Newbie - Unassigned Disks? + SMB set up
I think I am having the same issue. I already noticed it on Cobia 23.10.2 and hoped it would go away after upgrading to Dragonfish 24.04.1.1.
My NAS has two pools (3x18TB HDDs + 2x500GB SSDs).
The pools are healthy as shown by zpool status:
# zpool status
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:39 with 0 errors on Sat Jun  1 03:45:41 2024
        NAME         STATE     READ WRITE CKSUM
        boot-pool    ONLINE       0     0     0
          nvme0n1p3  ONLINE       0     0     0
errors: No known data errors
  pool: hdd_raidz1
 state: ONLINE
  scan: scrub repaired 0B in 17:26:02 with 0 errors on Wed May 15 18:26:06 2024
        hdd_raidz1                                ONLINE       0     0     0
          raidz1-0                                ONLINE       0     0     0
            ata-ST18000NM003D-3DL103_ZVTB4R5Q     ONLINE       0     0     0
            ata-TOSHIBA_MG09ACA18TE_6260A3SCFG0H  ONLINE       0     0     0
            ata-TOSHIBA_MG09ACA18TE_6260A1VKFG0H  ONLINE       0     0     0
  pool: ssd_mirror
 state: ONLINE
  scan: scrub repaired 0B in 00:07:38 with 0 errors on Fri May 10 01:07:41 2024
        ssd_mirror                                ONLINE       0     0     0
          mirror-0                                ONLINE       0     0     0
            fb3269db-3bcc-431c-9714-a6ad79ea3cf1  ONLINE       0     0     0
            a7b3ea94-9044-42ea-bc18-97caa4390d1b  ONLINE       0     0     0
I also find the output of lsblk -o name,model,serial,partuuid,fstype,size normal-looking:
# lsblk -o name,model,serial,partuuid,fstype,size
NAME          MODEL                  SERIAL             PARTUUID                             FSTYPE       SIZE
sda           CT500MX500SSD1         2104E4EC9620                                                       465.8G
|-sda1                                                  1b25b5b6-61c6-443a-82e8-7cc99f10e0f4                6G
`-sda2                                                  a7b3ea94-9044-42ea-bc18-97caa4390d1b zfs_member 459.8G
sdb           ST18000NM003D-3DL103   ZVTB4R5Q                                                zfs_member  16.4T
sdc           CT500MX500SSD1         1843E1D3333B                                                       465.8G
|-sdc1                                                  856debac-b14c-4999-8468-d3fdfcc1b5a9                6G
`-sdc2                                                  fb3269db-3bcc-431c-9714-a6ad79ea3cf1 zfs_member 459.8G
sdd           TOSHIBA MG09ACA18TE    6260A1VKFG0H                                            zfs_member  16.4T
sde           TOSHIBA MG09ACA18TE    6260A3SCFG0H                                            zfs_member  16.4T
zd0        60G
zd16        60G
zd32        100G
zd48        100G
nvme0n1       Patriot M.2 P300 128GB P300ADBB2303082206                                                 119.2G
|-nvme0n1p1                                             6fa3c15e-82d0-4157-ac41-b23f3aee4ea6                1M
|-nvme0n1p2                                             c50ddbbf-59e5-483d-9cc4-e85e9ce80f2d vfat         512M
|-nvme0n1p3                                             d761a7ec-041b-4ad3-b105-71aa31df6ead zfs_member 102.7G
`-nvme0n1p4                                             86edab8d-f33d-4ba6-bf24-dc5887eae886               16G
  `-nvme0n1p4        swap          16G
Any idea why GUI could show the drives that way?
Not quite.
If you click through using the “Add Disks” button you get a followup screen that asks you to provide additional details. That screen also includes a “Manual Disk Selection” button that lets you see more information about the available disks.
I posted a bug. The team was pretty quick to respond but they decided not to fix this bug. So, we’ll have the GUI showing unassigned disks for the time being.
I expect what’s happening is a discrepancy between how TrueNAS expects pools to be created (which is using PARTUUIDs) and how they actually were created (which in the case of both systems reporting problems in this thread is using /dev/disk/by-id identifiers).
I expect you’d be able to resolve this using the following steps:
  • Export the pool in question via the GUI. Do not destroy data or disable services using it.
  • From the shell as root, zpool import -d /dev/disk/by-partuuid/ poolname
  • zpool status poolname, look at the pool in question, and see that it’s showing the UUIDs
  • zpool export poolname
  • Import the pool using the GUI.
If my suspicion about the cause of this problem is correct, this would resolve it.
Has anyone tried this yet? Sounds promising.
I’ll see your -d /dev/disk/by-partuuid/ and raise you a -o altroot=/mnt :wink:
And I’ll save you some keystrokes with -R /mnt
Thanks for the additional help here.
@TheColin21 I haven’t tried @dan 's recommendation.
I got stuck at the zpool import -d /dev/disk/by-partuuid/ poolname as the command lsblk -o name,model,serial,partuuid,fstype,size doesn’t give me the partuuid. It appears that your 3 disks also are missing this. It was working, albeit with the “Unassigned Disk” notice, so I left it and then life got in the way.
With @pmh and @winnielinnie providing some additional suggestions, I got the reminder. And alas I have an hour while I’m in the penalty box with my wife. :upside_down_face:
I’m going to try and figure it out now.
Hmmm.
I’ve tried using sudo blkid but both the 8TB disks show only UUID and UUID_SUB and that they are zfs_member. There is no partuuid.
Similarly sudo sgdisk -i 1 /dev/sdb shows Partition #1 does not exist. Similar when I tried with -i 0.
So it would appear that the two disks in my Pool1 have no partitions???
If that’s the case I can’t try @dan 's suggestion.
I’m completely confused.
I’m about to replace the 8TB drives with 12TB drives but maybe I should wait until this is figured out?
