Nextcloud not working with a domain it should
Hello all!
I have a local network with a mesh 192.168.68.1/24 cabled to a modem 192.168.15.1/24, and a TrueNAS Scale 24.10, Tailscale, NPM, and NextCloud on ip 192.168.68.68 named ada. No SSL involved for this while.
I recently tried to make a weird setup with SSL that pretty much didn’t work, so I decided to step back to a stage where things work with ports alone and no SSL (so NPM is actually doing nothing and has empty config).
I got Tailscale properly config’d for no HTTPS, so I can properly access both through 192.168.68.68, ada and ada.alpha-centauri.ts.net almost everything: webadmin on :80, nginx admin on :30020, NextCloud on :30027 and even my weird subversion setup on :3690.
Except for one thing: NextCloud won’t accept login through ada.alpha-centauri.ts.net. It won’t give “not trusted domain” messages or else. It will just :arrows_counterclockwise: for half second and I’ll be still on the login page. If I login through 192.168.68.68, tailscale’s ip, ada, it will work perfectly.
NextCloud docker log for the event is this:
2025-03-09 16:34:20.658522+00:00172.16.2.1 - - [09/Mar/2025:16:34:20 +0000] "POST /login HTTP/1.1" 303 1910 "http://ada.alpha-centauri.ts.net:30027/login?direct=1&user=dandrea" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36 Edg/134.0.0.0"
2025-03-09 16:34:20.720773+00:00172.16.2.1 - - [09/Mar/2025:16:34:20 +0000] "GET /login?direct=1&user=dandrea HTTP/1.1" 200 8488 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36 Edg/134.0.0.0"
2025-03-09 16:34:21.530861+00:00127.0.0.1 - - [09/Mar/2025:16:34:21 +0000] "GET /status.php HTTP/1.1" 200 1068 "-" "curl/7.88.1"
Relevant info on ./config/config.php (I erased some critical lines):
<?php
$CONFIG = array (
  'htaccess.RewriteBase' => '/',
  'overwrite.cli.url' => 'http://ada.alpha-centauri.ts.net/nextcloud',
  'preview_imaginary_url' => 'http://imaginary:9000',
  'overwriteprotocol' => 'http',
  'trusted_proxies' =>
  array (
    0 => '127.0.0.1',
    1 => '192.168.68.68',
    2 => '192.168.0.0/16',
    3 => '172.16.0.0/12',
    4 => '10.0.0.0/8',
  'trusted_domains' =>
  array (
    0 => '127.0.0.1',
    2 => 'ada',
    3 => 'ada.alpha-centauri.ts.net',
    4 => 'ada.local',
    5 => 'localhost',
    6 => 'nextcloud',
I got no idea on how to debug this.
No experience on my side…
Docs indicate the trusted domain is about where the Nextcloud is being accessed from.
What is the domain of the client?
It is in the same domain the client is, as the domain alpha-centauri.ts.net is only available when Tailscale is running with my credentials here.
Can you test with a local client and no tailscale… it just eliminates an abnormal variable.
No, I can’t. It works with other domains and the faulty domain disappears if tailscale is removed.
So, can you summarize that it is just an issue with tailscale domains??
(put tailscale in the title if that is the case)
Perhaps tailscale should be set-up independently of the domains.??
Has anyone else configured a similar system?
