Nextcloud + Collabora on TrueNAS Scale using Apps
Greetings,
As an experiment, I am considering upgrading my TrueNAS Core to Scale.
As of now, I have a few iocage jails, which I would need to get rid of and install the following as Apps instead, in Scale:
Nextcloud
Collabora
Reverse Proxy (currently an nginx server running in a jail).
And then my Let´s Encrypt certificates:
[cloud.mydomain.com]
[office.mydomain.com]
So, I have set up TrueNAS Scale on a separate box, to test with, before I start messing with my “real” server. I have the Nextcloud and Collabora apps installed, which went very smoothly by the way (not much config done. maybe need to add something?). But now I am a little stuck when it comes to proxies and certificates.
I have been reading articles and forums for a couple of days, but I can´t really get it sorted. Could someone point me to a great guide for doing this?
I have added the TrueCharts catalog, and also installed the Traefik app. Looking at Cert-Manager and ClusterIssuer, but can´t figure out how to configure them.
Am i on the right track? Could someone outline the steps for me? Or point me in the right direction if I´m off course?
I don’t use Traefik for ingress but Caddy directly on my OPNsense firewall so I can not offer any insight in that regard. You might want to head over to the TrueCharts Discord for TrueCharts support.
This is exactly what I am trying to do, but I am stuck. I am attempting to do it with the official TrueNAS apps as Truecharts is now deprecated and moved away from the platform due to TrueNAS moving to Docker from Kubernetes.
If you’re on electric eel and use the new docker apps you should be able to add traefik labels to the apps. Label support was added a couple of months ago.
