Hi folks,
I’m fairly new to TrueNAS Scale and want to run nextcloud via the official app on 24.10. Everything works so far, but there is one warning message left I would like to get rid of: The PHP OPcache module is not properly configured. The OPcache interned strings buffer is nearly full. To assure that repeating strings can be effectively cached, it is recommended to apply “opcache.interned_strings_buffer” to your PHP configuration with a value higher than “32”.
I have some experience with running nextcloud on a traditional LAMP Stack where I simply would change the value in the php.ini. There are some values in the php configuration exposed to the installation but unfortunately not opcache.interned_strings_buffer. Any chance to set it somehow permanently?
Thanks!
