1.5 years later just to give you credit. That Silverstone case, while it wasn’t my issue, is a furnace. With the record heat this summer I’ve had drives hit 59c.
So you were right and Silverstone is out. :slight_smile:
Thanks for that! Especially as I should have done a better job in the first place and document the bad experience from which my contempt for Silverstone cases originates.
