New to TrueNas Scale: Will my build work?
I have this board for a completely different use-case (not a NAS) with a 12700k & ecc ram - I had stability & boot issues on newer bios versions & had to go all the way down to BIOS Version: 3101 (pretty old) to get things to boot properly. (after BIOS downgrade I’ve been stable for the last 179 days with no issues booting… that I remember from like I guess 6 months ago)
12900k is wayy overkill. Grab some more ram if you can.
Realistically you can likely save money on a used enterprise board since this isn’t 24/7 operations & power usage likely won’t be a major issue. This path also be nice since it would have built-in bmc (the add in card for bmc on the Pro W680 is a pain).
tldr; cpu/motherboard are too expensive for your specified usecase!
wow, I thought this is a friendly forum?
Why do you think that I am not changing my build?
I already changed the RAM (thanks to recommondations), reduced the overkilled Intel CPU, looking into externel SAS devices, etc…
I think that I am very friendly in every post and every feedback that i get.
So please keep your anger to yourself. thank you.
Well, compared with many others who posted after buying and were only seeking for validation, OP here asked for confirmation before buying—as should be.
There’s no written or unwritten rule that newcomers should pay feudal respect to the forum elders and heed everything the elders say. (Even though that would be nice for our egos…)
I do no think I have fully wasted my time here doing a round-up of the current DDR5 UDIMM solutions… and why I’d personally go for whatever good deal can be grabbed at the moment with DDR4 ECC UDIMM over DD5 if I were to make the build.
@Protopia:
First sentence of the FAQ: “Please treat this discussion forum with the same respect you would a public park.”
Someone like you, with so many posts, should know this and do better.
If you want to “complain” about my build, you can do so, but in a “nicer” way.
You want discussions and newcomers on this forum? Do you think that such a post like from you will help achieving this?
And by the way: Shortly before your “gruel” post, @Fleshmauler mentioned a problem with my choice of mainboard. So I am looking even further to changing my build :p.
Nevertheless, I will end my forum adventure now. I don’t want to discuss with high-posting-people, if i am a “f***ing” … something. That’s not my style. Look at all my posts so far. Every 2nd line I appreciate feedback and say “thank you”.
Good look with other newcomers in this forum, if people like @Protopia is acting like that.
So you, @Protopia, don’t need to block me. This will be my last post.
To all other posters in this thread: THANK YOU very much for your feedback and time! I will use your feedback.
The build will work (minding the RAM issue). Is it overkill? Yes. But do what makes you sleep at night :slight_smile:
If you are after reliability then I’d recommend going for an X13SCL-F or X13SCH-F. These are quality motherboards designed for 24/7 operations in addition to having IPMI so you can manage the server from the comfort of your chair.
So that is why I believed that you were not listening. However if I got the wrong end of the stick I apologise wholeheartedly.
It is absolutely not my intent to create the sort of environment that makes people want to stay away.
What can I say? I had a bad day and let my frustrations elsewhere spill over here - which I absolutely shouldn’t have.
But I did genuinely get the impression from what you said that you had decided to go ahead with your original build regardless of other people’s advice. And I fully accept that I was wrong.
