stuck at
Tried on 2 different machine, both using RYZEN cpu…
Trully no idea why
Anything helps
stuck at
Trully no idea why
Anything helps
Nevermind… waited 5 mintues, and able to continue to login page with 23.10.2 installation… Currently trying updating it to 24.04.0 to see what happens
It works… This makes no sense
. Where and how can I report this bug?
Well. It takes longer for the web server serving the gui to startup, so what the text really means is “will be at:”
Not exactly, the system that I fresh install 24.04.0 is still stuck at the same Connecting to TrueNAS page even until now. I just let it run to see what’s going to happen.
I think there were some report with fresh installs of dragonfish where the middlware would not load or hang while loading. If you can connect a keyboard and monitor to the box and try to restart the middleware from the buildin shell it could maybe fix your problem…
