Nextcloud and Collabora Integration
This resource was originally created by user: Basil Hendroff on the TrueNAS Community Forums Archive. Please DM this account or comment in this thread to claim it.
Collabora and OnlyOffice are popular office suite choices for Nextcloud. This is a collection of notes on how to get Collabora Online Development Edition (CODE) working in Nextcloud behind a reverse proxy on FreeNAS. To realise this, a number of building blocks need to be put together.
Credits
@danb35 : Nextcloud and Caddy resources
@KevDog : Collabora configuration, Docker Compose
Outline of the Steps
Using a Ubuntu VM on TrueNAS CORE:
  1. Install Nextcloud
  2. Set up Nextcloud behind a reverse proxy
  3. Install Ubuntu with Docker and Docker Compose in a FreeNAS VM
  4. Install Collabora using Docker Compose
  5. Set up the Collabora server behind the reverse proxy
  6. Enable and configure the Collabora Online connector in Nextcloud
  7. Collabora Automatic Updates (optional)
Using TrueNAS SCALE:
  4. Deploy Collabora on TrueNAS SCALE
You may be able to cherry-pick from these steps if you already have some of the building blocks in place.
Note: For the purpose of explanation, the steps below assume that the Nextcloud FQDN is cloud.mydomain.com and for Collabora, it is collabora.mydomain.com .
Steps 1 to 3
Refer to the first three steps of the resource Nextcloud and OnlyOffice Integration.
Step 4: Install Collabora using Docker Compose
Change to the home directory cd and create a directory for the Compose file mkdir collabora . Change to the directory cd collabora . Create the Compose file nano docker-compose.yml and paste the following:
version: ‘3.3’ services: code: ports: - ‘9980:9980’ container_name: collabora-code environment: - domain=cloud.mydomain.com - server_name=collabora.mydomain.com - username=admin - password=secret - ‘extra_params=–o:ssl.enable=false --o:ssl.termination=true’ restart: always image: collabora/code
References:
  1. Collabora Online in Nextcloud
  2. Setting up and configuring collabora/code Docker image
  3. Collabora, Nextcloud 11, FreeNAS, Nginx
  4. Requesting address is denied: ::ffff:172.17.0.1| wsd/LOOLWSD.cpp:1971
  5. Composerize
Alter the highlighted entries to suit your environment.
Note: By design, certification services are switched off in the Collabora container. A separate reverse proxy will provide certification services and TLS termination for Collabora. The Collabora server is placed behind the reverse proxy. When configured in this manner, there should be no SSL errors in the server log.
Build and run Collabora CODE with Compose sudo docker-compose up -d .
Q1. How will I know the Collabora server is working correctly, and I can proceed to step 5?
After a restart, it can take a few minutes for the Collabora server to reach a quiescent state. You can monitor the progress of server initialisation using sudo docker logs -f collabora-code to view the server log (Ctrl-C to exit). There are a couple of useful indicators that the Collabora CODE server has started properly:
You know you’re approaching the end of server initialisation when one of the entries towards the end of the log looks something like the following:
wsd-00006-00006 2020-04-12 20:11:19.792294 [ loolwsd ] INF WSD initialization complete: setting log-level to [warning] as configured.| wsd/LOOLWSD.cpp:3536
Next, entering the IP address of the Ubuntu VM and Collabora listening port e.g. http://10.1.1.21:9980 in a browser will return the status OK. Entering curl -k http://10.1.1.21:9980 in a terminal window will do the same thing.
Step 5: Set up the Collabora server behind the reverse proxy
Notes:
  1. In Cloudflare, set up a CNAME record for the subdomain collabora.mydomain.com.
  2. If using Caddy V2, the Caddyfile code block for Collabora will look something like:
collabora.mydomain.com { encode gzip @collabora { path /loleaflet/* # Loleaflet is the client part of LibreOffice Online path /hosting/discovery # WOPI discovery URL path /hosting/capabilities # Show capabilities as json path /lool/* # Main websocket, uploads/downloads, presentations } reverse_proxy @collabora http://10.1.1.21:9980 }
References:
  1. Example: Collabora CODE
  2. Collabora Caddyfile example
For a load balancing example, refer to this post.
Q1. How will I know Collabora is working with a reverse proxy such as Caddy, and I can proceed to step 6?
There are three useful indicators:
  1. Entering https://collabora.mydomain.com/hosting/discovery in a browser will output the contents of an xml file.
  2. You can access the admin console at https://collabora.mydomain.com/loleaflet/dist/admin/admin.html.
  3. Entering https://collabora.mydomain.com/hosting/capabilities in a browser will return text similar to that shown below:
{“convert-to”:{“available”:false},“hasMobileSupport”:true,“hasTemplateSaveAs”:false,“hasTemplateSource”:true,“productName”:“Collabora Online Development Edition”}
Step 6: Enable and configure the Collabora Online connector in Nextcloud
Notes:
  1. Enable the Collabora Online connector under Office & Text applications and configure it as shown below. Do not enable the Collabora Online - Built-in CODE Server.
That’s it. Logging in as a Nextcloud user now gives you access to the Collabora CODE suite including a word processor, spreadsheet and presentation applications. There are also free Collabora mobile (Android and iOS) apps that work with Nextcloud
Step 7: Collabora Automatic Updates
This is an optional step. It is not required for Nextcloud-Collabora integration. What it does is aim to ensure that Nextcloud has access to the latest version of Collabora CODE. A check is done daily for a new version of the Collabora image. If a new version exists, it is downloaded and the Collabora container updated. The old image is then removed.
The following assumes that you’ve adhered closely to step 4 and your Compose file is stored in the Collabora folder within the home directory.
Change to the Collabora folder cd $HOME/collabora . Create the update.sh script nano update.sh and paste the following:
#!/bin/bash date cd “dirname "$0"” docker-compose pull docker-compose up -d docker image prune -f date echo
Reference: CODE docker automatic update
Make the file executable chmod +x update.sh .
Next, we’re going to add a line, that takes the form below, to the system-wide crontab.
m h * * * /path/to/script >> /path/to/log 2>&1
References:
  1. Ubuntu Crontab
  2. Understanding Shell Script’s idiom: 2>&1
Standard and error output will be appended to /path/to/log . By design, the log file will be placed in the Collabora folder as well, so:
/path/to/script = $HOME/collabora/update.sh /path/to/log = $HOME/collabora/update.log
However, we need to use the evaluated version of $HOME for the system-wide crontab. Make a note of what this is echo $HOME .
For example:
screenshot.341
For this example:
/path/to/script = /home/administrator/collabora/update.sh /path/to/log = /home/administrator/collabora/update.log
Edit the system-wide crontab sudo crontab -e and set up the cron job.
The script should be run at a time when it’s unlikely anyone will be using Collabora. In the example below, I’m checking for updates daily at 10 minutes past midnight.
10 0 * * * /home/administrator/collabora/update.sh >> /home/administrator/collabora/update.log 2>&1
If there isn’t an update when the job is run, a typical log entry will look something like the following:
If an update is available, the log entry will instead look more like this:
My Nextcloud server ver 27 was working fine with Collabora integration. When I upgraded to ver 29 I had some issue which lead me to reinstall ver 29 from scratch. I restored my files from a backup and everything is work except the Collabora integration.
With the new version I had to use the Nextcloud Office app and choose my own server. collabora.mydomain.com The same one I was using before that worked.
In step 5, There are three useful indicators: 1 and 3 return the correct output but not #2. I can’t reach the admin console. My guess it has to do with the caddyfile in my caddy reverse proxy.
My nextcloud office app has the error
Your browser has been unable to connect to the Collabora server: https://collabora.mydomain.com
This URL is determined on the Collabora server either from the configured URL or the server_name parameter in coolwsd.xml.
My Caddyfile
	#  acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
	email myemail@gmail.com
mydomain.com {
	root * /usr/local/www/html/
	file_server
	header {
		enable HSTS
		Strict-Transport-Security max-age=31536000;
cloud.mydomain.com {
	encode gzip
	reverse_proxy http://192.168.5.81
	header {
		enable HSTS
		rewrite /.well-known/carddav /remote.php/dav
		rewrite /.well-known/caldav /remote.php/dav
		reverse_proxy {$NEXTCLOUD_HOST:localhost}
	encode gzip
	@collabora {
		path /browser/* # Browser is the client part of LibreOffice Online
	reverse_proxy @collabora http://192.168.5.89:9980
My TrueNAS is 13.0-U5.1
My Caddy ver 2.6.2
Can someone confirm that I’m correct and there is an issue with my Caddyfile for collabora and any possible fix?
The collabora part seems correct. Can you visit your domain and get to Collabora outside of Nextcloud?
Do you prefer collabora?
I’ve built a script that installs OnlyOffice.
Scripted OnlyOffice Installation (TrueNAS CORE)
I rebooted the Truenas server and now collabora works with nextcloud. Crazy. Still can’t access the admin panel step 5 #2.
I prefer collabora as it allows free access to documents on my iphone.
You’re referring to access through the nextcloud app? I’ve never had issues with OnlyOffice.
I set this up when Basil originally wrote it and if I remember correctly iPhone access was something you had to pay for with only office. Guess it has changed.
Did a fresh install,
ElectricEel-24.10.1
NPM also runs on this host. i added :
collabora.domain.eu → 192.168.1.5:9980
nc1.domain.eu → 192.168.1.5:32007
NPM has *.domain.eu and www.domain.eu let’s encrypt certificates.
nc1.domain.eu = nextcloud and works (https also)
collabora.domain.eu = collabora (https also)
I can open nextcloud and edit the settings for ‘office’ and add :
https://collabora.domain.eu:9980 and save it.
but weirdly it shows ‘URL used by the browser’ as empty.
Nextcloud URL used by Collabora: https:\\nc1.domain.eu:30027.
Connection seems to be working, and i can open:
https://collabora.domain.eu/browser/dist/admin/admin.html#
and login.
But when i try to open a file it loads forever and i see no activity on the collabora admin page. ‘Document loading failed’. I’m kinda stuck here.
Nextcloud log shows no errors.
Another strange thing, when i click the ‘nextcloud logo’ it goes to my truenas login. But when i mouse-over it does say ‘nc1.domain.eu:32007’
What i tried :
  • Added 192.168.1.5 to trusted proxies (NPM)
  • Added 192.168.1.* to trusted domains
  • used shell to edit /etc/hosts and add 127.0.1.1 collabora.domain.eu
any ideas?
