Nextcloud Pod stucks in deployment
i got a problem after updation my nextcloud pod. A rollback didn`t work either so i updated to newest one, today. The error still persists.
It seems the postgres database has found an error. How do i resolve this error?
Application Name:nextcloudPod Name:nextcloud-postgres-7476bddf96-c4drfContainer Name:nextcloud
2024-10-27 21:55:58.759075+01:002024-10-27T21:55:58.759075001+01:00
2024-10-27 21:55:58.759123+01:00PostgreSQL Database directory appears to contain a database; Skipping initialization
2024-10-27 21:55:58.759137+01:002024-10-27T21:55:58.759137378+01:00
2024-10-27 21:55:58.885629+01:002024-10-27 20:55:58.885 UTC [1] LOG:  starting PostgreSQL 13.1 (Debian 13.1-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2024-10-27 21:55:58.886098+01:002024-10-27 20:55:58.886 UTC [1] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-10-27 21:55:58.886124+01:002024-10-27 20:55:58.886 UTC [1] LOG:  listening on IPv6 address "::", port 5432
2024-10-27 21:55:58.894964+01:002024-10-27 20:55:58.894 UTC [1] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-10-27 21:55:58.909073+01:002024-10-27 20:55:58.909 UTC [13] LOG:  database system was shut down at 2024-09-28 12:12:38 UTC
2024-10-27 21:55:58.910824+01:002024-10-27 20:55:58.910 UTC [13] LOG:  invalid record length at 2/8A74A3C8: wanted 24, got 0
2024-10-27 21:55:58.910860+01:002024-10-27 20:55:58.910 UTC [13] LOG:  invalid primary checkpoint record
2024-10-27 21:55:58.910874+01:002024-10-27 20:55:58.910 UTC [13] PANIC:  could not locate a valid checkpoint record
2024-10-27 21:55:58.911845+01:002024-10-27 20:55:58.911 UTC [1] LOG:  startup process (PID 13) was terminated by signal 6: Aborted
2024-10-27 21:55:58.911868+01:002024-10-27 20:55:58.911 UTC [1] LOG:  aborting startup due to startup process failure
2024-10-27 21:55:58.915459+01:002024-10-27 20:55:58.915 UTC [1] LOG:  database system is shut down
