Hi everyone.
I’m looking for some help in a particular issue I myself can’t figure out.
I have installed nextcloud without issue, ddns server in ‘services’ in truenas, installed a certificate via certbot. I port forwarded 80 and 443 to my nextcloud IP 192.168.1.99. I have added my ddns and local nextcloud IP to trusted_domains - and everything works like a charm! I can now access nextcloud on LAN and WAN through my ddns.
Now to the issue - after implementing these configurations, I can no longer access my router locally (Linksys) which should be at 192.168.1.1 or myrouter.local. These addresses both send me to nextcloud, which should only be at …99 and xyz.ddns.net
what has happened and how to I fix it?
EDIT: applying DMZ to nextcloud 192.168.1.99 seems to work just fine btw… But not just port forwarding 80 and 443 to 192.168.1.99… hmm
Probably something to do with hairpin NAT. The problem is that because you forwarded the ports, any domain you type than is resolved to your router will end up being forwarded to you nextcloud. Try setting your router port to 8443 or something and see if you can access it that way.
Yeah true it’s an easy set up mesh, but port forwarding shouldn’t be a problem… I will give it a few more tries, then replace it if there’s no work around.
These are the port forward settings (disabled at the moment because of the issue). There is no other port forward rules enabled.
No it’s either only router or only nextcloud however I do it… Unless I use DMZ on …99 - then it works fine, but I don’t know if I’m comfortable with that.
Removing port forwarding and only using DMZ on 192.168.1.99 works as intended, yes. But it doesn’t feel safe since I guess it allows all incoming traffic
I’d recommend investing in some hardware and installing something like pfsense on there. Or you could virtualized it in a VM if you have the know how.
But as I’m seeing it, it looks like you’ll have to change your DNS somehow.
What you could do is run a reverse proxy and forward all the traffic there. That way you can route the traffic based on DNS names. So xyz.ddns.com will go to your router and xyzxyz.ddns.com can go to Nextcloud.
If you’re running CORE, you can set up a jail using
