Hello, I have installed a new install of Truenas Scale Electric Eel. I have successfully installed Plex and Nginx Proxy Manager but am having install issues with Nextcloud. I have set my Datasets which are empty. Every time I install it stops at about 80% with an error. I have looked all over the internet, but all that are posted does not relate to my problem. When installing I get this error
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 509, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 556, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1367, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1364, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 268, in nf
rv = func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 55, in nf
res = f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 183, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 203, in do_create
return self.create_internal(job, app_name, version, data[‘values’], complete_app_details)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 248, in create_internal
raise e from None
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 241, in create_internal
compose_action(app_name, version, ‘up’, force_recreate=True, remove_orphans=True)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/compose_utils.py”, line 61, in compose_action
raise CallError(err_msg)
middlewared.service_exception.CallError: [EFAULT] Failed ‘up’ action for ‘nextcloud’ app. Please check /var/log/app_lifecycle.log for more details
When I have tried to set the permissions for user and group to www-data I get this error
File “/usr/lib/python3/dist-packages/middlewared/plugins/filesystem_/perm_check.py”, line 122, in check_acl_execute_impl
raise CallError(
middlewared.service_exception.CallError: [EPERM] Filesystem permissions on path /mnt/Disc-0/Nextcloud-AppData prevent access for user “www-data” to the path /mnt/Disc-0/Nextcloud-AppData/AppData-Storage. This may be fixed by granting the aforementioned user execute permissions on the path: /mnt/Disc-0/Nextcloud-AppData.
The above exception was the direct cause of the following exception:
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 556, in run_body
File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem/acl.py", line 890, in setacl
return self.setacl_nfs4(job, data)
File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem/acl.py", line 597, in setacl_nfs4
self.middleware.call_sync(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1665, in call_sync
return methodobj(*prepared_call.args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/filesystem_/perm_check.py”, line 256, in check_acl_execute
run_with_user_context(check_acl_execute_impl, {
File “/usr/lib/python3/dist-packages/middlewared/utils/user_context.py”, line 55, in run_with_user_context
return exc.submit(func, *(func_args or )).result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 456, in result
return self.__get_result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 401, in __get_result
raise self._exception
And when i tried to set permission for my dataset PostgresData to User netdata I get this eroor
raise CallError(
middlewared.service_exception.CallError: [EPERM] Filesystem permissions on path /mnt/Disc-0/Nextcloud-AppData prevent access for user “netdata” to the path /mnt/Disc-0/Nextcloud-AppData/PostgresData-Storage. This may be fixed by granting the aforementioned user execute permissions on the path: /mnt/Disc-0/Nextcloud-AppData.
await self.future
It says to set user to execute Permission on the path but am unsure how to do this. Thank you for any help
