Hi everybody,
I am Chris from Germany and new to the world of TrueNas. After being a long-term Synology user, I want to switch to TrueNas Scale and, therefore, build my own system.
I hope that I will get some feedback, if my build will work for the newest version of TrueNas Scale.
What is the porpuse of my system?
I want to be future-proof / expandable. My system should be able to work for the next 10 years (I will only switch it on a few times per month, no 24/7 operation).
I will use it as data-storage / backup, no VMs or Docker.
What I think about my system?
Maybe it is “overkill” (from a hardware / performance point of view). However, I want to build it one time and it should last 10 years with the option to add more harddrives at a later stage. So I am willing to “outperform” data-storage use cases for the sake of convenience and to know that it will also perform later on, if i add more storage.
My system:
Case:
Fractal Design Define 7 XL BK (is able to accommodate 18 harddisks).
Mainboard:
Asus Pro WS W680-Ace (Workstation-Mainboard, ECC-Support, 1x SlimSas, 4x SATA → with the right cable from SlimSas to SATA, I should be able to connect 8 harddisks)
CPU:
Intel Core i9-12900K (maybe overkill)
RAM:
2x Micron RDIMM 16GB, DDR5-4800, reg ECC and on-die ECC
Power Supply:
Seasonic Vertex PX-1000 ATX 3.0 1000 Watt (has 18 SATA connectors)
Harddisks:
For now: 6x Seagate Ironwolf Pro 22 TB (which will be 1 vdev with RaidZ2).
For the future: Enough place in the case and support by power supply to add 2 additional vdevs with 6 HDDs each (so 18 HDDs total in 3 vdevs).
I know that I will need an additional Host Bus Adapter - Card for additional SATA-Connectors, if I add more drives. However, for the 6 HDDs to start with, I will only use the mainboard connectors.
I want to have a reasonable silent system, therefore I will only use Noctua fans.
Now the big questions:
Is my build compatible with TrueNas Scale?
Do I miss something in my thinking process?
Any feedback / information is very welcome :-).
Thank you and best regards,
Chris from Germany
