Nextcloud, HTTPS wrong redirection
If the Nextcloud app is installed without a certificate, everything works fine. However, if the app is installed with the same settings and a certificate, the browser constantly redirects to the TrueNAS dashboard page. What is the reason for this?
Nextcloud App, Certificate ID:
  • No Certificate
  • ‘truenas_default’ Certificate
HTTP, No Certificate, everything OK
http://172.19.50.54:30027 => redirect to => http://172.19.50.54:30027/login
http://172.19.50.54:30027/login => stays on website => http://172.19.50.54:30027/login
HTTPS, ‘truenas_default’ Certificate, wrong redirection
https://172.19.50.54:30027 => redirect to => https://172.19.50.54/ui/sessions/signin
https://172.19.50.54:30027/login => redirect to => https://172.19.50.54/ui/sessions/signin
System Information
Platform: Generic
Version: ElectricEel-24.10.1
Nextcloud
App Version: 30.0.4
Version: 1.5.13
Problem Solved
When installing the Nextcloud app:
  1. Leave the “Host” field empty.
  2. Set the “Certificate ID” to “truenas_default Certificate”.
After installation:
  1. Navigate to the configuration folder of Nextcloud (“Host Path Configuration”).
  2. Go to the “config” subfolder.
  3. Edit the “config.php” file (use sudo nano config.php).
  4. Add the following line, replacing YOUR_IP and YOUR_PORT with your specific IP and port:
'overwritehost' => 'YOUR_IP:YOUR_PORT',
  1. Add your IP to the ‘trusted_domains’ array. The modified section will look like this:
'trusted_domains' =>
array (
  0 => '127.0.0.1',
  1 => 'localhost',
  2 => 'nextcloud',
  3 => 'YOUR_IP',
I’m having the exact same issue. For me this did not fix it.
Where exactly did you enter the ‘overwritehost’ part in the config.php file? No matter where I put the phrase it will not work.
Same issue here.
Hi, here is my config.php. When installing the Nextcloud app leave the “Host” field empty!
<?php
$CONFIG = array (
  'htaccess.RewriteBase' => '/',
  'memcache.local' => '\\OC\\Memcache\\APCu',
  'apps_paths' =>
  array (
    0 =>
    array (
      'path' => '/var/www/html/apps',
      'url' => '/apps',
      'writable' => false,
    1 =>
    array (
      'path' => '/var/www/html/custom_apps',
      'url' => '/custom_apps',
      'writable' => true,
  'memcache.distributed' => '\\OC\\Memcache\\Redis',
  'memcache.locking' => '\\OC\\Memcache\\Redis',
  'redis' =>
  array (
    'host' => 'redis',
    'password' => 'xxxxxxxxxx',
    'port' => 6379,
  'overwriteprotocol' => 'https',
  'trusted_proxies' =>
  array (
    0 => '127.0.0.1',
    1 => '172.19.0.0/16',
    2 => '172.16.0.0/12',
    3 => '10.0.0.0/8',
  'upgrade.disable-web' => true,
  'passwordsalt' => 'xxxxxxxxxx',
  'secret' => 'xxxxxxxxxx',
  'datadirectory' => '/var/www/html/data',
  'dbtype' => 'pgsql',
  'version' => '30.0.5.1',
  'overwritehost' => '172.19.50.54:30027',
  'overwrite.cli.url' => 'https://172.19.50.54:30027',
  'dbname' => 'nextcloud',
  'dbhost' => 'postgres:5432',
  'dbport' => '',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'oc_admin',
  'dbpassword' => 'xxxxxxxxxx',
  'installed' => true,
  'instanceid' => 'xxxxxxxxxx',
  array (
    0 => '127.0.0.1',
    1 => 'localhost',
    2 => 'nextcloud',
    3 => '172.19.50.54',
This did the trick, thanks! If anyone tries this out and your container crashes on the first run just wait a minute and it should start itself again.
