I have installed Nextcloud by watching youtube tutorial where you create custom datasets. I have done this and put www-data full permissions to all datasets. Installation completed but this message showed up:
" * Your data directory and files are probably accessible from the internet. The .htaccess file is not working. It is strongly recommended that you configure your web server so that the data directory is no longer accessible, or move the data directory outside the web server document root."
Some say I have to edit apache config file (where it is by the way?)
And some are referring to config.php to include only FQDN domain.
I have included my FQDN domain there but can’t find the apache config file, can you help me?
When you give absolutely no relevant information in your post, that’s going to happen.
Because you’ve failed to give any relevant information, I don’t have the first clue. If you’d share, for example, what version of TrueNAS you’re running, details of how you installed Nextcloud, and exactly what errors you were getting, we might have a chance of being able to answer usefully.
